Author Topic: steelseries keyboard = crap  (Read 18792 times)
Offline zhuak1
« on: Thu, 03 March 2011, 11:27:13 »
my 6gv2 is always disconnecting from usb, my ctrl sometimes stucks.. it seems that this keyboard lags.. mechanical keyboards from steelseries sucks!
which one to get?
Offline pitashen
« Reply #1 on: Thu, 03 March 2011, 11:39:50 »
Filco
Das
Zowie
Deck
Cherry
Unicomp
etc.
You got quite a few choices
Offline ch_123
« Reply #2 on: Thu, 03 March 2011, 11:42:14 »
Have you looked into getting some sort of RMA yet? Those Steelseries aren't the most reliable keyboard around.
Did you like the switches on them?
Offline zhuak1
« Reply #3 on: Thu, 03 March 2011, 11:48:01 »
well i use alot of "CTRL" and "SHIFT" buttons to press very quickly! and they seem to be... too heavy.. i dont know..
which models do you recommend? i dont think that we can find filco's and deck's keyboards in portugal
anyway, which one to professional gaming? is celeritas good?
Offline ch_123
« Reply #4 on: Thu, 03 March 2011, 11:51:05 »
Keyboard Co in the UK ships Filcos around Europe. I don't think they are available in the Portugese layout though.
Many people find the blacks too heavy. You may want to look into something with Brown switches.
Offline Artillery
« Reply #5 on: Thu, 03 March 2011, 11:51:54 »
You are aware that Steelseries boards use cherry blacks right?  They are linear and actuate at 80g, its alot.
You might prefer a switch thats tactile like cherry browns or clears.
Current Keyboard: Deck Legend Ice (Tactile) with Cherry Clear switches
Offline zhuak1
« Reply #6 on: Thu, 03 March 2011, 11:54:06 »
but every pro gamer like SK players and fnatic players use 7G! :/ filco isnt a gaming brand...
which models with brown cherry?
Offline RiGS
« Reply #7 on: Thu, 03 March 2011, 11:56:49 »
I don't think there is an issue with lag. Probably your monitor sucks.
The usb connertor is just fine.
You should try a spring mod on your SS. I recommend you sixty's custom springs.
Btw the cable is easily replaceable.
Offline RiGS
« Reply #8 on: Thu, 03 March 2011, 11:58:07 »
Quote from: Artillery;304305
You are wrong! It actuates at 60g.
Offline pitashen
« Reply #9 on: Thu, 03 March 2011, 12:02:54 »
FPS = might want black
RTS --> brown to avoid finger strain
Zowie's not bad I heard, its brown. Just make sure you read all the reviews out there possible.
Offline Ekaros
« Reply #10 on: Thu, 03 March 2011, 12:02:56 »
Quote from: zhuak1;304306
No, because it's better...
Browns or reds if you want light feel and don't care about tactility.
Personaly I don't like my 6G either...
So I should add something useless here yes? Ok, ok...
Filco 105-key NKRO MX Browns Sw/Fi-layout|IBM Model M 1394545 Lexmark 102-key Finnish-layout 1994-03-22|Cherry G80-3000LQCDE-2 with MX CLEAR
[SIGPIC][/SIGPIC]
Dell AT102W(105-key SF) (Black ALPS)|Steelseries Steelkeys 6G(MX Black) ISO-FI-layout|Cherry G84-4400 G84-4700 Cherry MLs
Offline zhuak1
« Reply #11 on: Thu, 03 March 2011, 12:05:34 »
are razer keyboards good? lycosa or tarantula?
Offline zhuak1
« Reply #12 on: Thu, 03 March 2011, 12:06:58 »
should i go for a filco then? better than 7G? usb or ps2? Hugs guys and thanks!
Offline pitashen
« Reply #13 on: Thu, 03 March 2011, 12:08:51 »
Whats your definition of a gaming brand?
A brand with the "cool" gaming factor design?
Then you are greatly mistaken.
Any keyboard with the proper switch type (that suits your fingers for gaming) and with NKRO (or even just 6KRO) can be considered as a gaming keyboard
The gaming "brand" is there just to catch people's attention.
