Author Topic: After going through 7 keyboards I've gone back to the Rubberdome...  (Read 22242 times)
Offline Magna224
« Reply #50 on: Fri, 29 July 2011, 19:09:15 »
You haven't tried complicated white ALPS. I was not satisfied until I tried them then my world changed.
Offline The Solutor
« Reply #51 on: Fri, 29 July 2011, 19:19:02 »
Quote from: ch_123;389591
Yeah, I read descriptions of it being a standard rubber dome style switch, except using a mebrane instead of a PCB.
Looks embarrassingly similar to the Ti99's (not 4a) keyboard
 I haven't seen a dismantled photos of both, but from this photo doesn't look as a rubber dome.
Offline The Solutor
« Reply #52 on: Fri, 29 July 2011, 19:23:06 »
Quote from: Magna224;389640
They are nice because very close to the ergo clears, and also because cn be adapredd to various taste w/o the need of any soldering.
With a single kind of switches you can made them dampened/undampened clicky or not, and the tactility and be also adjusted just bending the leaf spring.
Offline Hydroid
    • http://justin.tv/hydr0id
« Reply #53 on: Fri, 29 July 2011, 22:36:00 »
I agree with the OP. As I may have mentioned before that I bought a Qsenn DT-35 in late February and used it for about 2 months. During that time I really hammered it, clocking ~400 hours of SC2. And it was a great keyboard. While I now prefer my ducky with blues for typing, I plugged my Qsenn in the other day because a friend of mine didn't like not being able to see the letters on the keys, and then I played another game with it while he was there and I forgot how it just feels right when playing SC2. Its not nice when playing FPS, for some reason I found it just wasn't that great, whereas my Blues are amazing for shooters and typing. I'm used to my blues and am still using them for SC2, but I really do think there is just something about the Qsenn that works.
Intel Core i7 870 @ 2.93GHz | Corsair H50 | 16GB G.Skill DDR3 | Asus P7P55D-E Pro | Galaxy nVidia GeForce GTX 460 SLI
OCZ 60GB SSD | 2x 1TB Seagate Barracuda RAID-0 | Samsung Blu-Ray Burner | Corsair HX-850W | 2x BenQ G2420HD 24"
Leopold FC200R Tenkeyless Blue | Ducky DK9008(B) Blue | Qsenn DT-35 Black PS/2 Rubber Dome |2x Razer Lycosa USB | Microsoft 500 PS/2
Help me support and grow e-sports below!!!
What Happens in Starcraft -- Vlogs -- Twitter
Offline False_Dmitry_II
« Reply #54 on: Fri, 29 July 2011, 22:41:30 »
Quote from: Reason;389568
I think you should learn how to read before posting your own biased opinion.
You too. You weren't the only one who listed a bunch of cherry switches in this thread. It also is not an opinion that you specifically tried too few types of switches, almost all of which were from just cherry. Liking a model m, but just for typing, means that you will most likely eventually use just the rubber dome unless you keep both plugged in and have a spot to stick one or the other when switching. That also means you haven't found one that is ideal and you could use at any time.
It's also not an opinion that that particular rubber dome is just popular because it was cheap and available in korea. This is not a statement of quality, and in fact all I ever read about is that it is hyped for no reason. There was another post in this thread with a list of what are considered good rubber domes. I'd add the NMB rubber domes to that. Most likely of the RT6xxx series, but you'd probably want to look that up.
Next time, don't just read the title and post a hateful comment.
Lol. Yours was more. I'm just tired of most acting like cherry switches are the one and only kind. Apart from that, the model m gets mentioned so much because of its age status and reputation so it isn't surprising that it would be the first one run across besides cherry.
Quote from: The Solutor;389651
Yeah, they really are quite cusomizable. You can even toss the leaf entirely and get linear switches (if you're into that sort of thing).
Offline flashstar
« Reply #55 on: Sat, 30 July 2011, 03:05:46 »
I've tried black alps and I didn't say anything about all mech boards being crap.
I stated that they simply didn't suit me. (I even mentioned that I really like the Model M.)
I'm actually thinking about buying a topre pretty soon if the 87s come back in stock on EK.
