Author Topic: Any way to stop MS Natural Ergo 4k from ghosting?  (Read 7312 times)
Offline redpill
« on: Thu, 10 February 2011, 11:11:59 »
I'm guessing the answer is no but I thought I'd ask.
I use a Microsoft Natural Ergonomic 4000 keyboard at both home and work and I really like the keyboard shape & layout.  My only issue is that there are a number of 3-key combinations that simply won't work.  Most notably up arrow, left arrow, and left control can't be pressed at the same time, the third keystroke is always ghosted.  Is there any easy way to mod the keyboard to prevent this from happening?  Or is the inherent underlying mat layout mean I'm screwed?
Thanks for any tips.
^ Current Favorite ^  Topre Realforce 87UB 55g  |  Topre Realforce 103UB 55g | KBC Poker/Browns/Sanded Keycaps |  Ducky 1087 | Filco MajesFoam-2 | IBM Model M 1390131 Feb '87 | Still Love: Microsoft Trackball Explorer x3 | Now Unused:  Microsoft Natural Ergo 4k x2
Offline bugfix
« Reply #1 on: Thu, 10 February 2011, 11:13:59 »
I'd say buying a decent keyboard with at least 6KRO is all you can do.
*~Unicomp and Topre fan~*
I have:
Unicomp Customizer 105 German
Realforce 105GR
Unicomp Spacesaver German/Ansi hybrid(Current favorite)
I want:
Realforce 88GER
I used to have:
DAS Model S Ultimate EU (Sold)
Offline redpill
« Reply #2 on: Thu, 10 February 2011, 13:32:11 »
Thanks, I kind of figured.  It's a shame because I think MS got the shape of this keyboard just right, and then ruined it by putting such cheap internals inside.  Between this and discontinuing the trackball explorer, I don't think I can ever forgive them.
Offline Lanx
« Reply #3 on: Thu, 10 February 2011, 16:17:45 »
hey i've opened a few ms ergo 4k's and lemme tell you, they are not cheap, I counted at least 20 screws maybe even 40 screws on these things. The zoom button is just overly done but is immaculately made.
Offline redpill
« Reply #4 on: Thu, 10 February 2011, 17:14:01 »
Quote from: Lanx;293038
Haha I've had the same experience after spilling a drink on one, I unplugged it quick, took it all apart, dried it out, put it back together, and voila.  Lots of screws indeed, but the design with the single mat of plastic domes is pretty underwhelming, in addition to the above referenced ghosting issue.
Offline Lanx
« Reply #5 on: Thu, 10 February 2011, 20:53:34 »
well it's either they're membrane like everyone else or somehow become mechanical and from experience, it's near design hemorroid.
Offline redpill
« Reply #6 on: Fri, 11 February 2011, 11:25:19 »
Understood, but there's nothing about the membrane design in and of itself that would prevent them from permitting a greater number of simultaneous keypresses, right?  Don't the undesirable ghosting characteristics come from having too simplistic of a board underneath?
Offline rantenki
    • http://armyofevilrobots.com/
« Reply #7 on: Wed, 23 February 2011, 22:51:59 »
Quote from: redpill;293411
More connections and diodes reduce ghosting, but both of those cost $$$. Take a look at that tiny little PCB; every extra square inch cuts into profits. And yeah, they are making BANK on that keyboard, but less bank for a bit less ghosting ain't gonna happen.
