Author Topic: The Phantom - and interest check  (Read 73112 times)
Offline litster
  • rare caps?! THAT'S A SMILIN
« Reply #200 on: Tue, 22 November 2011, 16:12:57 »
Quote from: TheProfosist;457683
There is also Hazu's code that is used on the DOX.
I didn't know that.  That's great!
Quote from: hashbaz;457691
I think I remember reading that the plate would have access holes to facilitate solderless switch modding.  Is that right?
Yes, the H switch cut out "should" let us open up switches without de-soldering the switch.  We still have to test it with a prototype.  Also, a few switches may still require de-soldering due to limited space or switch arrangement.  But the majority of them will not need to be de-soldered.
« Last Edit: Tue, 22 November 2011, 16:20:05 by litster »
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #201 on: Tue, 22 November 2011, 16:15:50 »
Quote from: litster;457709
Yes, the H switch cut out "should" let use open up switches without de-soldering the switch.  We still have to test it with a prototype.  Also, a few switches may still require de-soldering due to limited space or switch arrange.  But the majority of them will not need to be de-soldered.
Sweet.
Offline Mr. Perfect
« Reply #202 on: Tue, 22 November 2011, 23:08:33 »
Sweet indeed! How is it the entire keyboard industry can't come up with this stuff?
Mr. Perfect - A name fraught with peril.
G80-8113HRBUS MX Clears, FC200R MX Clears, RK-9000v2 MX Blues.
Offline TheProfosist
  • Custom Layouts Only!
« Reply #203 on: Tue, 22 November 2011, 23:10:34 »
Quote from: Mr. Perfect;458027
Cost
Offline dux
« Reply #204 on: Sun, 04 December 2011, 18:58:58 »
Plu Dimensions:
size of PCB  122 * 345 mm ,  one or 2 mm more would not be a problem
size of plate  128 * 349 mm, the 128 should be rather precise cut
distance between:
ESC and F1: 38 mm
F9 to Pause/Break : 119 mm
ESC and Pause/Break : 328.5 mm
Pause/Break and Right Arrow: 104 mm
Distance between all the holes on the PCB for the supporting posts on the bottom of the keyboard case
I measuerd all holes from the middle of the hole.
All upper holes have the distance of 22.5mm from the upper edge of the PCB.
The distances of the upper 3 holes from left (CapsLock side) to the right side are:
left edge to 1st hole: 56mm, 1st hole to 2nd hole: 115.5mm, 2nd hole to the 3rd hole: 115.5mm, 3rd hole to the right edge: 58.5mm.
Lower right (CapsLock Side) hole: 13mm to the bottom edge, 58.5mm to the right edge.
Lower left hole: 36mm to the left edge, 37.5mm to the bottom edge.
Hope this helps. Please check if this is OK, because I want to put my plu together again. [ Attachment Invalid Or Does Not Exist ] 33922[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 33921[/ATTACH]
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
Re: The Phantom - and interest check
« Reply #205 on: Tue, 08 October 2013, 03:10:13 »
Deeply interested
Offline Reomero
  • Manual breather
« Reply #206 on: Tue, 08 October 2013, 03:51:17 »
Deeply interested
Do you check the date when a post was posted?
Offline MJ45
  • HHKB Pro
« Reply #207 on: Tue, 08 October 2013, 09:32:06 »
Deeply interested
Keep checking the classifieds and post a WTB, you may get lucky. That's how I got mine.
Offline MKULTRA
  • telling it how it is
« Reply #208 on: Tue, 08 October 2013, 10:36:41 »
Deeply interested
This guy is just trying to get to classifieds.
