Author Topic: Goo Gone  (Read 7490 times)
Offline patrickgeekhack
Goo Gone
« on: Fri, 04 March 2011, 17:10:31 »
How bad is this stuff for plastic? I need to remove some sticky stuffs under my AEK II. It seems that there was a sticker underneathe keyboard. I used Goo Gone to remove it. It worked. However, I noticed that Goo Gone smell was similar to something containing petroleum derivatives. I heard that petroleum derivatives could be bad for resin.
Cherry MX Blue: Cherry G80-3000, Das Keyboard Model S Ultimate
Cherry MX Brown: Filco Majestouch, Compaq MX11800
ALPS: AEK, AEK II, Northgate Omnikey Ultra, Matias Tactile Pro 4
Topre: Realforce 103UB
Buckling Spring: IBM Model M 1390120
Previous owned: Unicomp Customizer 104, IBM Model M 1390141, ABS M1
Offline digitalleftovers
Goo Gone
« Reply #1 on: Fri, 04 March 2011, 17:14:35 »
Quote from: patrickgeekhack;305177
I haven't used that stuff in years, but if it is the same thing, then I'm pretty certain it works by using citric acids...  It contains orange oil, but I do not know of that being hardful to plastic.
Keyboards:
Filco 104 MX Brown (Otaku) - FKBN104M/NPEK 黒い空
Ducky TKL MX Brown/Blue 80% (White) - 1087-F 白の空
KBC Poker MX Red with PBT Key Caps - PFCN6000
"Consumers use touch screens.  Producers use keyboards."
Offline isp
Goo Gone
« Reply #2 on: Fri, 04 March 2011, 17:15:51 »
works great, love the stuff
hhkb
Goo Gone
« Reply #3 on: Fri, 04 March 2011, 17:16:12 »
Quote from: ripster;305179
It's the BOTTOM of your keyboard Patrick.
Speaking of keyboard bottoms, my G15 got knocked against a heater last night (its normally on the floor).  The bottom is pretty warped now...
Keyboards:
Goo Gone
« Reply #4 on: Fri, 04 March 2011, 19:00:42 »
I know it's the bottom of my keyboard, but some inevitably got on the keycaps after I plugged the keyboard and started to type again. Today I tried to wipe the surface with a wet cloth trying to remove any left over. This thing is a bit oily and I am a bit obsessive.
Goo Gone will remove what it is supposed to remove. It's the smell left that I don't like.
Goo Gone
« Reply #5 on: Fri, 04 March 2011, 19:30:28 »
Quote from: ripster;305253
It's not Citric Acid.  I use citric acid to maintain my Espresso Machine.
But I wouldn't worry about it.
Have a double shot and fuggedaboutit.
I have an espresso machine too. Only for about 3 months now.  I have yet to clean the internals  but I am not too worried. We have very pure water. What product do you use?
Keyboards:
Offline keyboardlover
Goo Gone
« Reply #6 on: Fri, 04 March 2011, 19:31:17 »
That'd be cool if you could control your espresso machine with your keyboard.
Goo Gone
« Reply #7 on: Fri, 04 March 2011, 19:43:59 »
Thanks. I will check it out.
Keyboards:
Offline ricercar
  • mostly abides
Goo Gone
« Reply #8 on: Fri, 04 March 2011, 22:43:10 »
Bzzt. Good answer. Thank you for playing.
Unmatched for versatility, Citrus Power and Scientific Technology combine to solve your most difficult cleaning problems. Goo Gone takes the chore out of household cleaning.
Offline heedpantsnow
  • Old enough to know better
Goo Gone
« Reply #9 on: Sat, 05 March 2011, 00:12:53 »
ripster, is that a Sylvia?
edit:  nvm, it's a Quickmill.  nice doser in the background, what kind of grinder?
I'm back.
Goo Gone
« Reply #10 on: Sat, 05 March 2011, 00:25:41 »
Niiiice, I have the same thermometer for frothing.  stupid battery is soldered in on mine though.
Why didn't you go PID?
OP, by the way, I WOULD keep Goo-gone (and also carbon fiber epoxy resin :D) away from typical computer plastics.  I accidentally gave my macbook an 'alligator skin' finish one time!
I'm back.
Goo Gone
« Reply #11 on: Sat, 05 March 2011, 02:24:06 »
Quote from: ripster;305396
Grinder setup.
Nice.
I'm back.
Offline ashort
  • Hoosier Daddy
    • http://andrew.wingedwheel.net
Goo Gone
« Reply #12 on: Sat, 05 March 2011, 12:38:15 »
I've used Goo Gone on the GPU, CPU, and motherboard of a couple of XBox 360s to clean up old thermal paste and the only thing it did was clean it up REALLY nice in a way that rubbing alcohol could not.  I wouldn't worry about using it on anything metal or plastic, ever.
I would NOT use it on anything "goo like" that I wanted to preserve.  =-D
Andrew
{ KBC Poker - brown | Filco Majestouch - brown | Dell AT101W | Cherry G84-4100 }
Goo Gone
« Reply #13 on: Sat, 05 March 2011, 12:39:59 »
Quote from: ashort;305592
That makes sense :-)
Goo Gone
« Reply #14 on: Sat, 05 March 2011, 12:40:42 »
Quote from: heedpantsnow;305402
Nice.
Expresso machines is a hobby I try not to get into because it can be very expensive. Keyboards and fountain pens are expensive enough.
