Author Topic: iASUS NT3 Evolution  (Read 2725 times)
Offline redpill
iASUS NT3 Evolution
« on: Sun, 08 May 2011, 18:56:27 »
Recently got one of these throat mics for dual use in gaming (cool factor) and in the car (engine roar), available with attachments for both PCs and cell phones.  Very cool concept, and works well, I do get occasional complaints about sounding muffled but otherwise decipherable.  Definitely better in the car, where a regular mic gets a ton of background noise.
For those not familiar with how they work, the microphones pic up vibrations directly from your voice box around your neck.  Initially designed for military use, they now sell them commercially.
^ Current Favorite ^  Topre Realforce 87UB 55g  |  Topre Realforce 103UB 55g | KBC Poker/Browns/Sanded KeycapsDucky 1087 | Filco MajesFoam-2 | IBM Model M 1390131 Feb '87 | Still Love: Microsoft Trackball Explorer x3 | Now Unused:  Microsoft Natural Ergo 4k x2
Offline HaveANiceDay
iASUS NT3 Evolution
« Reply #1 on: Mon, 09 May 2011, 22:06:04 »
That is weird. Do you sound like a robot trough that?
Filco Tenkeyless Brown with beige cherry doubleshots (home)
Realforce 86U (work)
Get you own Phantom NAO!
Offline Arc'xer
iASUS NT3 Evolution
« Reply #2 on: Mon, 09 May 2011, 22:30:20 »
Quote from: HaveANiceDay;344161
You'll actually sound pretty much natural though depending on the quality of the mic; they are used in high-noise(aircraft, tanks, combat) or you can whisper in low-noise required environments.
Offline redpill
iASUS NT3 Evolution
« Reply #3 on: Mon, 09 May 2011, 23:20:05 »
No, your voice comes through like normal, it's just the sharp consonants you make with your teeth and tongue are less pronounced.
Quote from: Arc'xer;344174
Well, not exactly whisper, because you have to create some vibration in your vocal cords, but you can talk very very softly while pressing the mics inwards for a low volume situation.
But typically at 8k RPMs with windows down I'm not so worried about how loud I'm talking, just that they can hear me!
On a geek note, the cables on these are really sweet, very high quality, flexible, fabric wrapped, non-binding sort of sheath.  It's almost like I'm on Seal Team 6 bringing it to Bin Later.
The earpiece is also a tube, so you don't have to cram an actual mini-speaker in your ear like typical in-ear headsets.  It's way more comfortable, but obviously not for music and such.
« Last Edit: Mon, 09 May 2011, 23:25:45 by redpill »
