Author Topic: Nice Aluminium caps  (Read 2961 times)
Offline RiGS
Nice Aluminium caps
« on: Sun, 20 March 2011, 07:52:53 »
I've just noticed these nice Aluminium keycaps on Taobao.
I'm sure Michael will help to get these.
He charges 5% of the item cost as commission, though commission must be a minimum of $5.
The price is approximately 8,5$/keycap.
Offline RiGS
Nice Aluminium caps
« Reply #1 on: Sun, 20 March 2011, 07:55:35 »
Better hurry!
Offline keyboardlover
Nice Aluminium caps
« Reply #2 on: Sun, 20 March 2011, 08:57:29 »
You should tell webwit about these.
Offline ashort
  • Hoosier Daddy
    • http://andrew.wingedwheel.net
Nice Aluminium caps
« Reply #3 on: Sun, 20 March 2011, 09:00:24 »
I don't know if I'd be able to resist ordering an etched set of these if they were available.
Andrew
{ KBC Poker - brown | Filco Majestouch - brown | Dell AT101W | Cherry G84-4100 }
Offline RiGS
Nice Aluminium caps
« Reply #4 on: Sun, 20 March 2011, 09:02:39 »
I posted it on KBDthority as well.
Nice Aluminium caps
« Reply #5 on: Sun, 20 March 2011, 09:03:52 »
KBDThority is what ripster calls it to make fun of it. You DO know it's really DeskThority right?
Offline RiGS
Nice Aluminium caps
« Reply #6 on: Sun, 20 March 2011, 09:07:54 »
Nope, I have never heard of that before.
woody
  •  Guest
Nice Aluminium caps
« Reply #7 on: Sun, 20 March 2011, 16:50:02 »
Keycaps must be loose or something. There is glue/silicone on the brown stem.
Offline Quest-
Nice Aluminium caps
« Reply #8 on: Sun, 20 March 2011, 17:15:39 »
I thought it was a miniature spiderman web o_O
Btw, doesn't this give an annoying cold feeling when typing on?
Edit: and i can imagine it changing the attenuation force also. because of the weight.
« Last Edit: Sun, 20 March 2011, 17:20:54 by Quest- »
[SIGPIC][/SIGPIC]
Offline Oqsy
Nice Aluminium caps
« Reply #9 on: Sun, 20 March 2011, 17:26:51 »
I do not approve of mystery goo on my stem.
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
Nice Aluminium caps
« Reply #10 on: Sun, 20 March 2011, 17:40:33 »
I thought it was just a tiny bit of saran wrap to help hold the key in place?
Offline Oqsy
Nice Aluminium caps
« Reply #11 on: Sun, 20 March 2011, 19:43:51 »
if you go to the page from the OP, it looks like instructions for installing them using scissors and clear tape... I'm assuming that's a bit of adhesive scraped off of the back of scotch tape, but it's more fun to pretend it's dirty asian bukkake sauce.
Offline Surly73
Nice Aluminium caps
« Reply #12 on: Mon, 21 March 2011, 09:49:46 »
Need printed versions of these in 103/104 kits to fit Topre switches.  Then a Realforce could be even more expensive.
Offline sixty
    • http://deskthority.net
Nice Aluminium caps
« Reply #13 on: Mon, 21 March 2011, 10:50:59 »
the strip of tape is there to avoid the metal directly having contact with the plastic. apparently in testing the stem slowly got grinded down from the metal having direct contact with the plastic stem.
Offline eugenius
Nice Aluminium caps
« Reply #14 on: Thu, 24 March 2011, 04:19:59 »
WTF, get your chinese caps right here, only 900$ for a keyboard!!! Hahahahaa hahaaaa! :) ;) :)
Cherry ErgoPlus MX5000 + MX5700 / IBM Model M
Offline phuzion
Nice Aluminium caps
« Reply #15 on: Thu, 24 March 2011, 11:06:48 »
Only $615 for a tenkeyless/87 key!  Or $430 for a Poker/61 key!
Keyboards Owned: Cherry G80-1800 - 3x Filco Majestouch-2 Tenkeyless NKR ASCII, Reds, Browns, and Blues - Dell L100
Offline digitalleftovers
Nice Aluminium caps
« Reply #16 on: Thu, 24 March 2011, 12:17:07 »
I would be curious how these would feel if they covered the typing area of a keyboard.  Aluminium is light, but not plastic light.  I have a feeling that there would be a counterweight effect on the acutation force.  Maybe more so with those titanium caps.
Perhaps they would be a clever way to make a lower net actuation force switch?
Keyboards:
Filco 104 MX Brown (Otaku) - FKBN104M/NPEK 黒い空
Ducky TKL MX Brown/Blue 80% (White) - 1087-F 白の空
KBC Poker MX Red with PBT Key Caps - PFCN6000
"Consumers use touch screens.  Producers use keyboards."
