Author Topic: Cherry MX "Ergo" Clears  (Read 269941 times)
Offline The Solutor
« Reply #50 on: Fri, 08 July 2011, 08:07:00 »
hahaha
Offline The Solutor
« Reply #51 on: Fri, 08 July 2011, 08:10:20 »
Quote from: keyboardlover;376087
Panda clears is an awesome name.
Tactoblacks...:painkiller:
Offline RickyJ
« Reply #52 on: Sun, 24 July 2011, 15:26:24 »
Just finished swapping clear stems into my keypad (had blues).  Cleaned off the tactile bumps before adding a tiny dab of white lithium grease to each leg.  With the lighter spring it really feels like the keys want to get stuck on the way back up, but it also feels like that eases up with use (in the last 5 minutes anyways).  I'll give it more time before I form my opinion, but initial impressions weren't great.
Currently GMMK Pro: lubed 68g U4T, FR4 plate, extra gaskets, etc
Offline The Solutor
« Reply #53 on: Sun, 24 July 2011, 15:40:48 »
Quote from: RickyJ;386321
If the switches are brand new, you should wait one or two week depending (on the keyboard usage) to give a little burn in to the stems.
It's also statistically normal that a couple of stems over 100 are too tactile or even prone to stick, in that case just replace them
Offline RickyJ
« Reply #54 on: Mon, 25 July 2011, 00:25:37 »
The stems are from a G80 POS board that was in quite good condition, I didn't notice any inconsistent switches during the 1.5 months I used the board.  It's not that the switches stick down at all, they just feel like they want to rest in the tactile valley instead of bouncing right back up like my browns.  They feel chunky even when pressing keys quickly. :/
Offline wompwomp
« Reply #55 on: Sun, 31 July 2011, 20:17:16 »
Wait a minute, what's wrong with the stock springs?
Online Findecanor
« Reply #56 on: Mon, 01 August 2011, 09:33:19 »
So ... let me see if I have got this right:
1. Original Cherry Clear springs are stiffer than Cherry Black springs?
2. Cherry Clear stem + Cherry Black spring = Panda Clear switch.
A Panda Clear switch is softer how?
1. Is the initial resistance changed?
2. Is the tactile feel changed?
3. Is the landing after actuation softer?
Not too long ago, I was almost about to buy a keyboard with Panda Clears but the seller told me that the switches were stiffer than original Clears. How can they be?
I can imagine that the tactile bump would feel like it is larger in relation to the spring's stiffness.. but that is all.
Offline keyboardlover
« Reply #57 on: Mon, 01 August 2011, 10:09:26 »
The seller was BSing you. IMHO, panda clears feel much like a tactile black. Not my cup of tea but they're pretty nice.
Offline The Solutor
« Reply #58 on: Mon, 01 August 2011, 11:24:49 »
Quote from: dux;376027
Why do you think Panda Clears would be better than standard clears against bottoming?
Panda clears, like panda blue doesn't exist so hardly they bottom out.
« Reply #59 on: Mon, 01 August 2011, 12:07:35 »
Quote from: ripster;390949
What isn't a Panda Clear?
Fixed for you.
« Reply #60 on: Mon, 01 August 2011, 13:30:48 »
Tacto black is very descriptive but doesn't make much sense since its a clear stem. Panda clear is simply another title I came up with for the same switch (clear stem + black spring).
Offline The Solutor
« Reply #61 on: Mon, 01 August 2011, 13:37:33 »
Quote from: keyboardlover;391042
The panda itself is a white animal with black patches or a black one with white patches ?
Same problem here, a panda clear could be a black stem with the clear spring or viceversa...
Offline The Solutor
« Reply #62 on: Mon, 01 August 2011, 13:44:37 »
Quote from: ripster;391051
It's also endangered and has difficulty with reproduction.
Yeah, I tried a panda clear the the autorepeat function stopped working :D
Offline greyhounds
« Reply #63 on: Sat, 27 August 2011, 13:14:10 »
The spring rate of the clear spring is higher than that of the black spring. They provide the same amount of force at 2mm travel. Due to the spring rate difference, the clear spring requires lower force below 2mm and higher force above 2mm than the black spring does.
If you are looking to minimize the amount of work required to trigger the switch, but maximize the resistance of the spring before the bottoming out point (to reduce bottoming impact), the clear spring would be a good choice.
I've got curves plotted on my machine at work for each spring on a black stem (and forpretty much any other combination you can think of), and it shows the difference between the two springs very clearly. I'll try to remember to post that here Monday.
Offline greyhounds
« Reply #64 on: Sun, 28 August 2011, 13:32:23 »
That's something I hadn't considered.
I can use a Ripometer, dial indicator, and some clear springs to determine the exact spring rate of the clear springs. That'll get us alot closer to a true profile for the clear switches. At least we'll know exactly what happens above 2mm travel.
I'll also try to plot a few points on the cam of the Clear switch as well to verify it (ie, <2mm travel). It may be that I just need to take the published Clear switch curve, subtract out the spring they claimed it to have, and substitute in the actual spring values based on my tests.
