Author Topic: Remapping Leopold Win/Alt in OS X  (Read 7967 times)
Offline mjacob
« on: Fri, 08 April 2011, 00:28:23 »
The first thing I do after plugging a new keyboard in is remap Opt to Cmd and Cmd to Opt in System Preferences > Keyboard > Modifier Keys. Well, for whatever reason, the settings aren't "taking" with this new Leopold keyboard.
Is anyone else having this problem? I'm gonna try to find a third-party key mapping tool to see if that does the trick...
Matt
Offline mjacob
« Reply #1 on: Fri, 08 April 2011, 00:38:14 »
Oddly enough, KeyRemap4MacBook was able to swap the keys successfully (use the "Swap Start (aka Command) and Alt keys on Windows keyboard" setting). I'm still curious to know if anyone else is having the same problem, or if it's just me (OS X 10.6.7, BTW).
Offline Chobopants
« Reply #2 on: Fri, 08 April 2011, 01:01:31 »
So I was confused at first when I did this as well. You have to make sure you select "USB Keyboard" when you do it from the dropdown. Mine kept selecting something saying "Razer Blah" for some reason I don't know.
Realforce 87UW 45g - Filco Blue 87 - Filco Linear R - Filco Brown 104
Offline dez
« Reply #3 on: Fri, 08 April 2011, 01:07:27 »
hi there, i am actually interested in getting a leopold keyboard for myself and am currently on mac os x. therefore i would like to know if besides the remapping issue, does the keyboard itself function well on the mac os x? thanks in advance.
Offline mjacob
« Reply #4 on: Fri, 08 April 2011, 01:18:14 »
I made sure (several times) that "USB Keyboard" was selected in the dropdown before I started changing the settings. I hit OK afterward. I even quit System Preferences and came back in, and it still didn't work.
Offline Chobopants
« Reply #5 on: Fri, 08 April 2011, 01:18:16 »
Yeah, it works just great on OS X no problems.
Offline mjacob
« Reply #6 on: Fri, 08 April 2011, 01:20:39 »
Quote from: dez;326579
No other problems so far. The "Scroll Lock" key doesn't light up for obvious reasons, but other than that, it works just fine.
Offline dez
« Reply #7 on: Fri, 08 April 2011, 02:41:51 »
thanks for the input guys, however i am now stuck between getting the filco or the leopold blue tenkeyless.
Offline Chobopants
« Reply #8 on: Fri, 08 April 2011, 10:35:01 »
Quote from: dez;326598
Filco is overall a nicer board to be honest. My Leopold is back in the box until I get new keys and some lithium grease to fix those stabilizers.
(also yay, 200 posts. :)
Offline mjacob
« Reply #9 on: Sun, 10 April 2011, 23:23:48 »
The plot thickens. When I unplugged the keyboard from my USB hub and plugged it directly into the computer, the built-in key mapping started working properly. Very strange.
I've never had a problem with any other device plugged into this hub, and I've never had a problem swapping the keys of any other USB keyboard plugged into this hub. Very, very odd.
Offline kamui
« Reply #10 on: Wed, 20 April 2011, 10:14:00 »
I'm having this exact same issue. When I put my MacBook Air to sleep it seems to forget the modifier key changes I made when it wakes up. Sometimes even unplugging and replugging it in doesn't do the trick. Sometimes I just reboot to fix it. KeyRemap works, but it also swaps my built in keyboard and when I'm mobile that's just annoying.
