Author Topic: Leather wrist rest picks: Filco or 3-Star?  (Read 6812 times)
Offline Engine
« on: Fri, 24 June 2011, 16:23:27 »
Here are the picks for leather wrist rests:
1. Filco:  http://www.keyboardco.com/keyboard_details.asp?PRODUCT=635
This one is poly-coated.
2. "3-Star":  http://elitekeyboards.com/products.php?sub=access,palm_rests&pid=hm_prlb
This one is just all leather and no coating.
They both seem high quality.  The Filco is less money than the 3-Star but is poly-coated and I'm not sure if that is good or not.  Should leather be coated?  I thought leather was supposed to breath?  Also, I wouldn't think it would be as nice to work on as the non-coated "3-Star.
Does anyone have either of these and can give their findings or facts on this?
I'm trying to committ to one or the other and at the price tag of either, I need some user inside info because I'm ready to buy this weekend.
« Last Edit: Fri, 24 June 2011, 16:25:47 by Engine »
In order of purchase:
Unicomp Space Saver(Black) - Topre Realforce 103U-UW -   Topre Realforce 103UB - Leopold Tenkeyless MX Blue - Leopold Tenkeyless MX Brown - Filco Majestouch 2 MX Blue - Filco Majestouch 2 MX Brown
Offline reaper
« Reply #1 on: Fri, 24 June 2011, 16:29:14 »
nvm.
« Last Edit: Fri, 24 June 2011, 16:52:26 by reaper »
Din Eli
Offline Engine
« Reply #2 on: Fri, 24 June 2011, 16:45:50 »
I need to know the difference before I buy.  I prefer the lower price of Filco but think the leather "experience" of the 3-Star maybe superior.  I'm looking for folk's input before I spend the money.
« Last Edit: Fri, 24 June 2011, 16:48:10 by Engine »
Offline reaper
« Reply #3 on: Fri, 24 June 2011, 16:51:11 »
Quote from: Engine;367290
No problem.  Was just trying to save you some money and FWIW, I tried both and like Filco one better since it's a little thinner and has better grip.  Couldn't tell the difference between the coating. To each his own though, might not be for everyone.
« Last Edit: Fri, 24 June 2011, 17:08:10 by reaper »
Din Eli
Offline redpill
« Reply #4 on: Fri, 24 June 2011, 16:54:05 »
I have a hard time spending $70+ on a wrist rest.  Have you tried the 3M gel-filled kind?
^ Current Favorite ^  Topre Realforce 87UB 55g  |  Topre Realforce 103UB 55g | KBC Poker/Browns/Sanded Keycaps |  Ducky 1087 | Filco MajesFoam-2 | IBM Model M 1390131 Feb '87 | Still Love: Microsoft Trackball Explorer x3 | Now Unused:  Microsoft Natural Ergo 4k x2
Offline ~Blood~
« Reply #5 on: Fri, 24 June 2011, 17:07:19 »
The leather is died with a vegetable tannin. Furthermore, from EK:
Once assembled the surface of
the leather is then treated with moisturizing/waterproofing product from
Italy called Noacqua and then finally the edge of the palm rest (at the
seam) is treated with a acrylic-based sealant for durability.
Real leather will get dirty quicker than fake leather, this is why it is often applied in VERY high quality headsets, I mean fake leather. Real leather is an option if you want it, but fake leather does better overall because its easier to care for.
So as always there is no best thing. Touching and sweating into some plastic kind of thing an ultimately really badly tanned leather isn't the best thing one can do, and its probably poisonous to some degree.
Offline ~Blood~
« Reply #6 on: Fri, 24 June 2011, 17:53:58 »
which is usually PU coated leather that has been tanned with aggressive chemicals
which is not good!
Offline Engine
« Reply #7 on: Fri, 24 June 2011, 18:11:05 »
[video=youtube;dG5Qk-jB0D4]http://www.youtube.com/watch?v=dG5Qk-jB0D4[/video]
Is the non-PU model from EK tanned with nastiness?
"Is it safe?"
« Last Edit: Fri, 24 June 2011, 18:20:37 by Engine »
Offline calavera
« Reply #8 on: Fri, 24 June 2011, 18:19:21 »
I've been using the filco one for the past 4 years and it still looks pretty new. No signs of wear whatsoever.
woody
  •  Guest
« Reply #9 on: Sat, 25 June 2011, 09:31:24 »
Using Filco wristrests and happy. Long years before on gel pad with textile on top - was driving me nuts from sweating.
Funnily, the other day I saw a wristrest, which seemed to be filled with small pellet-like thingies, sewn into a sausage-shaped pouch. Tried it and found it very weird - your palms sink very quickly close to the surface level, and the feeling is funny, in the weird sense.
Offline heedpantsnow
  • Old enough to know better
« Reply #10 on: Sat, 25 June 2011, 13:13:54 »
Quote from: woody;367707
Yeah, I got one of those from office depot and hated it.  Glad they took it back.  Useless!
I'm back.
Offline Engine
« Reply #11 on: Sun, 26 June 2011, 00:25:24 »
I'm going with EK's 3-Star.  I neglected to consider the S/H on each.  Initially, The Keyboard Co is about $13 cheaper than EK but after adding carriage, EK ends up about $4 cheaper then The Keyboard Co.  It seems to be clear what to do.
THanks all for your replies/info.