When you post on a forum, you are asking for everyone to give their opinions. I don't see why Dmitri shouldn't be allowed to give his.
I can assure you though that you are missing out unless you have tried lubed/new complicated ALPS whites or complicated blues. No rubber dome could match these key switches.
To put this in perspective, my brother bought an Xarmor with cherry blues and it does not even compare to blue ALPS keyswitches. The cherries feel less stable, do not slide as smoothly, and are generally less satisfying to type on. Cherry Browns are awful in my opinion (they feel like rubber domes). Cherry blues are not bad switches, I just believe after comparing the two side-by-side that ALPS blues are superior.
I've tried many different keyboards (Ione Xarmor, Logitech G15, Lazer Lycosa, Model M, SteelSeries 7G) as well and none have even compared to complicated ALPS when it comes to non-gaming typing feel. I do not consider black ALPS to be as good as white ALPS. For gaming, the one exception so far is the Model M.
My point is that you should not rule out every mechanical keyboard just because the ones you have tried do not fit you well. It would be like trying out a few pairs of inexpensive shoes at a department store and concluding that the nicest pairs out there are no better...
Keyboards: Omnikey 102 (complicated whites), Omnikey Ultra T (blues), Omnikey 101p (FUKKAs), Focus FK-2001 (comp whites), Escom (blues, for parts)
Offline TheProfosist
  • Custom Layouts Only!
« Reply #56 on: Sat, 30 July 2011, 04:04:09 »
i dont get how any mechanical keyboard could feel remotely like a rubber dome. even topre switches which are part rubber dome feel night and  day different.
Offline ch_123
« Reply #57 on: Sat, 30 July 2011, 06:12:36 »
Quote from: The Solutor;389649
From here
The PCjr keyboard has generated a fair bit of controversy. IBM calls the 62-key unit "a cordless, portable, hand-held device [utilizing] full travel, carbon contract/rubber dome technology for long wear and reliability.' Critics say it is a cheap, "Chiclet' keyboard, unworthy of a "real' computer, with the wireless business a superfluous gimmick. Who is right? Ask the blind man over there by the elephant.
 Game players, slouchers, and other relaxed individuals will find the cordlessness a godsend. There is nothing to stretch or break. Tabletop users have a choice of two tilt angles with two little flip-down legs on the underside of the keyboard. The dust-and spill-resistance should be quite high, since the entire interior is covered by a solid rubber sheet with molded-in domes.
 Glued to the underside of each dome is a little piece of carbon. When you press a key, it squishes the dome, the carbon makes contact with the underlying printed circuit card, and the keystroke is sensed by the keyboard microprocessor, which transmits the information to the system unit--simple, reliable, and cheap.
Offline isp
« Reply #58 on: Sat, 30 July 2011, 07:17:22 »
You silly goose.  You didn't even try topre.
hhkb
Offline noodles256
  • le legendary
« Reply #59 on: Sat, 30 July 2011, 09:49:49 »
-1
AF | Ducky YOTD |
Offline flashstar
« Reply #60 on: Sat, 30 July 2011, 12:34:20 »
Quote from: isp;389851
+1
Offline snowball
« Reply #61 on: Sat, 30 July 2011, 13:15:25 »
To each there own. I don't really like the DT-35. Mine is on a server box in the basement. Maybe gets an hour of use a year.
Mice: Zowie EC2, SS Xai, Deathadder Black Edition, Imperator, MX 518, G9
Mousepad: Artisan KAI.g3 HARD, QCK+, SX, 9HD, I-2, NP+, QCK Heavy, Zowie G-TF
Keyboard: G6v2, Mini Choc (blue), Leo Otaku (brown), Poker (Red on order)
Offline MrGPhantome
« Reply #62 on: Sat, 30 July 2011, 16:14:20 »
Well from my experience, most new Rubber Dome keyboards feel pretty serviceable the first day of use. The main problem is the longevity, If you are heavy typist they wear very quickly. Even the higher quality domes in boards like Keytronic wear down much faster than any mechanical out there. Mechanical keyboards have consistency which is far more reliable than a first day feel.
