Author Topic: Japanese Keyboards and JIS Layout, questions  (Read 14035 times)
Offline ~Blood~
« on: Mon, 11 July 2011, 17:47:31 »
Hi there
so I've been thinking and googling abit now, does the JIS layout serve a good purpose?
Do some of you have experience with it? I see that some retailers, including realforce, don't even print the kana lettering onto their keyboards anymore because most japanese people don't use it, is that correct?
Can you someone get along with IME although you have standard ISO/ANSI layouts?
Offline Tennobanzai
« Reply #1 on: Mon, 11 July 2011, 17:55:22 »
According to my Japanese friends and GF. The main purpose is the two keys by the spacebar. One switches between written languages and I think the other switches between auto suggestions. Not sure of the 2nd.
They all said they don't use the kana on the keycaps. They don't type feel either, it's just the romanji/english on the keycaps is all they need.
Offline ~Blood~
« Reply #2 on: Mon, 11 July 2011, 18:03:04 »
switch between auto suggestions?
so I see... is there a good solution for iso boards for swapping languages and stuff?
I'm kind of tempted to buy a topre, just not the JIS type. If I don't really need the kana lettering, because japanese people even don't, I'd rather have a large space bar.
Offline Tennobanzai
« Reply #3 on: Mon, 11 July 2011, 18:11:36 »
Quote from: ~Blood~;378409
I'm not exactly sure about the switch between auto suggestions.
Do you know Japanese? To be honest I hate the JIS layout.
Offline The Solutor
« Reply #4 on: Mon, 11 July 2011, 18:20:59 »
Quote from: ~Blood~;378400
Many keyboards are available in both versions like this two
Other than the shorter spacebar the latin layout is very nice, maybe even better than the ISO itself
Offline ~Blood~
« Reply #5 on: Tue, 12 July 2011, 04:49:06 »
still not sure if I would ever need the keys beside the space bar, someone wrote that you only need the language switch key which I could also use ALT GR for basically, i guess?
Offline hasu
  • @tmk
« Reply #6 on: Tue, 12 July 2011, 08:57:31 »
Many people including me write Japanese with ANSI keyboard here in Japan. No problem.
I'm not sure why you ask this. You need to write Japanese?
You can consult with Wikipedia if you want to know about Japanese input.
http://en.wikipedia.org/wiki/Japanese_input_methods
Offline ~Blood~
« Reply #7 on: Tue, 12 July 2011, 10:40:39 »
Well I think sometime I will need to. Seeing how I will actually buy a keyboard thats worth $300, I have to look a bit into the future in order not to be disappointed.
Offline bdpq
« Reply #8 on: Wed, 13 July 2011, 01:02:34 »
Quote from: ripster;378733
Just don't call it JAP input.
That's racist.
JIS people.
Thanks for the consideration, ripster.
I will try to demystify the Japanese IME and the JIS/ISO keyboard layout.  Please bear with me as English is not my first language.
The Japanese language has three character systems
1. Kanji - this is the imported Chinese character that we have been sharing with Chinese (traditional Chinese) for about one thousand years.
Example: 英語 - pronounced as "ei-go" meaning "English"
2. Hiragana - this character system is the backbone of Japanese language and all the Kanji can be written in Hiragana. Kids or people who are trying to learn Japanese start with Hiragana.
Example: 英語  can be written as えいご,
3. Katagana - this character system is reserved for words of "foreign-origin" and Japanese language use this system to "Read" foreign words.
Example: イングリッシュ - reads like "Inn-gu-ri-shu" meaning "English"
It is because of this complicated language we need so many extra buttons to assist us "transforming" between different character systems.
Now how about the Japanese characters on the keyboard, are they necessary?  Well, not really.  One can type all three systems perfectly well on an ANSI keyboard using the "romaji" input system, it would just involve more keystrokes.  However it is easy to learn and under this input system, one need only type out the pronunciation and then choose the right character system.
example: itsumoarigatougozaimasu (meaning: Thank you as always)
23 keystrokes plus space key for 1st level transformation to hiragana, you'd get
いつもありがとうございます
and after a few more "transformations", you'd get the "proper Japanese:"
いつも有難う御座います
but if you want to be a purist and want to type real fast in Japanese, that's when you will need to learn the KANA layout.
One would type the mapped pronunciation keys on the KANA layout resulting only 13 keystrokes and transformation keys
It's complicated, isn't it.
Most younger Japanese now use the "romaji" input system, eliminating the need to have Kana characters printed on the keyboard and some even prefer ANSI layout.
You can use the Japanese ISO layout on a US system without installing the IME system, it will behave just like another ISO keyboard.  You can even use the extra keys in gaming if you want.  they can be quite handy sometimes.
One last point thou', as ripster pointed out earlier, the KANA characters indeed make the keyboard looks more, er, exotic, some of my American friends use it to impress chicks. ;)
« Last Edit: Wed, 13 July 2011, 02:04:15 by bdpq »
[SIGPIC][/SIGPIC]
where the heck is green?
Offline The Solutor
« Reply #9 on: Wed, 13 July 2011, 01:44:10 »
Thanks for the detailed explanation.
 My friend Mikio already did it, but I quickly forgot the details.
As you said it's complicated, but I presume that a jōyō kanji keyboard with 2136 keys would be a bit more complicated :-)