*It would be nice if you could do a bit of research on your own.
« Last Edit: Thu, 03 March 2011, 12:11:22 by pitashen »
Offline phillip
« Reply #14 on: Thu, 03 March 2011, 12:10:14 »
"Gaming brand" is just another marketing tool.  I played CS a lot with a filco with black switches and now I'm playing with brown switches and either one is fine.
Offline guilleguillaume
« Reply #15 on: Thu, 03 March 2011, 12:15:52 »
Quote from: zhuak1;304299
Quote from: ripster;304312
Aren't you polite.  Are you German?
He is from portugal!  They used to fight us :fencing:
You should RMA your Steelseries 6G and then when it comes back sell it like NIB and then buy another Keyboard that suits you better.
Offline krazymunky
« Reply #16 on: Thu, 03 March 2011, 12:16:26 »
Just because progamers use them doesnt mean they are the best. Its possible that they use them because theyre sponsored by the company.  Filco isnt a 'gaming keyboard' but I have seen a few korean starcraft 2 progamers use them.
Filco is a good unless you dont want a 'boring' looking keyboard.
Offline zhuak1
« Reply #17 on: Thu, 03 March 2011, 12:23:07 »
http://www.gamegear.be/product_info.php?cPath=102_49&products_id=1621&osCsid=t77hiu8nu5b1c38cks0d1o4234 this one is brown?
gief models to search and read reviews please :) one keyboard for gaming, top!
Offline Ekaros
« Reply #18 on: Thu, 03 March 2011, 12:28:35 »
Quote from: zhuak1;304328
Tactile generaly means Browns. Check:
http://www.keyboardco.com/ too for prices.
[SIGPIC][/SIGPIC]
Offline Shuki
« Reply #19 on: Thu, 03 March 2011, 12:38:07 »
I heard some ss6Gv2 had issues via usb but worked fine through ps/2. Have you tried that?
Offline pm_
« Reply #20 on: Thu, 03 March 2011, 13:51:21 »
Quote from: pitashen;304313
Blacks suck.  Regardless of application, they should be last on anyone's list unless they have previously tried them and know they like them.  They are a bad first switch to get if you haven't tried the others.
And their is absolutely nothing inherent to them that makes them better for FPS gaming.
Also, there's nothing special about Steelseries. Their products are fine, but nothing that makes them inherently better than, say, Filco keyboards, Sennheiser headphones, or Logitech mice. It's all about the marketing.
Offline Ekaros
« Reply #21 on: Thu, 03 March 2011, 13:55:28 »
Only good thing about Steelseries is mass market availability, nothing else.
[SIGPIC][/SIGPIC]
Offline zhuak1
« Reply #22 on: Thu, 03 March 2011, 14:02:25 »
zowie celeritas.. the one to get it?
woody
  •  Guest
« Reply #23 on: Thu, 03 March 2011, 14:10:08 »
Gaming world is such a joy.
Offline Shuki
« Reply #24 on: Thu, 03 March 2011, 14:24:34 »
Tbh, I wouldn't rule out non-gaming keyboards.
As someone who spends quite a lot of time playing a variety of different games, I can safely say the requirements for a good keyboard for "gaming" are less stringent than a good keyboard for typing.
Unless you are playing a game which requires two hands on the keyboard (I would say this isn't the case for a vast majority of people who call themselves "gamers") you only require a board to be able to process at most 5 key presses simultaneously. Once you've ruled this feature as something which you do not require (you don't press five keys at once) or ruled out keyboards which do not have this feature, there is very little which will have any effect on playing games.
From what I have seen, switch type is often over-emphasised to people who play games on this site, as people equate playing games to typing. Disregarding switches that cannot be pressed in quick succession (I've heard this is the case with cherry blues) the type of key switch won't have a huge impact on your experience. When playing games people tend to press the key much harder than what is necessary to activate the switch, and as a result people can be less discriminating on how the switch itself feels.
The obvious solution is, try to find a keyboard that you will enjoy typing on and then use that for playing games as well. As long as it doesn't have any of the issues as mentioned above then you won't have any issues playing games either.