"It\'s true what they say... If you dress Hitler up in a nice sweater... He\'s still f****** Adolf Hitler." - Cinema Snob
Offline The Solutor
« Reply #63 on: Sat, 30 July 2011, 18:39:00 »
Quote from: MrGPhantome;390078
This is completely untrue.
At least the tactile switches will wear surely depending on the number of activation, while the RD becomes mushy only if poor materials are used.
On heavy usage patterns a lot of RD will beat easily most of the tactile microswitch keyboard, with the exclusion of  buckling springs ones.
« Last Edit: Sat, 30 July 2011, 18:56:52 by The Solutor »
Offline ch_123
« Reply #64 on: Sat, 30 July 2011, 18:41:45 »
Agreed. Comparing a year old Blue Cherry keyboard and a 10 year old Blue Cherry keyboard, you'd be forgiven for thinking they weren't the same switch.
Offline Johannes
« Reply #65 on: Sat, 30 July 2011, 18:42:12 »
As The Solutor said (he's right for once) mech switches also wear. Also, they are much more expensive, so replacing a board is much less practical.
« Last Edit: Sat, 30 July 2011, 18:45:04 by Johannes »
Offline RiGS
« Reply #66 on: Sat, 30 July 2011, 18:45:48 »
Linear switches don't wear that much.
Offline hella
« Reply #67 on: Sat, 30 July 2011, 21:07:58 »
Quote from: The Solutor;390162
I gotta partially agree with this, if you want a mechanical keyboard for tactile feedback a rubber dome won't satisfy you.
Offline sordna
« Reply #68 on: Sat, 30 July 2011, 21:16:20 »
One of my rubber dome keyboards (CKS) is rated better than cherry switches:
Conductive elastomer rubber designed for 60 million cycles
Offline MrGPhantome
« Reply #69 on: Sat, 30 July 2011, 23:26:28 »
*snip
I'm not giving the impression that a mech switch board is immortal and consistant forever. However in general I would believe that a Mechanical board would last longer than your general run of the mill RD keyboard. Sure their are standouts like Keytronic and IBM M4s, but I would venture that most keyboard fall into the poor quality zone.
All I know is that my Keytronic I used didn't feel the same 3 months down the line while I my Apple Extended keyboard switch board easily lasted much longer before losing it's initial feeling.
Quote from: Johannes;390166
*snip
The idea that you won't have to replace a mechanical keyboard often enough for it to become an issue.
Offline detriarch
« Reply #70 on: Sun, 31 July 2011, 01:36:02 »
Where did u get ur dt 35 from and does urs have korean and english writing or jsut english on it ?
Offline ch_123
« Reply #71 on: Sun, 31 July 2011, 05:02:45 »
Quote from: sordna;390200
Some manufacturers have more believable ratings than others. Even the Cherry rating of 50 million is a bit dubious (once it was 20 million for tactile switches, then it was suddenly bumped up to 50...)
Offline The Solutor
« Reply #72 on: Sun, 31 July 2011, 05:17:46 »
Quote from: ch_123;390312
And even with the correct number we have still to understand what they mean.
What's lasting 20 or 50k actuations ? The contact, the whole switch ? What are the parameters taken in account ?
When someone says a "led last 100k hours" he should mean that the LED will still emit the 50% of the initial luminous flux, we have an universally accepted methodology.
What a bout the switches ?
A brown that act like a red is a working switch or not ?
Offline Multiple
« Reply #73 on: Sun, 31 July 2011, 06:45:04 »
Quote from: The Solutor;390316
The actuations are probably just that, actuations. A key-press; an actuation is registered.
Should take about 2 months to test a switch for 50 million actuations, 10 actuations per second.
« Reply #74 on: Sun, 31 July 2011, 06:57:01 »
What I have heard, and think is the most believable, is:
50 million presses for Cherry MX Black
20 million presses for all tactile Cherry MX switches, but the tactile feel will have been diminished significantly long before the switch breaks.
