Author Topic: [GB] Double shot replacements ROUND FOUR! - SHIPPING!  (Read 1442565 times)
Offline Fred
[taking orders!] Double shot replacements ROUND FOUR!
« Reply #1550 on: Mon, 14 November 2011, 20:57:31 »
Quote from: kps;452169
According to the wiki, all the kits currently have both arrow and text versions of the cursor movement keys.
Ah indeed. Looked over the standard kit pic, see them right there.
Offline godofdeath
« Reply #1551 on: Mon, 14 November 2011, 21:22:07 »
ah do i want a kit, with shipping, space bars, std set, windows set its prolly like 100 :(
« Reply #1552 on: Tue, 15 November 2011, 00:47:28 »
Quote from: FourOhFour;452242
The text ones seem to go nicely with round3. And let's be honest, it doesn't much matter what the arrow keys are marked as which is which is generally obvious from their locations. They could be "Pie", "Cake", "Cinnamon Bun", and "Turnips" for all it matters.
Ok, maybe not "Turnips".
In for "cinnamon bun" arrowkeys :p
7bit, I will order more noir glider if necessary. It will happen. Also, I Might do the same for "dark" glider escapes or similar. I want dem gliders!
Offline 7bit
  • MX1A-G1DW
« Reply #1553 on: Tue, 15 November 2011, 02:29:16 »
Quote from: Fred;452165
Wait, even the arrow keys have text...!? That's definitely a big no-no. xD
Where do you see text?
Keys_with_Pictures
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline AgentZen
« Reply #1554 on: Tue, 15 November 2011, 02:54:15 »
Will an entire kit with spherical keys be weird to type on? What about gaming? I want to get a round 3 kit but don't know if I should go with the classy sphericals or cylindrical. Also is there two shapes of cylindrical keys available? what is the difference?
KUL ES-87 w/ Clears (GMK Hyperfuse) | Working on: Custom 60% w/ 65g feelios (BSP blanks)
Offline eagleeye
« Reply #1555 on: Tue, 15 November 2011, 02:59:33 »
I was thinking of order 2 sets of replacement keys.  I currently switch between a couple of different Noppoo Choc Minis, and before placing my order, I wanted to make sure it's right.  I was going to order:
ROUND3/TENKLESS
ROUND3/SPACE
ROUND3/GEEKHACK 2
RETRO/TENKLESS
RETRO/SPACE
RETRO/GEEKHACK 2
EMAIL ***myemail**@gmail.com
Before I send the PM, I wanted to clarify that I will be able to replace all 84 keys on the keyboard including the space bar.  I read through some of this thread, but I wasn't sure if it was resolved if the spacebar's with this groupbuy are compaitiable with Noppoo keyboards or not.
Offline AgentZen
« Reply #1556 on: Tue, 15 November 2011, 03:04:08 »
Does anyone have a real pic (not graphic) of what the SPH will look like on an actual keyboard?
Offline RColinTaylor
« Reply #1557 on: Tue, 15 November 2011, 03:09:49 »
Quote from: brsp25;452469
I believe the old image of the Space Cadet is the only picture I have ever seen of a SPH set in full.
I like my Browns more than my Blues.
Offline zulios
« Reply #1558 on: Tue, 15 November 2011, 04:06:03 »
Noticed a few details in the wiki :
- The arrow down image is labeled as arrow up.
- The 1.25 shift is not marked in red in the FR kit.
Is it possible to make such minor modifications with 7bit's consent ? I'm not familiar with wikis yet.
Also, I'm wondering about the size of ctrl and alt modifiers on a g80-2100. 1.50 unit or 1.75 unit probably ?
Tipro matrix - mx black
Offline 7bit
  • MX1A-G1DW
« Reply #1559 on: Tue, 15 November 2011, 04:27:06 »
Quote from: brsp25;452463
Do you think we did not play games in the days of C64 & Co?
ROUND or SPH: either will be fine for me.
Just don't forget to order the important add-on stuff (NUMERIC, FUNCTION, POS)!
Offline 7bit
  • MX1A-G1DW
« Reply #1560 on: Tue, 15 November 2011, 04:50:10 »
It does not exist!
The closest thing is webwit's Space Cadet keyboard.
Offline 7bit
  • MX1A-G1DW
« Reply #1561 on: Tue, 15 November 2011, 04:54:44 »
Quote from: zulios;452495
Yes, if you find a typo you may correct it.
The shift and J-shape return are not in red, because I was unsure at the beginning if I include them or not.
G80-2100&friends all have 1.5 units modifiers.
« Reply #1562 on: Tue, 15 November 2011, 04:54:53 »
Quote from: 7bit;452507
It does not exist!
Copycat.
Offline 7bit
  • MX1A-G1DW
« Reply #1563 on: Tue, 15 November 2011, 04:59:33 »
Quote from: RColinTaylor;452510
Copycat.
How can you say that!
I use different shades of color!
« Reply #1564 on: Tue, 15 November 2011, 05:00:33 »
Quote from: 7bit;452513
No you fool! You copied my response!
Though, to the colorblind, you are a copycat on that front as well.
