Author Topic: HHKBP2 spacebar VS Realforce spacebar: sound  (Read 3676 times)
Offline Mazora
« on: Mon, 06 June 2011, 15:49:12 »
my HHKB2 is very silent except for the very annoying TIC of the spacebar (stabilizer?).
Anyone know  if its the same on a Realforce ? I was going to buy a realforce but I'll reconsider if its not fixing this issue.
Tks in advance,
Misery
HHKB Pro 2: black case white keys
Filco Masjestouch v2 / MX-Reds / hard lending pads /Dye-sub keycaps
RF-87UW
Offline hasu
  • @tmk
« Reply #1 on: Mon, 06 June 2011, 21:26:11 »
My Realforce 101's space bar seems to be a little quieter and smoother, but not so different.
While HHKB pro has a spring and Realfoce 101 not. I think your pro2 has it too.
I found displacement of the spring causes very annoy sound. To remove or reinstall the spring might improve your problem.
Give it a try.
Offline reaper
« Reply #2 on: Mon, 06 June 2011, 23:08:32 »
This question might also benefit OP..  Is there any special instuction we should know when removing either HHKB or 87ub spacebar?  I mean I've removed both Filco and Ducky spacebar without any issue (thanks to ripster's guide).  Is it different with the Topre?
Din Eli
Offline hasu
  • @tmk
« Reply #3 on: Tue, 07 June 2011, 00:39:14 »
My 101 is a cheap secondhand with some damage, so previous owner might have lost a spring.
[ Attachment Invalid Or Does Not Exist ] 18938[/ATTACH]
How to remove space bar:
In my case, just pull *gently* each side of bar to unlock stabilizer(do not both at the same time),
then pull middle part like normal key. Easy.
Easy but not always :) This is a horror for Realforce owners.
[ Attachment Invalid Or Does Not Exist ] 18939[/ATTACH]
Offline reaper
« Reply #4 on: Tue, 07 June 2011, 00:42:19 »
^ Cool.  Thanks hasu.  That helps a lot.  Yikes on that second pic tho. lol
Din Eli
Offline chongyixiong
« Reply #5 on: Tue, 07 June 2011, 01:12:43 »
Quote from: hasu;356620
(Attachment Link) 18938[/ATTACH]
(Attachment Link) 18939[/ATTACH]
Ouch, how did that happen?
Offline noodles256
  • le legendary
« Reply #6 on: Tue, 07 June 2011, 08:41:42 »
ill trade you my topre for your hhkb
if it is wwhite
AF | Ducky YOTD |
Offline Mazora
« Reply #7 on: Wed, 08 June 2011, 09:11:29 »
its black on gray, very bad choice i know
RF-87UW
