Author Topic: KBC Poker 40% New design of the keyboard frame part.1  (Read 18831 times)
Offline bl1978
« on: Wed, 16 March 2011, 00:00:23 »
Hi, I"m a keyboard fan from Taiwan
Very pleased to come here to share with you information about the keyboard
Recently I got the keyboard KBC poker 40%
PBT keycap and cherry black posed by the mechanical axis of the keyboard, and keys location has not been changed.
I feel very satisfied of the keyboard. I was quite happy at the time.
But I think KBC poker 40% could be better
So I started thinking, I want to add more functions, to make it perfect
The following summarized design ideas.
1. Storable USB cable
  40% of the keyboard to go out quite easily, if the USB cable can be incorporated in the function of adding even more ideal. It can be forget to bring the USB cable out to avoid the dilemma.
2. USB cable can be adjustable
As an external device, sometime we need longer cable, if the cable can be adjusted so that will be the best.
3. Hight of the Keyboard can be adjust
I always liked adjustable keyboard, if they can add this features it would be ideal.
I am a industrial designer, so I am quite familiar with the product design process
So I started working the design of the KBC poker 40%
I can add three more functions.
(The sharing will be completed in two articles)
In order to achieve the exact size, I first disassembled the keyboard KBC poker 40%
And take it to 3D reverse scan
As the white spray paint scanning needs, it becomes like this
After I use 3D graphics software, the 3D rendering completed in full accordance with the ratio of 1:1
And in the frame I want to add functionality.
This is a 3D drawing final look, I have considered the feasibility of the die mold. This is certainly not problem.
Then, making the sample frame
I used to draw a 3D CNC in accordance with drawings to process samples
Figure not yet completed processing of plastic paint colors
Assembly testing
KBC poker 40% I have remove the load board that and put into the sample frame which I designed myself
Storage USB cable test
50cm USB cable
USB wire diagram incorporating
100cm USB cable
With three holes to reach the control pressure line the length of USB cable length
Use it with ipad
Currently the keyboard frame is not yet completed
There are keyboard stand not making and the frame needs painting
I prefer to paint color in iron-gray
Please look forward to part 2
And please respect this article as intellectual property, without my approval, please do not reprint articles
Thanks
Brian
My BLOG
http://design1978.pixnet.net/blog/post/33520525
Topre Realforce 103 (PBT Keycap)
Topre Realforce HiPro
KBC Poker 60% (PBT Keycap)
Offline calavera
« Reply #1 on: Wed, 16 March 2011, 00:09:07 »
this is freaking awesome! If only we had someone who could design PCB's we'd be one step closer to making our own custom keyboards.
Would have been perfect if there was a comparison pic showing the original KBC case side by side as well since most of us (like 99%) don't own a KBC poker yet. I haven't paid much attention to the underside pictures of the keyboard itself in some of the reviews but I doubt anyone does.
Offline reaper
« Reply #2 on: Wed, 16 March 2011, 00:17:40 »
Hey Brian, welcome to GeekHack and that is very cool!  Looking forward to part 2. =D
Din Eli
Offline laden3
« Reply #3 on: Wed, 16 March 2011, 00:51:42 »
Hello~~您老好~~~ 花了多少钱 (how much did u spend)?
I rrrove brrracks.
Offline n12
« Reply #4 on: Wed, 16 March 2011, 01:01:53 »
Ugh, KBC Pokers are just sexy. Even without the girl.
Offline db_Iodine
« Reply #5 on: Wed, 16 March 2011, 04:09:27 »
That cable holder is just a fantastic idea. I can't wait to get my Pokers.
[SIGPIC][/SIGPIC]
Offline CephalicCarnage
« Reply #6 on: Wed, 16 March 2011, 07:25:14 »
Looks amazing!  I'm really digging that cable holder design.
Filco Tenkeyless "Otaku" (Blue), Leopold Tenkeyless "Otaku" (Brown), Leopold Tenkeyless (Blue), Goldtouch GTC-0077 Numeric Pad (Brown)
In the mail: HHKB Pro2 White/Gray
WTB: G80-8113HRBUS-2 with Clear switches
Offline Brodie337
« Reply #7 on: Wed, 16 March 2011, 07:49:29 »
I would perform unspeakable sexual favors in order to get an aluminium one of those... Or just pay money for plastic.
