Author Topic: Suggestions for a full-size Cherry Brown keyboard  (Read 2270 times)
Offline wfaulk
« on: Tue, 17 May 2011, 08:15:59 »
All of my current keyboards are too clicky for my new job.  I was going to go buy a Filco, but I see that Elitekeyboards no longer sells them, and the Leopold replacements aren't available with a numpad.
Can anyone suggest a good Cherry Brown keyboard currently available in the US?
Offline wfaulk
« Reply #2 on: Tue, 17 May 2011, 08:36:30 »
I could swear that I looked at that last night and it wasn't available.  On order.  Thanks!
Offline elef
« Reply #3 on: Tue, 17 May 2011, 08:54:25 »
The filco is pretty loud, though. Quieter than a pcb mounted keyboard with blues, but, if you bottom out hard, it's not much quieter.
For somebody who is not used to mechanical keyboards (i.e. the coworkers), it's a hell of a loud keyboard. I much prefer plate mounted keyboards and love my brown filco to death, but if you bottom out and low noise is a high priority, get a pcb mounted board. If you don't bottom out, you can probably get away with a filco.
Offline wfaulk
« Reply #4 on: Tue, 17 May 2011, 10:37:17 »
Hm, that's a good point.  I don't bottom out hard, but it might still be a concern.  Can anyone recommend a quality PCB-mounted Cherry Brown that is, again, currently available in the US?
Offline pitashen
« Reply #5 on: Tue, 17 May 2011, 10:45:59 »
Quote from: wfaulk;347501
Cherry.
You will eventually learn not to bottom out. Especially if you are under the pressure of keeping it down.
Offline wfaulk
« Reply #6 on: Tue, 31 May 2011, 13:54:59 »
Okay, I got my Cherry Brown Filco in and I'm not exactly thrilled with it.  I should have done a little more research first, but I didn't realize how slight the tactility of the keys is; I was thinking it was just a Blue minus the shuttle on the key peg, but that's apparently not the case, and the Clear is closer to that.
First, am I correct in that assessment?
Second, if so, is there a Cherry Clear currently available in the US?
Offline ZRock
« Reply #7 on: Tue, 31 May 2011, 14:12:25 »
The deck ice has a board with clears on it IIRC.
