Author Topic: filc blue tenkeyless key prblem  (Read 2601 times)
Offline nrtdx
« on: Sun, 03 July 2011, 13:24:36 »
well as yu can see I cannt type the letter 0.
I mean WTF this bard is like 2 mnths lds isnt it suppsed t be 50millins keystrkes......................................................
**** this **** im pissed.
I can make the letter register if I type it mre than nce : oooooooooooooooo
When I hld the key it desnt repeat at all...
[SIGPIC][/SIGPIC]
mx red ¯\\_(ツ)_/¯
Offline Astounding
« Reply #1 on: Sun, 03 July 2011, 13:46:18 »
If it's only 2 months old, why not make use of your warranty?
Offline nrtdx
« Reply #2 on: Sun, 03 July 2011, 13:51:18 »
o o           o   o o       o    o o o o  o o o  o           o              o          o     o     o       o      o   o  o
p p p p p p p p p p p p p p p p p p p p p p p p p p p p p p p p p p p p p p p p p p p p p p p p p p p p p p p p
[SIGPIC][/SIGPIC]
mx red ¯\\_(ツ)_/¯
Offline noodles256
  • le legendary
« Reply #3 on: Sun, 03 July 2011, 14:07:00 »
op
AF | Ducky YOTD |
Offline False_Dmitry_II
« Reply #4 on: Sun, 03 July 2011, 14:16:12 »
I'm pretty sure those don't work for acronyms.
And that avatar and sig still weird me out.
« Reply #5 on: Sun, 03 July 2011, 14:20:04 »
No, it's because it is a giant picture instead of the text sig you used to have.
Why would I care where the pic is?
Offline substract
« Reply #6 on: Sun, 03 July 2011, 14:56:57 »
Same thing happened to the "c" on my rosewill.  It wouldn't come out unless I hit it multiple times.  Then I removed the cap to check the switch, put the cap back on and it wouldn't come out at all after that.
Offline Astounding
« Reply #7 on: Sun, 03 July 2011, 15:01:08 »
Offline nrtdx
« Reply #8 on: Sun, 03 July 2011, 16:32:24 »
I don't care about the stupid warranty. Things like that should not happen that soon with a filco (at least that's what i thought).
What's the point of buying expensive boards if they break that easy?
[SIGPIC][/SIGPIC]
mx red ¯\\_(ツ)_/¯
Offline Lester
« Reply #9 on: Sun, 03 July 2011, 16:50:21 »
Buy a ducky! Problem solved :)
Offline redpill
« Reply #10 on: Sun, 03 July 2011, 16:59:18 »
1) Remove the keycap and blow compressed air into the switch
2) If that doesn't work you could try lubricatant as well.
3) If it still doesn't work, use the warranty.
And no it shouldn't happen on a premium keyboard.  Did you even get a key puller with your Filco?  A lot of folks don't these days.  I guess Filco isn't what it used to be.
^ Current Favorite ^  Topre Realforce 87UB 55g  |  Topre Realforce 103UB 55g | KBC Poker/Browns/Sanded KeycapsDucky 1087 | Filco MajesFoam-2 | IBM Model M 1390131 Feb '87 | Still Love: Microsoft Trackball Explorer x3 | Now Unused:  Microsoft Natural Ergo 4k x2
Offline Tony
« Reply #11 on: Sun, 03 July 2011, 17:03:42 »
Quote from: nrtdx;372644
Ironically, that's what the warranty is all about. If everything were perfect, we would all be Gods by now, and Filco would be a Keyboard Paradise.
« Last Edit: Mon, 04 July 2011, 01:16:11 by Tony »
Offline Wallach
« Reply #12 on: Sun, 03 July 2011, 17:32:54 »
Hey, it seems like it works now.
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #13 on: Mon, 04 July 2011, 09:32:08 »
Typical bathtub curve behavior. Stuff mostly fails when it's either very new or very old.
That aside, resoldering the keyswitch in question is likely to fix this particular problem.