Offline George7
« Reply #75 on: Sun, 31 July 2011, 07:51:29 »
Glad you've found a keyboard that suits you. I've thankfully been completely satisfied by Cherry Blue switches :) Some rubber domes aren't bad at all though. I think my favourite rubber dome board is, weirdly, the OEM Dell board that came with the Dell machines 7ish years ago. For me, the feel is just right; just a shame they're pad printed!
Offline Bry
« Reply #76 on: Sun, 31 July 2011, 08:07:19 »
 I cant wait till my browns start acting like reds, FREE SWITCH CHANGE :D
last.fm | deviantART | SC2
Filco MJ2 Ninja - MX Red | Filco MJ2 Ninja - MX Brown | U9BLS - MX Brown
Offline DivineWind
« Reply #77 on: Sun, 31 July 2011, 17:02:39 »
The Topres are rated for 30 million presses although before I would get close to that number I would have already switched out my keyboard.  How long does it take for an avid typist to hit 1 million keystrokes on a single key?  What do you guys think?
Topre REALFORCE 103UB w/ 3-Star Leather Palm Rest   Logitech G700 Mouse  Logitech G35 Headset
Intel i5 2500K @ 4.4 GHz, eVGA GTX 560 Ti SC, 4 GB G. Skill RAM, ASrock P67 Pro3, Hitachi 1TB HDD, Lite Scribe Disk Drive, 750 Watt Antec power supply, Antec 300 Illusion tower, 23" Asus LED 2 MS monitor
Offline prd
« Reply #78 on: Sun, 31 July 2011, 17:11:51 »
[STRIKE]It will take 489 days.[/STRIKE]
I might have exaggerated: 207 days.
« Last Edit: Sun, 31 July 2011, 17:15:37 by prd »
Offline The Solutor
« Reply #79 on: Sun, 31 July 2011, 17:24:09 »
Quote from: prd;390581
I'd said 500 days (for the most used vowels).
So I assume your first guess is more correct.
Offline RiGS
« Reply #80 on: Sun, 31 July 2011, 17:35:08 »
You guys make these claims look scientific.
Offline prd
« Reply #81 on: Sun, 31 July 2011, 17:42:45 »
But they are! That's 4830 spacebar presses a day.
Offline The Solutor
« Reply #82 on: Sun, 31 July 2011, 17:43:56 »
Quote from: RiGS;390596
Statistics results are imprecise by definition, but are still scientific data if correctly guessed and calculated.
Offline RiGS
« Reply #83 on: Sun, 31 July 2011, 17:46:29 »
Yeah I like the words scientific and guessing in the same sentence, especially without the statistical data.
Offline prd
« Reply #84 on: Sun, 31 July 2011, 17:52:24 »
I wonder if that Korean oil prolongs the life of MX switches.
Offline The Solutor
« Reply #85 on: Sun, 31 July 2011, 17:52:38 »
Quote from: RiGS;390607
Yeah I like scientific and guessing in the same sentence.
Sorry but when you can't install a key-logger on sufficient sized sample of all the PC users, you have to start guessing.
Exactly as you have to guess what happened at the moment of the universe born, because the CNN wasn't there.
Offline RiGS
« Reply #86 on: Sun, 31 July 2011, 17:55:14 »
I'm okay with guessing, but you have to admit the part when you corrected prd was a little bit funny.
Offline prd
« Reply #87 on: Sun, 31 July 2011, 17:55:15 »
Yeah, I think the universe was always there. And this brings me back to the Korean oil...
Offline The Solutor
« Reply #88 on: Sun, 31 July 2011, 17:58:07 »
Quote from: prd;390612
The correct lubricant surely improve the mechanical life, but hardly something can be done for the electrical contact on such kind of switches, operating at very low currents and voltages.
When greater currents and voltages are involved a wide range of solutions can be used to reduce the electrical spark, that is the major source of wearing .
Offline The Solutor
« Reply #89 on: Sun, 31 July 2011, 18:04:12 »
Quote from: RiGS;390615
Clearly we "guessed" different pattern usages, and different meaning for "avid typer", you can't ask more than the order of magnitude for this kind of request.
You can consider 200 as correct as 800, start wondering when one says 75 and the other says 10000...
