Author Topic: Cleaning lettering on 6gv2  (Read 6751 times)
Offline June
« on: Tue, 28 June 2011, 05:43:17 »
Hello,
I would like to know if I can clean the lettering on a steelseries 6Gv2.
It's looks like this (not mine but same problem. S, D letters) :
Tried some water but didn't work.
Thanks :smile:
Offline Philth
« Reply #1 on: Tue, 28 June 2011, 05:55:18 »
Do you mean just clean the keycaps or remove the white paint of the lettering?
Offline June
« Reply #2 on: Tue, 28 June 2011, 06:28:39 »
I mean cleaning the keycaps only. The letters are not as white than when I bought it even if I wash my hands before using my keyboard. :)
As you can see, S and D letters are more grey than the other letters.
Offline Alex
« Reply #3 on: Tue, 28 June 2011, 06:51:04 »
Quote from: June;369348
My WASD cluster looks worse than that on my SteelSeries 6gv2, it's not due to fingeroils, but wear on the keycaps. They seem to be pretty low quality.
Offline The Solutor
« Reply #4 on: Tue, 28 June 2011, 07:03:41 »
Use some ammonia based cleaners like Glassex (Windex if you are in the US) and a cloth.
If not enough try with hydrogen peroxide
Offline HaiiYaa
« Reply #5 on: Tue, 28 June 2011, 07:59:43 »
damp a cloth with some isopropryl alcohol and clean it with that
Offline HaiiYaa
« Reply #6 on: Tue, 28 June 2011, 08:02:07 »
yuck what is that layout? I feel like vomitting looking at that zqsd cluster
Offline Alex
« Reply #7 on: Tue, 28 June 2011, 08:06:07 »
Quote from: HaiiYaa;369375
AZERTY layout. French thing. I dig the page up and down buttons.
Offline Tony
« Reply #8 on: Tue, 28 June 2011, 09:42:52 »
For that very reason I now use Ninja keycaps.
The keycaps will be shiny after some months, but there will be no letter paint wearing.
Offline redpill
« Reply #9 on: Tue, 28 June 2011, 10:14:00 »
Are they just dirty or wearing off entirely?
^ Current Favorite ^  Topre Realforce 87UB 55g  |  Topre Realforce 103UB 55g | KBC Poker/Browns/Sanded Keycaps |  Ducky 1087 | Filco MajesFoam-2 | IBM Model M 1390131 Feb '87 | Still Love: Microsoft Trackball Explorer x3 | Now Unused:  Microsoft Natural Ergo 4k x2
Offline June
« Reply #10 on: Tue, 28 June 2011, 14:21:54 »
Alright thanks for advices. I don't really know what it is. I first tought it was dirt but even after cleaning the keyboard immediatly after use it doesn't seem to remove.
I'll try some of the products mentionned and if it doesn't work i'll buy some blank keycaps too.
