Author Topic: How can I remove the print off my majestouch?  (Read 3104 times)
Offline bytemeavaj
« on: Thu, 10 March 2011, 18:30:59 »
Hello guys,
Sorry for this most likely repetitive question but I searched and couldn't find anything on this.
Is there a safe way to remove all of the print on the keys? Some solution I should use?
I was reading a previous thread about something similar, and one guy used fingernail polish, but then ripster said that was 20% acetone and then a bunch of other crap you don't want on a keyboard so that turned me off.
Thanks
I\'m a tool.
Offline phillip
« Reply #1 on: Thu, 10 March 2011, 18:50:59 »
my fingers
Offline digitalleftovers
« Reply #2 on: Thu, 10 March 2011, 18:53:01 »
Quote from: bytemeavaj;309507
Hello guys,
Thanks
May I ask why you don't just pick up some blank key caps?
Keyboards:
Filco 104 MX Brown (Otaku) - FKBN104M/NPEK 黒い空
Ducky TKL MX Brown/Blue 80% (White) - 1087-F 白の空
KBC Poker MX Red with PBT Key Caps - PFCN6000
"Consumers use touch screens.  Producers use keyboards."
Offline keyboardlover
« Reply #3 on: Thu, 10 March 2011, 18:53:10 »
Quote from: phillip;309535
my fingers
That's what she said.
Offline RiGS
« Reply #4 on: Thu, 10 March 2011, 18:53:42 »
Sandblast'em.
Offline bytemeavaj
« Reply #5 on: Thu, 10 March 2011, 18:56:26 »
Quote from: digitalleftovers;309540
Well, I don't really need an extra set of keys. Aren't they around $50 shipped from armygroup? Is there a better alternative closer to home (USA)?
If I can remove the print easily, I would prefer to go that way.
I\'m a tool.
Offline RiGS
Offline pitashen
« Reply #7 on: Thu, 10 March 2011, 19:03:52 »
I thought using sand paper to sand the prints off is pretty safe... since you are not dealing with dangerous chemicals. Do be careful not to breath in plastic particles flying off from the sanding process though.
Offline Lpb45
« Reply #8 on: Thu, 10 March 2011, 19:26:54 »
you could just get a black permanent marker, dunno how it would look though or for that matter how long it would last
Topre - 86U   |   Filco - Tenkeyless Linear Red
Filco - Tenkeyless Blue       |   Filco - Fullsize Non NKRO Blue (Work)
Offline bytemeavaj
« Reply #9 on: Thu, 10 March 2011, 19:49:02 »
I see. I guess I should just buy a set of blank caps.
Will this work? Thanks
http://www.armygroup.com.tw/shop/goods.php?id=5370
I\'m a tool.
Offline Lpb45
« Reply #10 on: Thu, 10 March 2011, 19:54:00 »
It may be cheaper to just get them through 7bits group buy and they will be double shots then too
Offline Pylon
« Reply #11 on: Thu, 10 March 2011, 20:05:29 »
Just post a classified asking for blank keys or possibly a trade.
Offline Tony
« Reply #12 on: Thu, 10 March 2011, 20:07:35 »
You could do it but it erases all the coatings of the keys and make the keys look dirty and not shiny.
I have done it with cheaper rubber dome keycaps, so I never do it with Cherry keycaps.
Offline bytemeavaj
« Reply #13 on: Thu, 10 March 2011, 22:38:04 »
thanks for the advice guys
I\'m a tool.