Offline zhuak1
« Reply #25 on: Thu, 03 March 2011, 14:32:52 »
guys, i don't understand nothing from keyboards.. i was expecting some help from you! :p
woody
  •  Guest
« Reply #26 on: Thu, 03 March 2011, 14:37:31 »
Quote from: zhuak1;304431
Do you need advice on women and cars as well?
Offline zhuak1
« Reply #27 on: Thu, 03 March 2011, 14:56:16 »
lol that web only have like 3 keyboards from what i've seen.. im going to buy some stuff from gamegear.be and they only have this ones: http://www.gamegear.be/index.php?cPath=102_49&osCsid=3tipjsrr1n01chnfgkuj8r6tp4
like 4-5 filcos
so you recommend filco majestouch.. with BROWN cherry! (lighter) so.. which of them.. have brown cherry?
Offline thebilgerat
« Reply #28 on: Thu, 03 March 2011, 15:06:48 »
Quote from: zhuak1;304449
like 4-5 filcos
Crap, dude.  Buy this, because your zerg rush speeds increase by 20% from a special FPGA processor chip inside that buffers the IO to speed up their tiny little legs:
http://www.amazon.com/Logitech-920-002478-Keyboard-K120/dp/B003ELVLKU
10 dollars US.  Comes with space-age keys as well, along with high-density rebound system.  For a $150 US premium to me, I will personally outfit this gaming powerhouse with custom graphics, a "tactile feel" WASD cluster, braided EMP-resistant cable, and an official certificate that says your starcraft 2 penis is very large.
Offline zhuak1
« Reply #29 on: Thu, 03 March 2011, 15:13:15 »
"After havin black switches, which i didn't like, i thought about browns too, but in the end those felt even worse.
Because the only way u can benefit from mechanical switches IMHO, is if u can get used to not pressing the key all the way down, and browns r so light, that u must be really relaxed which is impossible while gaming."
cmon guys.. just a little help lol. if you were in my position, which one...
Offline Ekaros
« Reply #30 on: Thu, 03 March 2011, 15:18:42 »
Quote from: zhuak1;304459
It doesn't matter while you game if you press them down. It's helpfull when typing though...
[SIGPIC][/SIGPIC]
Offline zhuak1
« Reply #31 on: Thu, 03 March 2011, 15:22:50 »
i cant decide for myself :(
Offline dracaXL
    • http://www.technickal.org
« Reply #32 on: Thu, 03 March 2011, 15:26:39 »
There's nothing wrong with the Steelseries boards... if you're having issues with your particular model, return it and get a replacement. If that one doesn't suit you either, buy a different board.
It seems you're not a fan of the MX Black switch type (I, personally, love them) so you may want to have a look at MX Brown switch keyboards (Zowie Celeritas has a good rep) or MX Blue switches... most likely the MX Brown switch will be the best for you based on what you've said in the last couple of pages.
I'd try to get a Celeritas, or if you don't mind not having the 'gaming' image then go for the quality of a Filco Tenkeyless Tactile.
Filco Majestouch Linear (i.e. MX Blacks) | Noppoo Choc Mini (MX Browns) | TVS Gold Bharat (MX Blue) | VorTex KBC Poker* (MX Red)
Intel Core i7-2600k | Gainward GTX 580 GOOD | 8GB XMS3 DDR3 RAM | Gigabyte P67-UD4 | Asus Xonar Essence ST | NZXT Phantom | KRK RP5 G2 w. Wharfedale SW150
*pre-ordered
Offline pitashen
« Reply #33 on: Thu, 03 March 2011, 15:37:59 »
Seems you just wanted to be spoon fed. So here I decide for you
1. Filco or leopol  mx brown  Whichever available for you
2. Zowie (only come with brown)
3. Das keyboard brown switch version
Or blue switch of above mentioned
Offline Armando Penblade
    • http://thegeekery.org
« Reply #34 on: Thu, 03 March 2011, 15:53:56 »
Filco & Leopold have same designer, and the Filco line GENERALLY has good, respectable quality. Neither feature media keys or "fancy" stuff.
Zowie is a gaming board. Which, I'm sure, is nice.