All my junk is at work though so it'll have to be next week some time.
Offline greyhounds
« Reply #65 on: Mon, 29 August 2011, 12:51:38 »
Here's the plot of a standard black switch compared to a black stem with clear spring. This is based on the published curve data though, so I'll revise this once I've tested the clear spring. Hope this comes out OK as I haven't tried to upload files/pics before.
[ Guests cannot view attachments ] 25285[/ATTACH]
Offline The Solutor
« Reply #66 on: Mon, 29 August 2011, 13:36:48 »
Quote from: greyhounds;406940
(Attachment Link) 25285[/ATTACH]
Makes sense
Offline greyhounds
« Reply #67 on: Thu, 01 September 2011, 12:58:30 »
Ripster, you were right. The clear springs are much closer to the published black spring chart then they are to the clear spring chart.
The force measurements I just took from the clear springs are:
4.2mm = 85g
2.8mm = 71g
Both of these are taken beyond 2mm travel, so just the spring is in play regardless of the stem (well, except maybe blues, but I had browns here). If you compare these to the black chart, you can see they are almost dead on. Crazy.
So for all practical purposes it looks like clear springs are functionally the same as black springs. That's sad though - I'd really like something with a faster rate like the clear spring is supposed to have had.
Offline Lanx
« Reply #68 on: Thu, 01 September 2011, 14:45:25 »
Quote from: RickyJ;386594
it felt this way to me as well since i've been typing on browns for maybe a year? you'll get used to it lol, i actually have one half of my board ergo clears and browns (1 cuz i wanted to see the difference, 2 i stopped midway cuz i wanted to finish another mod), and you can really tell the difference.
Offline itlnstln
« Reply #69 on: Thu, 01 September 2011, 14:48:12 »
Quote from: Lanx;408935
I concur.  Clears with too light of a spring tend to feel "sticky."
Offline domin8r
« Reply #70 on: Sat, 03 September 2011, 13:17:02 »
Converted my old G80-1000 from blacks to panda clears last night.. And I have to say I really, really like it! :D
I got the stems from BiNiaRiS and he had also added the clear springs as a bonus but after trying it for a bit I much prefer the black springs compared to those.
Still willing to try Ergo-clears but for now loving this!
(Not sure if I like this more than blues, will have to try it for a bit I guess)
Compaq MX-11800, Ergo Clear/Brown/Ghetto Red
Ducky 1087XM
Laser SX-25 , White SMK
Black Dell AT101W
IBM Model M 1390120 (\'86)
Cherry G80-1000, Panda Clears
Offline N8N
« Reply #71 on: Sat, 03 September 2011, 13:53:00 »
could you describe the difference you feel between the black and clear springs?  I thought they were supposed to be very similar.  I actually have some blacks but I think they're sold, and I have too many other projects going at the moment.
Offline domin8r
« Reply #72 on: Sat, 03 September 2011, 15:41:02 »
Quote from: N8N;410017
Well I visually compared the springs from the black and the clear and they are definitely different!
It's a bit hard to describe but to me the clear stem + clear spring felt heavier/less smooth. That also made it feel less tactile (if that makes sense).
I only tried it with a few switches to compare.. so I haven't fully typed on it, not sure if that would make a difference.
Ducky 1087XM
Black Dell AT101W
Offline The Solutor
« Reply #73 on: Sat, 03 September 2011, 16:06:47 »
They are similar but the difference is perceptible, black spring is stiffer in the first piece of the keystroke, clears are stiffer at the end of the keystroke.
Offline N8N
« Reply #74 on: Sat, 03 September 2011, 21:14:44 »
Quote from: The Solutor;410090
hmm, if that is the case then it's probably not worth it to me to try the experiment, because that is really what i like about the clears, the way they get noticeably stiffer after the tactile point without feeling artificial like the o-rings.  If that makes any sense whatsoever...
« Reply #75 on: Sat, 03 September 2011, 21:35:07 »
I didn't find them to feel very similar at all. I found Tacto (Panda) Clears to feel mostly like a black switch with a tactile bump.
« Reply #76 on: Sat, 03 September 2011, 21:45:16 »
10g more is a BIG difference in feel.
Offline The Solutor
« Reply #77 on: Sat, 03 September 2011, 21:58:05 »
Quote from: ripster;410220
Hmmm... I didn't feel that but The Solutor and I always disagree.  It's remarkable how similar a Tactoclear and a Cherry Clear are.
Tactoblack
BTW
I think this graph posted earlier is pretty close to the truth
the difference can be felt more on cyan switches vs blues + black spring (feel free to found a name for them, night blue, dark blue, inter switches, whatever).
Cyan are pretty nice.
« Reply #78 on: Sun, 04 September 2011, 06:36:00 »
Yea - I meant in comparison to an ergo clear (blue/brown/red) spring - not in comparison to a standard clear switch.
Weren't you saying the two felt remarkably similar?
