Author Topic: Length of Noppo choc mini and Filco  (Read 3773 times)
Offline kwantz
« on: Tue, 19 July 2011, 20:44:21 »
I was wondering if you could possibly tell me the length from edge to edge of the noppo choc mini and the filco I want to see which one will fit on my set up the best.
Offline kwantz
« Reply #1 on: Tue, 19 July 2011, 20:56:37 »
i dont see it, but i meant the 10 keyless filco... also the length of the leopold.
Offline elbowglue
« Reply #2 on: Tue, 19 July 2011, 21:04:18 »
Leopold should be the same size as filco.
I have no idea where to find the measurements you have asked for...
Just kidding.
Look at my sig!
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline alaricljs
  • I be WOT'ing all day...
« Reply #3 on: Tue, 19 July 2011, 21:08:14 »
elbowglue comes prepared... scary
Filco w/ Imsto thick PBT
Offline alaricljs
« Reply #4 on: Tue, 19 July 2011, 21:11:59 »
Had to zoom in 10 clicks to read it tho  8)
Offline supremeMilo
« Reply #5 on: Tue, 19 July 2011, 21:16:17 »
Noppoo Choc Mini is 12.5" long.
Offline keyboardlover
« Reply #6 on: Tue, 19 July 2011, 21:18:00 »
Quote from: supremeMilo;383726
Damn. That's not what they call "Mini" in MY neighborhood.
Offline RiGS
« Reply #7 on: Wed, 20 July 2011, 18:21:30 »
Quote from: elbowglue;383713
Just kidding.
Look at my sig!
The Leopold is 4mm wider.
Offline Arcanius
  • Buckling Spring Lover
« Reply #8 on: Fri, 22 July 2011, 10:02:09 »
Rounded edges add more width, since the top of the edge is just as wide as filco, and the rounding then adds 2mm on each side?
Random guess.
Offline Arcanius
« Reply #9 on: Fri, 22 July 2011, 11:17:27 »
Oh, just tell us!
Offline Chobopants
« Reply #10 on: Mon, 25 July 2011, 14:57:18 »
The width of the bevel is less on the left/right sides than the top/bottom?
Nope that's wrong, the bottom bevel actually seems to be the odd man out in being thicker.
Realforce 87UW 45g - Filco Blue 87 - Filco Linear R - Filco Brown 104
Offline sordna
« Reply #11 on: Tue, 26 July 2011, 10:10:58 »
So the frame is thinner, hence the smaller overall length?
Offline Arcanius
« Reply #12 on: Tue, 26 July 2011, 10:30:30 »
How do you know why it's wider? Have you owned a Leo and I didn't hear about it?
Also, please tell us, mighty ruler of the keyboard world. ;)
Offline The Solutor
« Reply #13 on: Sun, 31 July 2011, 11:17:02 »
Quote from: ripster;389347
Nobody with Leopolds owns rulers?
Maybe Leopold ?
[ Attachment Invalid Or Does Not Exist ] 22903[/ATTACH]
Offline The Solutor
« Reply #14 on: Sun, 31 July 2011, 11:28:54 »
Quote from: ripster;390401
Yep, and I get 355/6mm for the Filco.
Better if you ask to someone expert in basic keyboards, he will tell if is the border is larger, the key blocks are more spaced, or Mr Leopold has a wrong ruler...
« Last Edit: Sun, 31 July 2011, 11:38:13 by The Solutor »
Offline The Solutor
« Reply #15 on: Sun, 31 July 2011, 11:42:28 »
I wrote alpha block by mistake I meant the keys blocks, btw the only other option is a slightly increased distanche from key to key, unlikely but possible.
Yesterday I learned that some logitechs have a not standard staggering on the numeric row, like the japanese HHKB, so all is possible.
« Last Edit: Sun, 31 July 2011, 11:46:39 by The Solutor »
Offline The Solutor
« Reply #16 on: Sun, 31 July 2011, 11:47:55 »
Quote from: ripster;390420
You meant SOME Logitechs have nonstandard staggering.  Most are standard.
Indeed was already corrected, never reply before I read what I wrote.
Offline The Solutor
« Reply #17 on: Sun, 31 July 2011, 11:54:25 »
Quote from: ripster;390425
I find this statement difficult to reply to.
Hahaha