Das is a decent brand marred by a lot of bad decisions in the past. Their keyboards also get all smudgy. No media keys.
Filco Majestouch 104-US, Metallic Blue, with Chery MX Blues  //  Microsoft Comfort Curve 2000, 104-US + Media Keys & Browser Controls  //  iRocks RF-6570 Cordless 104-US, 2.4GHz Wireless, White  //  SteelSeries 6Gv2 104-US, Black, with Cherry MX Blacks
Offline zhuak1
« Reply #35 on: Thu, 03 March 2011, 16:06:05 »
for counter strike maybe im going for celeritas. but zowie had so many problems with their mice.. ec2... i ****ing dont know..
Offline pitashen
« Reply #36 on: Thu, 03 March 2011, 16:07:10 »
I already provided you the alternatives.
Offline zhuak1
« Reply #37 on: Thu, 03 March 2011, 16:17:06 »
whats your opinion about 7G
Offline Ekaros
« Reply #38 on: Thu, 03 March 2011, 16:55:30 »
Quote from: zhuak1;304498
Same, but fancier than 6Gv2...
[SIGPIC][/SIGPIC]
Offline bxt
« Reply #39 on: Thu, 03 March 2011, 17:14:58 »
This is what I would go for (I too own Steelseries 6gV2)
MX Browns: Zowie Celeritas (similar layout to Steelseries, has media keys, build quality should be good)
MX Blues: Razer Blackwidow
Offline Nadger
« Reply #40 on: Thu, 03 March 2011, 17:34:37 »
Quote from: thebilgerat;304456
Careful man, you might get sued by steelseries, razer, logitech and saitek for stealing their ideas and IPs.
● Logitech ♦ G600
● Noppoo ♦ Choc Mini 茶轴
● Plum ♦ 96 White / Red Switch
● Microsoft ♦ Xbox 360 Windows Controller
Offline zhuak1
« Reply #41 on: Thu, 03 March 2011, 17:57:47 »
Quote from: bxt;304545
difference from mx blue and brown? you dont like 6gv2?
Offline rustybarnacle
« Reply #42 on: Thu, 03 March 2011, 18:02:58 »
Lulz!
Offline zhuak1
« Reply #43 on: Thu, 03 March 2011, 18:05:14 »
rofl, i quoted the text from some random website. that was a comment from a guy. saying that browns is worst than black..
im so... so... so... confused..
7G - Celeritas - Filco MX Brown/Blue.. - Razer Black Widow
Offline noodles256
  • le legendary
« Reply #44 on: Thu, 03 March 2011, 18:07:09 »
Quote from: zhuak1;304577
Obviously people will have different opinions. You have to figure it out yourself.
Stop derping around waiting to for people to tell you what you want because it may not be what you want.
derptard
AF | Ducky YOTD |
« Reply #45 on: Thu, 03 March 2011, 18:10:56 »
Man, you guys are flipping angry :)
Offline jsvd
« Reply #46 on: Thu, 03 March 2011, 18:13:16 »
And stop embarrassing us Portuguese :P
Offline thebilgerat
« Reply #47 on: Thu, 03 March 2011, 18:15:52 »
real gamers use this (notice custom graphics - increases "BOOM!  HEADSHOT" ratio by 64%):
Offline canon.tk
« Reply #48 on: Thu, 03 March 2011, 18:25:40 »
Quote from: pm_;304392
You really shouldn't speak for others.  It's all personal preference.  I love Black switches for typing and gaming.  It techincally wasn't the first I tried, browns were first, but that was a friend's board.  After him letting me use it for two days I bought a Filco with blacks and love it.
Filco Majestouch 104 Cherry MX Black; Filco Majestouch 87 Ninja Cherry MX Brown; Filco Majestouch Indigo Blue 104 Cherry MX Brown; Filco Majestouch 2 104 Cherry MX Red; Leopold 87 Otaku Cherry MX Brown; Leopold 87 Cherry MX Brown; Razer Black Widow Ultimate
Offline pitashen
« Reply #49 on: Thu, 03 March 2011, 18:32:59 »
yawn