Offline bl1978
« Reply #8 on: Wed, 16 March 2011, 07:49:35 »
I think the price of the problems and can not be calculated correctly
Design ideas and drawing the correct calculation of the cost of not
However, the cost of plastic materials and processing can be calculated
« Last Edit: Wed, 16 March 2011, 08:15:04 by bl1978 »
Offline 002
  • Topre Enthusiast
« Reply #9 on: Wed, 16 March 2011, 08:07:33 »
good lord...do you take commissions? :)
Offline bl1978
« Reply #10 on: Wed, 16 March 2011, 09:18:33 »
I think I designed this keyboard frame
 Just to finish my own design ideas
 I do not know what you mean
 commissions ?
Offline Philth
« Reply #11 on: Wed, 16 March 2011, 09:58:32 »
This is awesome. Have you considered contacting KBC with the design?
Offline bl1978
« Reply #12 on: Wed, 16 March 2011, 10:17:16 »
I'm just an independent designer
I have eight years of industrial design experience
Design of the frame, is my personal preference
not associated with KBC
Offline Lpb45
« Reply #13 on: Wed, 16 March 2011, 10:21:17 »
liking those pics
Topre - 86U   |   Filco - Tenkeyless Linear Red
Filco - Tenkeyless Blue       |   Filco - Fullsize Non NKRO Blue (Work)
Offline gilgam
« Reply #14 on: Wed, 16 March 2011, 10:33:59 »
Commissions :
he means do you sell it at the factory cost or do you take some bribe  ;-)
Realforce 105 FR, HHKB Pro 2 black, 1 Raptor K1 Black Cherry and 1 Raptor K1 Red Cherry , Compag MX 11800  tBrown Cherry, G80-3000 Clear Cherry , G80-1000 Blue Cherry / Ghetto red, Lexmark 1992 SSK Buckling spring, Unicomp 2011 Customizer 102 Buckling spring
and a few rubber dome/scissors keyboards from Apple/Logitech
Offline db_Iodine
« Reply #15 on: Wed, 16 March 2011, 10:57:24 »
Quote from: ripster;312669
Ah OK, thanks for clarifying that.
I'm still curious if KBC is a real company or just 3 guys placing bulk orders and assembling keyboards in their kitchen.
Probably a real company of three employees assembling keyboards in their kitchen.
[SIGPIC][/SIGPIC]
Offline bl1978
« Reply #16 on: Wed, 16 March 2011, 10:59:25 »
I understand
 But unfortunately the are. This is just a plastic model of the sample
 If you want to sell the price will be quite expensive
 I do not have the intention to sell
 I just want to design my own convenience of a portable and can be incorporated wire frame
Offline laden3
« Reply #17 on: Wed, 16 March 2011, 11:46:39 »
Sounds more like das (especially "3 guys"), minus the "assembling keyboards in their kitchen".
I rrrove brrracks.
Offline noodles256
  • le legendary
« Reply #18 on: Wed, 16 March 2011, 11:51:46 »
This mod is so sick.
AF | Ducky YOTD |
Offline reaper
« Reply #19 on: Wed, 16 March 2011, 12:05:04 »
At least it's in their kitchen..  lol
or is it? O.o
Din Eli
Offline hansmuff
« Reply #20 on: Wed, 16 March 2011, 12:09:46 »
First off, thank you for sharing your ideas!
I do have a suggestion: I think it would make sense to have the USB connection recessed in the housing. It looks like the port is subject to damage when there is unintentional strain on the cable, or the keyboard falls.
It would be nice if the port was recessed and the cable could "lock in" on a plastic tab so strain/drop would not damage cable or port.
Offline RiGS
« Reply #21 on: Wed, 16 March 2011, 13:25:54 »
This is freaking awesome.
You should consider selling it.
Offline guilleguillaume
« Reply #22 on: Wed, 16 March 2011, 13:44:02 »
Quote from: RiGS;312751
I'm pretty sure a lot of people will buy it.
I think it's just an awesome work.
Offline suntorytime
« Reply #23 on: Wed, 16 March 2011, 17:44:32 »
I think the expense is high because it is made from 3d CNC instead of plastic injection molding. It's possible for users to do something similar by drawing a CAD or 3d render and submitting it to a nearby industrial workshop with a CNC machine.
It's an excellent design, really dig the USB cable compartment.
I'm excited to see what other mods come out from hobbyists separate from KBC.
