Author Topic: Noob question  (Read 2982 times)
Offline siaoginazakum
Noob question
« on: Sun, 06 February 2011, 02:04:43 »
Hey guys , i have a question for you about mechanical keyboards .. which is better for gaming ? Cherry mx black , brown or blue switches ? I've tried the blue before and i kinda like the clicky feel but i have not tried mx black or brown before because i can't :( ! What switches does the Steelseries 6gv2 use ? Would you recommend it ? Or should i buy the Filco keyboard with cherry mx blue switches ?
http://www.gameshop.com.sg/advanced_search_result.php?keywords=filco+majestouch&x=0&y=0
the second one .
Thanks !
Offline manfaux
Noob question
« Reply #1 on: Sun, 06 February 2011, 02:16:26 »
welcome to geekhack
it depends on what kind of game you will be playing really, are you a FPS gamer? Cherry blacks are very good for FPS but probably not the most fitting switch for typing.
the 6gv2 uses cherry blacks,
if you let us know what you will be using your keyboard for, everyone will share their input and will give you a pretty good idea of what to get.
Noob question
« Reply #2 on: Sun, 06 February 2011, 02:18:49 »
thanks !
well um .. i play counter strike , just cause 2 , gta 4 ... all sorts of games ! but the most is fps like Bad company 2 , i also type too ( not so much )
Offline manfaux
Noob question
« Reply #3 on: Sun, 06 February 2011, 02:24:49 »
Quote from: siaoginazakum;290616
thanks !
cherry blacks are fantastic for FPS gaming, and really not too bad for typing either once you get used to 'em. How much can you get a 6Gv2 for? if you can find a good deal on it then it's a pretty good choice.
looks like you are located in singapore? can't you get a hold of other Chinese mechanicals?(PLU ML-87, Noppoo choc mini etc.) Those are cheaper than the  6gv2 and pretty well made.
Noob question
« Reply #4 on: Sun, 06 February 2011, 02:27:40 »
i cant find the chinese mechanicals here in Singapore :( . which would you choose between the 6gv2 and filco with cherry blacks ?
Offline manfaux
Noob question
« Reply #5 on: Sun, 06 February 2011, 02:31:44 »
Quote from: siaoginazakum;290620
how much is the 6Gv2 over there?
I see the filcos for 190 SGD, is that the cheapest you could find?
Offline db_Iodine
Noob question
« Reply #6 on: Sun, 06 February 2011, 02:33:41 »
I would choose the one that's cheaper. There's not really that much difference between these keyboards after all.
[SIGPIC][/SIGPIC]
Noob question
« Reply #7 on: Sun, 06 February 2011, 02:36:40 »
the 6gv2 is cheaper by 5 bucks ~  if there's not much difference between the two i think i'll get the 6gv2 because i would have a complete SS set lol
Offline manfaux
Noob question
« Reply #8 on: Sun, 06 February 2011, 02:41:28 »
Quote from: siaoginazakum;290628
wtf ? that 6gv2 is so overpriced...for only 5 bucks more I'd go with the filco.
Noob question
« Reply #9 on: Sun, 06 February 2011, 02:43:49 »
Are the filcos is better made ?  Sorry for my questions xD
Offline db_Iodine
Noob question
« Reply #10 on: Sun, 06 February 2011, 02:44:53 »
One thing to consider is the possibility of a Filco tenkeyless. Would you be wanting to try a tenkeyless keyboard, or do you think you absolutely need a numpad? It's a lot easier to use your keyboard in a more ergonomic fashion and have it centered when using a tenkeyless or a small form factor keyboard.
Another thing to consider is that the Steelseries has a Bigass enter key (see the picture). If the price difference is only a few bucks, then my choice would turn to the Filco because of the normal Enter key, and R-shift layout.
« Last Edit: Sun, 06 February 2011, 02:47:47 by db_Iodine »
[SIGPIC][/SIGPIC]
Offline manfaux
Noob question
« Reply #11 on: Sun, 06 February 2011, 02:46:39 »
Quote from: siaoginazakum;290631
I've ever owned a 6gv2, so I can't give you a first-hand advice, but the filco  probably has the best build quality you could ever ask for.
Plus the 6gv2 has a big enter key, could be a problem in the future if you decide to get some new keycaps.
Offline manfaux
Noob question
« Reply #12 on: Sun, 06 February 2011, 02:54:40 »
Quote from: db_Iodine;290632
[/IMG]
yup, +1 for the tenkeyless versions.
Also if i recall correctly, the 6gv2 doesn't have the mouse feet that pops up in the back of it, deal breaker for me :)
Noob question
« Reply #13 on: Sun, 06 February 2011, 02:56:41 »
i will consider the tenkeyless version ! they look nice. Thanks for your help guys
Offline db_Iodine
Noob question
« Reply #14 on: Sun, 06 February 2011, 02:58:01 »
Quote from: manfaux;290636
Yep, with only $5 difference in price, I think we both agree that a Filco is a better choice - Be it Tenkeyless or a full size keyboard.
The biggest deal breaker for me would be the right shift key. I'm so used to hitting the left edge of the shift key that I would constantly miss the shift and hit |\ -key instead.
[SIGPIC][/SIGPIC]
Offline RiGS
Noob question
« Reply #15 on: Sun, 06 February 2011, 07:35:17 »
It has no feet, but the build is inclined in a superior way. Also KBC is going to supply keycaps for them.
The sound of the keyboard and the quality of the usb cable is way better than the Filco.
SS has cherry stabilizers which is imo comfortable and sturdy.