Offline RiGS
« Reply #90 on: Sun, 31 July 2011, 18:14:08 »
I agree, but you are still not getting the joke.
It is the way how you corrected prd.
However this statement of yours makes it even funnier.
Offline The Solutor
« Reply #91 on: Sun, 31 July 2011, 18:19:29 »
Quote from: RiGS;390627
I guess you missed the moment.
He corrected himself, i quoted in that precise moment, when I posted the message he reverted the correction...
So my quote looked as materialized from the hyperspace...
all in all you are guessing w/o all the data available...:happy:
Offline RiGS
« Reply #92 on: Sun, 31 July 2011, 18:23:14 »
Haha.
This thread is getting funnier with every new post. :happy:
Offline themadreason
« Reply #93 on: Wed, 16 November 2011, 01:31:07 »
Quote from: Tony;389238
The thought of perfection kills you.
Every switch or keyboard is fine in its own way, and by comparing each keyboard with something perfect in your head, you make your life miserable, since you will never be satisfied.
You always feel you are missing something by comparing. That feeling make you either a hoarder, trying to get every keyboard you can afford, or a bad loser, by choosing the worst that you can get, since in your mind all things are not perfect so get the worst can be very fulfilling.
Damn that is deep man!
MY WHOLE LIFE IS A LIE!  My keyboards make me empty inside! (*slits writst, hangs self, glad he bought the TG3 BL 82 w/blood spatter guard).
« Reply #94 on: Wed, 16 November 2011, 01:40:52 »
Seriously though, that blew open my tiny mind.
Offline Harlequin
« Reply #95 on: Wed, 16 November 2011, 01:46:37 »
I actually own 2 Qsenn DT-35. Black and white. I love playing SC2 with it. but i always mix membrane and mechanical keyboards.
So sometimes i use mech and sometimes i use membrane but membrane for only SC2 i guess.
Generally mech is good for typing and also gaming imo. However, truly DT-35 is an awesome keyboard for SC2.
It just feels so good!! Even though it's really cheap keyboard.
DK Saver Winkeyless | Leopold FC700R | Ducky DK9087 Shine 2
Offline shrap
« Reply #96 on: Wed, 16 November 2011, 13:11:26 »
Quote from: themadreason;453077
That whole spiel is just a rephrasing of The Paradox of Choice.
« Reply #97 on: Wed, 16 November 2011, 23:32:51 »
"That whole spiel is just a rephrasing of The Paradox of Choice"
Hmmm.  That looks interesting.  I may need to read this.
Offline epik
« Reply #98 on: Thu, 17 November 2011, 08:13:44 »
lol interesting thread. Logged back in for the first time in a while to say that I have settled back on my ol' 1st gen Logitech G15 as well.
I still have a Razer Blackwidow and tried out a couple Filcos. I did like the feel of the mechanicals a bit. Black switch was interesting but in the end I think there was so much hype I read that it was almost as if I was forcing myself to deal with the awkwardness of the mechanical switches and telling myself that it would be better off in the long run. Well, I gave it a few months and it wasn't so.
Hindsight is 20/20 but I didn't actually have any problems with my G15 in the first place. I type just as fast, 200+ wpm and have fewer errors.
So in the end I'd have to say there's a lot to like about mech keyboards but to everyone who tells unaware people they are miles better, let's just keep these realistic yeah? Personal preference in the end, I suppose.
7+ years and still going strong; feels like home.
« Last Edit: Thu, 17 November 2011, 08:17:30 by epik »
Offline Mazora
« Reply #99 on: Thu, 17 November 2011, 08:40:16 »
Quote from: epik;453928
This keyboard is not as ugly as it looks on this picture. I used the G15 for so long and I kinda got used to the look in the end. But going with mechanicals allowed me to type 15% faster, from like 275 wpm to 316.25+.
Also, the Filco looks so good; even my tattooed friend told me it didnt "look like a toy for once", which is a great compliment coming from him. Although the Logitechs age very very well, you should be expecting some mushiness after 7years of relatively-heavy typing.
HHKB Pro 2: black case white keys
Filco Masjestouch v2 / MX-Reds / hard lending pads /Dye-sub keycaps
RF-87UW
