Author Topic: COMPAQ mechanical board? IBM M color scheme on it  (Read 1911 times)
Offline kylexy
« on: Wed, 06 April 2011, 23:05:27 »
Hey fellows,new here,was COMPAQ's keyboard ever the grey / beige look of model M, was that mechanical? I seem to remember it different from all kbs ive had. Also it had no windows key and was in a fairly normal layout for a  keyboard of 1993 or whatever year. I liked the heavy touch to the space bar.  It made a clunk similar to a mx blue, in fact maybe im almost positive it had an mx blue 'or green' spacebar..... anybody know what I am referring to as I do not know?
Offline CurtisLeon
« Reply #1 on: Thu, 07 April 2011, 00:14:46 »
There were a few Compaqs from that time period that used Cherry Browns.
Currently Using
Space Invaders: NMB RTRT8255CW+
Black ALPS: Dell AT101W
Foam & Foil: BTC 5339SX
In Storage
White ALPS (complicated): Focus FK-2001, Reveal KB-7061 (Chicony rebrand), PC Concepts KB-7000 (Chicony rebrand)
Orange ALPS: Apple Extended Keyboard (modded to ghetto Blue ALPS)
Peerless: Fujitsu FKB4700
Foam & Foil: LR 69497 (unknown make, terminal keyboard)
Offline lzf929
« Reply #2 on: Thu, 07 April 2011, 00:18:08 »
that's a typical cherry thing to use heavier switch for space.
if a compact one, then mx 11800
« Last Edit: Thu, 07 April 2011, 00:51:57 by lzf929 »
Offline kylexy
« Reply #3 on: Thu, 07 April 2011, 00:24:26 »
doh@my pre-edited post, google is my friend. Yeah its standard layout like todays US ANSI 100 something but without the windows key.
I'll look at 1800 when I find it thanks :-)
« Last Edit: Thu, 07 April 2011, 00:27:53 by kylexy »
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #4 on: Thu, 07 April 2011, 13:31:52 »
Doesn't sound like a MX11800 then. Those would be too new anyway. The regular Compaq Extended keyboards with detachable SDL cable were Maxi-Switch rubber dome affairs, IIRC... or foam on foil capacitive? The wiki should know.
