Author Topic: Bought a legit mechanical keyboard tonight, tell me how I did.  (Read 4788 times)
Offline benis
It was $2.99 at Value Village.
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
Offline benis
« Reply #1 on: Mon, 09 May 2011, 22:00:31 »
[/URL][/IMG]
[/URL][/IMG]
Offline HaveANiceDay
« Reply #2 on: Mon, 09 May 2011, 22:13:27 »
Not so sure, but the caps look pad printed. They have the "aura" around the legends.
Other than that, they look really solid. Not even Hulk could flex those!
They look MX compatible.
I have no idea what the switch is.
Filco Tenkeyless Brown with beige cherry doubleshots (home)
Realforce 86U (work)
Get you own Phantom NAO!
Offline DeltaGunner
« Reply #3 on: Tue, 10 May 2011, 00:07:44 »
Dont know what switch it is too but it looks Cherry MX compatible as HaveANiceDay already said.
It also looks like the spring under the keycap is the only spring(?), when it pushes the keycap up the switch goes up with it.
Just a speculation.
[SIGPIC][/SIGPIC]
Keyboards:
Razer BlackWidow Ultimate
Wishlist:
DAS Ultimate Model S Ultimate Silent, or atleast some other Cherry Brown
Mice:
Logitech Trackball
Logitech Trackman Wheel
CM Storm Sentinel Advance 5.600 DPI
Switches:
Blue
Want to try:
Black, Brown, Red and BS
Offline redpill
« Reply #4 on: Tue, 10 May 2011, 00:21:45 »
No idea, but Google tells me Schuyler County NY disposed of one as surplus in 1997.  So it's not even good enough for government work.
http://www.schuylercounty.us/Minutes1997.htm
In a more relevant search return, there's one for sale on e-bay ( http://cgi.ebay.com/Keyboard-BTC-Professional-5339-Vintage-Style-/350359835372 ) that describes the keys as having "white X style plungers or sliders" which isn't very descriptive.
But from what I've seen in my brief time on this board, chances are good that ripster has one in the closet.
Edit:  just found a geekhack post that mentions BTC but the switches sound different and it was made in Taiwan http://geekhack.org/showthread.php?14183-First-post-found-keyboard...
^ Current Favorite ^  Topre Realforce 87UB 55g  |  Topre Realforce 103UB 55g | KBC Poker/Browns/Sanded KeycapsDucky 1087 | Filco MajesFoam-2 | IBM Model M 1390131 Feb '87 | Still Love: Microsoft Trackball Explorer x3 | Now Unused:  Microsoft Natural Ergo 4k x2
Offline redpill
« Reply #5 on: Tue, 10 May 2011, 00:35:20 »
Quote from: ripster;344227
BTC Foil over foam capacitive.
But do you have one in your closet????
Offline What is X?
« Reply #6 on: Tue, 10 May 2011, 00:58:08 »
that does not look MX compatible. Edges are too sloped.
Offline RickyJ
« Reply #7 on: Tue, 10 May 2011, 01:17:13 »
I've got one of those in hiding, foil over foam just like Ripster said.  Feels worse than the board I've got with linear green Alps switches. :o
Currently GMMK Pro: lubed 68g U4T, FR4 plate, extra gaskets, etc
Offline the_buff
« Reply #8 on: Tue, 10 May 2011, 02:10:28 »
But hey--for only $2.99, and keys that might fit Cherry MX switches, not a bad first outing.  Let the obsession begin.
Offline Dox
« Reply #9 on: Tue, 10 May 2011, 06:23:37 »
The keycaps are cherry compatible. I got a btc from 1988 with double shot keycaps and they fits cherry mx switches just fine.
ErgoDox x2 | DoxKB x2 |   IBM SSK   | HHKB pro2
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #10 on: Tue, 10 May 2011, 06:56:42 »
Not meaning to sound like a broken record, but here on the interwebs, keeping image sizes at a moderate level is usually appreciated. Something like 100..200K per image tends to be fine (typically that's what you get with about 1024x768 and a decent JPEG quality setting like 90).
BTC foam and foil jobs are not the very most popular since the feel is kinda meh, but they do sport NKRO, which can be handy in certain applications (e.g. music input).
Offline digitalleftovers
« Reply #11 on: Tue, 10 May 2011, 17:59:56 »
Quote from: keyb_gr;344311
I'm viewing this page on 45Mb Fiber (Synchronous), but yes, It annoys me too whenever I'm trying to browse from my phone.  I don't blame the OP, some sites auto-resize.  Depending on user input, I think its worth suggesting to iMav that there be a smaller image size cap.
Keyboards:
Filco 104 MX Brown (Otaku) - FKBN104M/NPEK 黒い空
Ducky TKL MX Brown/Blue 80% (White) - 1087-F 白の空
KBC Poker MX Red with PBT Key Caps - PFCN6000
"Consumers use touch screens.  Producers use keyboards."
Offline benis
« Reply #12 on: Tue, 10 May 2011, 21:14:45 »
thanks for all the tips guys, and sorry about the large pics. Anyone know where I can get an adapter to ps2?
Offline RickyJ
« Reply #13 on: Tue, 10 May 2011, 23:45:18 »
Check for markings to see if it's compatible with AT communication protocol, the older XT protocol is missing bits.  XT/AT switch is good indication, check the label to see what it says too.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #14 on: Wed, 11 May 2011, 16:48:16 »
i have a btc that i first thought was a mechanical, it has clear mx compatible plungers with a spring, but underneath it turned out to be just rubber domes. very sneaky.
Offline Ascaii
« Reply #15 on: Wed, 11 May 2011, 16:50:04 »
hit me up with a pm...i have another 20 or so at-ps2 adapters here