Offline theferenc
Goo Gone
« Reply #15 on: Sat, 05 March 2011, 12:50:24 »
2 large cappucinos a day, every day, all year? Caffeine addiction, much?
Goo Gone
« Reply #16 on: Sat, 05 March 2011, 12:53:10 »
Quote from: ripster;305600
Venti Starbucks Cappucino in NYC $5 x 2 a day x 365 days = $3,650.
Plus Starbucks cappucino's suck.
I visit Starbucks maybe once or twice a year.  I had (still have) a Breville thermobock espresso machine. I don't use it anymore for two big reasons: time and noise. I wake up at 4:00 am every day to study before going to work. If I try to make an espresso that early, I am sure to wake up my daughter. Moreover, it does take more time to make an espresso and to clean up after.
I want one of these: http://www.alessi.com/en/2/1309/coffee-machines/90906-espresso-coffee-maker
I met an Italian who swear by this machine. He does make great coffee from this little machine.
Offline rustybarnacle
Goo Gone
« Reply #17 on: Sat, 05 March 2011, 14:35:31 »
And...thread jacked
Goo Gone
« Reply #18 on: Sat, 05 March 2011, 14:46:37 »
Quote from: rustybarnacle;305670
And...thread jacked
It's okay if I thread-jack my own thread, isn't it?
Quote from: ripster;305672
Well, aren't you boring.
Here is the chemical analysis.  Some nasty stuff in there.  The Citrus extracts are there to make you think you are getting something "natural".
Did you guys fall asleep in Chemistry 101?  Shoulda had coffee.  God's nectar.
And WHY oh WHY do I have to always correct RicerCar?
I knew the petroleum part was very high. There was no way citrus based products would be as strong on these gooey stuff. I did not take any Chemistry class unfortunately. High school (British system) was Economics, Mathematics and Accounting, General Paper and French for me.
Goo Gone
« Reply #19 on: Sat, 05 March 2011, 14:53:52 »
Quote from: ripster;305683
Damn, no wonder the British had to resort to Financial Services instead of making stuff.
Now their economy has gone gooey.
Well...you should not jump to conclusion that rapidly. Just because I came from a British school system did not mean that I am from UK. That's very far from the truth. In fact, I was about a 12-hour flight away from England.
What conclusion would you come up with if I told you that my post-education was from the French system? This time, keep in mind that I was nowhere near France.
Goo Gone
« Reply #20 on: Sat, 05 March 2011, 14:59:15 »
Quote from: ripster;305690
If you came from the French system you would be on Strike right now.
LOL. I have experienced more than one system. French/British/Canadian systems, at various points in my life.
Offline False_Dmitry_II
Goo Gone
« Reply #21 on: Sat, 05 March 2011, 14:59:34 »
Canada? maybe Newfoundland?
Goo Gone
« Reply #22 on: Sat, 05 March 2011, 15:00:29 »
Quote from: False_Dmitry_II;305694
? What do you mean?
Goo Gone
« Reply #23 on: Sat, 05 March 2011, 15:24:14 »
Quote from: patrickgeekhack;305695
? What do you mean?
While I currently reside in Canada, I was not born here. I come from the island of Mauritius.
Goo Gone
« Reply #24 on: Sat, 05 March 2011, 15:31:43 »
Quote from: patrickgeekhack;305715
Wow...pretty interesting. Looks beautiful!
Why on Earth did you leave??
Talk about "goo gone!" :D
Goo Gone
« Reply #25 on: Sat, 05 March 2011, 16:23:05 »
Quote from: ripster;305721
He's telling a Newfie joke.  I'd tell a Mauritian joke but I don't know french.
Oh wait, did you hear the one about the Coconuts, the Hula dancers, and the Mariachi Band?
What a Cast A Nuts!
It would be a mistake to assume that French is the dominant language in Mauritius, although it is used a lot. We don't have Hula dance, but we do have sega.
Quote from: keyboardlover;305723
I left because there are things I can do in Canada that I could not do there. For example, getting a university degree while studying part-time is not really an option. There's only one university there, and the competition to get in is really really tough.
This was one of my favourite activities while there. It's the most relaxing activity in my opinion.
Offline Oh Mike!
Goo Gone
« Reply #26 on: Sat, 05 March 2011, 16:37:46 »
Quote from: patrickgeekhack;305782
How about dodo hunting?
Goo Gone
« Reply #27 on: Sat, 05 March 2011, 16:44:02 »
Quote from: Oh Mike!;305794
There's none left. The Duth killed them old. I can see comments about Webwit coming.
Offline Surly73
Goo Gone
« Reply #28 on: Sat, 05 March 2011, 19:32:05 »
I had something like Goo Gone (I don't know if it was genuine "Goo Gone" or not) dissolve the case on a Startac I was cleaning up once.  I would certainly worry about using it on plastic, depending on the kind of plastic.  I don't know exactly what the Startac was made from, but that can probably be determined.  It was like the gooey label I was trying to get off was infinite, because the plastic case started going gooey from the solvent.  It took a couple of rubs before I definitively figured out what was going on.
Offline Surly73
Goo Gone
« Reply #29 on: Sat, 05 March 2011, 19:33:26 »
Wait - did he just give away that he's in NYC?  Or was it a carefully crafted slip to make us think he's in NYC.  If Cappucinos are $5, imagine how much cappuccinos must be with that extra 'c'!
Offline Surly73
Goo Gone
« Reply #30 on: Sat, 05 March 2011, 19:35:04 »
There are two Goo Gones - a nasty one and a citrus one.  They're both called goo gone IIRC