Edit: Oh yeah, good work on doing the cable routing channels right. Not even the engineers who designed the Topre 103 could figure out how to get a middle cable routing channel. *tongue in cheek*
« Last Edit: Wed, 16 March 2011, 18:30:52 by suntorytime »
Offline BucklingSpring
« Reply #24 on: Wed, 16 March 2011, 19:27:48 »
This is fantastic!!!!!!
Here's a constructive critic. What do you think of moving the USB plug from the FRONT to UNDER... Something like that:
I don't know what size/space constraint you have for the USB connector.
But if you can manage to put it somewhere under in the same compartment as the cable management area... This would make it cleaner and one step closer to the PERFECT keyboard :-)
I also suggest for durability to keep a regular size USB connector. Again, if you have the space to do it.
Great Job!
Boards I own, click ->
Offline bl1978
« Reply #25 on: Wed, 16 March 2011, 20:15:28 »
This is a good suggestion, I have thought about the various programs
 Make it more perfect.
 But I use the PCB ready KBC
 It can not be reached
Unless modified PCB board
Offline keyboardlover
« Reply #26 on: Wed, 16 March 2011, 20:20:43 »
Great mod Brian! I like it a lot.
« Reply #27 on: Wed, 16 March 2011, 21:00:11 »
Ok then...
I like your project. Very well thought!
Quote from: bl1978;312979
Offline spolia optima
« Reply #28 on: Wed, 16 March 2011, 23:23:24 »
This kicks so much ass.
Thank you.
keyboards!
Offline heedpantsnow
  • Old enough to know better
« Reply #29 on: Thu, 17 March 2011, 04:39:47 »
Wow, great mod!
I'm back.
Offline zaerst
« Reply #30 on: Thu, 17 March 2011, 13:29:16 »
Man would love to have one of those as well!
Offline Rally Man
« Reply #31 on: Thu, 17 March 2011, 14:23:48 »
You can use shapeways.com to upload your design and people can buy it.  The person can even select the material for the casing to be made out of (including metal!).
Might be something to think about since many people are interested in your design.
« Last Edit: Thu, 17 March 2011, 14:27:44 by Rally Man »
INPUT GEAR
Work: Logitech MX Revolution |
Filco "Hulk" Majestouch-2 Tactile Action NKR
Home: Razer Imperator | Filco "Doraemon" Majestouch-2 Tactile Action NKR
Want:  3DConnexion SpaceMouse Enterprise | Logitech MX Master
Offline quadibloc
  • Layout Fanatic
    • John Savard's Home Page
« Reply #32 on: Thu, 17 March 2011, 16:53:40 »
While I won't be able to take part in the group purchase, I still looked up the information about the keyboard. There seems to be one serious mistake in its layout.
The keyboard has only one Alt key, the left-hand Alt key.
There's a DIP switch setting to make the left-hand Windows key into a left-hand Fn key instead, but none to make the right-hand Windows key into a right-hand Alt key instead.
This is very important, because on some European keyboard layouts, the left-hand Alt key and the right-hand Alt key perform two different functions: the left-hand Alt is used normally for special functions in programs, while the right-hand Alt key is used for shifting into additional characters.
Offline ch_123
« Reply #33 on: Thu, 17 March 2011, 16:56:46 »
Yeah, this was one of the major gripes I had with the design when I tried it.
It could do with a dedicated Fn key to the right of the right Shift key, like the HHKB.
Offline RiGS
« Reply #34 on: Thu, 17 March 2011, 18:04:31 »
Quote from: quadibloc;313522
That's why I passed that group buy.
Offline enoy21
« Reply #35 on: Wed, 05 October 2011, 15:29:13 »
I don't know about the rest of you guys.....
But my instant thought when seeing this was a Rubberized Keyboard jacket like Most smart phones offer.
So basically an addon to the original Poker that is made of rubber ( Slip resistant and shock resistant ).    This would make it ideal for traveling with the USB cable management.  Make it in various colors and it's a quick custom option for people afraid to really get into the innards.
That's actually something that could be made for almost any board.   To you can add a color to the casing to match some scheme you have on your keys or surface log.
WASD 104 work
WASD 104 home
WASD 104 [not my style]
Filco MJ2 Ninja 87 [sold]
Offline hargon
« Reply #36 on: Wed, 05 October 2011, 15:48:57 »
Another one here, who would like to get this. In another color please, but then very much interested.
Hopefully something comes up in this direction!
Offline ishtob
« Reply #37 on: Wed, 05 October 2011, 16:01:16 »
i would love to see that done in aluminum CNC!
