Author Topic: How to increase the repeat rate of my keyboard?  (Read 6277 times)
Offline repeatrate
« on: Fri, 21 January 2011, 01:45:58 »
Hallo,
thats my first post on geekhack and i hope this is the right section for my question.
I used to have a X7 A4tech keyboard and recently bought a 6gv2 steelseries keyboard. The problem is you were able to increase the X7's repeatrate with a button on the top right - and now the 6gv2 seems to be way slower repeating keys than what iam used to. Iam looking for way to increase the repeatrate - can i change some hkey variables or are there any programs out that allow me to do so?
Any help is appreciated
Thanks repeatrate
Offline repeatrate
« Reply #1 on: Fri, 21 January 2011, 02:12:57 »
That made it a little bit faster but there is still a huge difference to my old keyboard  settings. Is there a way to increase my repeat rate even more?
/E actually found an answer to my problem on the interwebz
i changed the HKEY variables to this and now my repeatrate is acceptable - probably needs some finetuning there but yeah.
[HKEY_CURRENT_USER\Control Panel\Accessibility\Keyboard Response]
"AutoRepeatDelay"="250"
"AutoRepeatRate"="13"
"BounceTime"="0"
"DelayBeforeAcceptance"="6"
"Flags"="59"
Now my Zerglings will come out as fast as they did with my old keyboard.
« Last Edit: Fri, 21 January 2011, 02:43:15 by repeatrate »
Offline Tony
« Reply #2 on: Fri, 21 January 2011, 03:58:34 »
I am also affected by this. Many thanks for your solution.
Offline Arc'xer
« Reply #3 on: Fri, 21 January 2011, 04:10:14 »
I checked those keyboard out and on their specs. Most if not all seem to specify PS/2 hell they even sell some with terminated with PS/2.
Were you by any chance using PS/2 port before hand?
I don't want to turn this into a PS/2 vs USB thing but maybe that's why?
Offline repeatrate
« Reply #4 on: Fri, 21 January 2011, 11:49:37 »
Quote from: Arc'xer;282174
The X7(old keyboard) was plugged in with a PS/2 but came with an adapter for USB iirc.
The 6gv2 came with USB and i plugged it in with the PS/2 adapter because i had some issues with my shift key before and using PS/2 magically fixed it.
Offline Arc'xer
« Reply #5 on: Fri, 21 January 2011, 12:23:04 »
Quote from: repeatrate;282360
Did your A4tech have a turbo button? I looked it up again and apparently some of the G-models have a turbo button.
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #6 on: Fri, 21 January 2011, 14:17:16 »
Aren't these registry settings for accessibility options only? Or did they change that at some point? I'd check the accessibility settings relating to keyboard.
Offline repeatrate
« Reply #7 on: Sat, 22 January 2011, 05:04:50 »
Quote from: keyb_gr;282465
yes but in the accessibility options the values i  can enter are limited, changing the HKEY variables allows me to increase the speed from 33 letters per second to something around 80-90 per second. I could also reduce the time for holding down a key giving out the same character again.
When i click on the accessibilty options now i have to change HKEY variables again because it reset the values to standard values.
Offline keyb_gr
  • Cherrified user
« Reply #8 on: Sat, 22 January 2011, 11:44:23 »
Ah, so the keyboard settings and keyboard accessibility settings have been merged? (Those registry keys used to belong to FilterKeys and other accessibility features, while regular repeat/delay values were stored under HKCU\Control Panel\Keyboard.) Control Panel is such a mess from Vista onwards.