Offline RickyJ
« Reply #79 on: Sun, 04 September 2011, 13:26:16 »
Just redid this mod using broken-in clear switches instead of brand new blue switches, night-and-day difference.  I'll give it more time, my cheapo Adesso keypad isn't the best demo unit.
Offline domin8r
« Reply #80 on: Fri, 09 September 2011, 09:07:31 »
For some reason I always think of browns when I see the term tactile.. I wouldn't know I would guess Tacto Black would be black springs with brown stems..
Ducky 1087XM
Black Dell AT101W
Offline litster
  • rare caps?! THAT'S A SMILIN
« Reply #81 on: Fri, 09 September 2011, 11:19:29 »
I do like the panda clear name, because it gives me a visual cue in my head that it is white and black.  Where as tacto black makes me do 2 conversions in my head: something in this switch is black (spring or stem?), tacto here is ... hum, white, so the black is hum, ah the spring.  I have to go through that thought process every time :-).
Panda clear works better for me.
Offline litster
« Reply #82 on: Fri, 09 September 2011, 11:31:47 »
Panda clear sounds girly though.
Offline The Solutor
« Reply #83 on: Fri, 09 September 2011, 12:28:33 »
Quote from: domin8r;413260
For some the reason when i see the term tactile, I think to anything but the brown switches.
Maybe it's because they are the less tactile thing on the universe ? :confused:
Offline The Solutor
« Reply #84 on: Fri, 09 September 2011, 12:34:35 »
Quote from: ripster;413362
It's because you haven't tried a real linear until you've tried the Cherry Red switch.
Captain obvious, actually I have two linear boards. I was talking about the tactile switch world...
« Last Edit: Tue, 13 September 2011, 15:29:57 by The Solutor »
Offline The Solutor
« Reply #85 on: Tue, 13 September 2011, 15:29:10 »
Quote from: ripster;413368
Are you a Wizard?
(Attachment Link) 26210[/ATTACH]
No, just the humble MacGyver's teacher :becky:
Offline The Solutor
« Reply #86 on: Tue, 13 September 2011, 15:42:40 »
Quote from: ripster;415647
I stuck these in the Cherry MX wiki as "Ergo Clears".
I left the Black Spring/Clear Stem mod as "Tacto Clears AND Panda Clears".
Tacto BLACK
BTW feel free to change your mind about the switch name, btw then I will feel free to call the ergo clears with their logical name, "beige".
« Reply #87 on: Tue, 13 September 2011, 17:02:07 »
Panda clears won. I know this because it's on my website.
Offline Lanx
« Reply #88 on: Wed, 14 September 2011, 17:52:43 »
modded a whole board to ergo clears, feels good and with the kinesis sound too. well the sound is getting annoying.
« Reply #89 on: Wed, 14 September 2011, 17:53:43 »
Nice!!
Offline ishtob
« Reply #90 on: Fri, 04 November 2011, 20:01:16 »
my modded poker's got ergo clears, and i love it :)
Offline domin8r
« Reply #91 on: Sat, 05 November 2011, 03:13:53 »
Modded my Compaq MX-11800 to a bit of a mix. Have a all the regular keys modded to ergo clears, the arrow keys to ghetto reds and the rest I left brown (don't care about the tactile feedback of my functions keys and such)
Gotta say the difference between panda clears and ergo clears is really noticeable! I think I prefer the ergo clears.. but the panda clears come in a close second :)
Ducky 1087XM
Black Dell AT101W
« Reply #92 on: Sat, 05 November 2011, 10:14:58 »
Glad you like them! Be sure to vote here.
fossala
  •  Guest
« Reply #93 on: Sat, 05 November 2011, 15:20:07 »
I have been playing with ergo clears on my poker. I like them but I prefer strait clears.
Offline domin8r
« Reply #94 on: Tue, 08 November 2011, 04:03:17 »
After using my panda clears again for a few days it's still hard to pick the best clear setup.. I love the "bounciness" of panda clears but the ergo clears feel more tactile and light..
Ducky 1087XM
Black Dell AT101W
fossala
  •  Guest
« Reply #95 on: Tue, 08 November 2011, 04:13:00 »
I just found ergos a bit sticky. But I also like a heavier switch.
Offline domin8r
« Reply #96 on: Tue, 08 November 2011, 04:15:38 »
Quote from: fossala;447900
I've found that the keycaps make quite a difference too.. the ergos felt a lot better when I fitted heavy cherry keycaps instead of the flimsy default MX11800 keycaps!
Ducky 1087XM
Black Dell AT101W
Offline Roguemaster8
« Reply #97 on: Fri, 13 April 2012, 11:33:28 »
Just got a Poker with ergo clears, these are definitely a superior switch.
Tactile as hell, but not obnoxiously clicky.
CM Storm Quickfire | Dell Quietkey | Unicomp Ultra Classic | KBC Poker
« Reply #98 on: Fri, 13 April 2012, 14:01:02 »
Glad you like 'em! I've been typing on mine for the last couple months now. Love 'em.