Offline 7bit
  • MX1A-G1DW
« Reply #1565 on: Tue, 15 November 2011, 05:48:38 »
Quote from: RCopyTaylor;452515
And what did you do with all of my Round 3 graphic keys?
You not even dared to change the colors as I did with SPH and RETRO!
You even copied my avatar (showing a keyboard) and copied my location-style!
« Last Edit: Tue, 15 November 2011, 05:50:58 by 7bit »
Offline Razer1987
« Reply #1566 on: Tue, 15 November 2011, 08:18:38 »
Quote from: 7bit;451936
Code: [Select]
SPH/BEPO......................1<------ this is a huge kit and 1 is too few!
For others sets which don't reach the 25, you said that it's still might happen under condition (total amount of keys, different price etc.).
If i buy 5 sets or if i am ready to pay five times the price for one, does that can change something?
« Last Edit: Tue, 15 November 2011, 08:29:16 by Razer1987 »
Offline kps
« Reply #1567 on: Tue, 15 November 2011, 09:00:02 »
The space cadet keyboard has a key for turnips.
[ Attachment Invalid Or Does Not Exist ] 32067[/ATTACH]
Offline 7bit
  • MX1A-G1DW
« Reply #1568 on: Tue, 15 November 2011, 09:09:58 »
Quote from: Razer1987;452550
Just order 5 of them and see what happens;-)
Quote from: kps;452562
(Attachment Link) 32067[/ATTACH]
I've already done the SVG for the simpler left and right pointing hands.
Offline kps
« Reply #1569 on: Tue, 15 November 2011, 09:34:59 »
If by weird you mean awesome, then yes.
Just ask 13,000,000 professional typists.
« Last Edit: Tue, 15 November 2011, 22:53:52 by kps »
« Reply #1570 on: Tue, 15 November 2011, 09:37:34 »
Quote from: RColinTaylor;452472
There's also the knight keyboard (precursor, same designer) but it's basically the same thing
http://world.std.com/~jdostale/kbd/Knight.html
Offline Razer1987
« Reply #1571 on: Tue, 15 November 2011, 10:10:18 »
Quote from: 7bit;452564
i want to try that, in this case i will add 5 bépo standard kit to my order but is it possible to make it Ťuniversalť to fit AINSI and ISO even if its more expensive?
Offline 7bit
  • MX1A-G1DW
« Reply #1572 on: Tue, 15 November 2011, 10:15:09 »
Quote from: Razer1987;452594
No problem with that.
Thanks for your order!
Offline zulios
« Reply #1573 on: Tue, 15 November 2011, 10:58:21 »
How difficult would it be to add two more keys in the FUNCTION kit ? I was think of "CLEAN" and "BUILD", but you will probably need svgs and more interest for that, right ?
Offline Fred
« Reply #1574 on: Tue, 15 November 2011, 11:01:23 »
Quote from: 7bit;452458
Keys_with_Pictures
Those aren't even the arrow keys! xD
Are symbol backspace and shift available in SPH style btw? Doesn't look like it judging from the wiki.
Offline 7bit
  • MX1A-G1DW
« Reply #1575 on: Tue, 15 November 2011, 11:10:54 »
Quote from: zulios;452623
If it is only text, I just have to add them to the source-file, 'compile' it to have a PostScript file, make a PNG out of it and then upload it to the wiki.
In which row should CLEAN and BUILD go?
BW, best chances that you actually get your keys is to order ROUND3/FUNCTION or SPH/FUNCTION, because people who prefer those other styles usually don't take the serious kits like FUNCTION, NUMERIC, POS, etc.
Quote from: Fred;452627
In theory, they are all available. It just depends on how many people want them ...
« Last Edit: Tue, 15 November 2011, 11:12:55 by 7bit »
Offline 7bit
  • MX1A-G1DW
« Reply #1576 on: Tue, 15 November 2011, 12:24:54 »
:~> ./statistics.sh | grep BEPO
NOIR/BEPOSTD..................2
NOIR/BEPO.....................1
What is this?
However, we are at 37141 with 15 days to go!
Offline zulios
« Reply #1577 on: Tue, 15 November 2011, 13:25:18 »
Quote from: 7bit;452633
Lovely ! They should be for row 1 please :)
I went for ROUND3 style for both my terminal and function kit already indeed.
Offline 7bit
  • MX1A-G1DW
« Reply #1578 on: Tue, 15 November 2011, 13:31:05 »
Quote from: zulios;452714
Wise decision!
Offline Wraul
« Reply #1579 on: Tue, 15 November 2011, 14:35:31 »
Hi 7bit.
As instructed i here by want to remind you about my *' key that I wanted added to the SE kit.
I think I accidentally called it star & comma before, but it actually is star & apostrophe. The comma and apostrophe looks identical on my Filco though.
Offline godofdeath
« Reply #1580 on: Tue, 15 November 2011, 14:41:00 »
Why is it that there is a tkl cheapskate set but not one for standard? I would buy the standard but it comes with too many useless keys I won't need
Offline 7bit
  • MX1A-G1DW
« Reply #1581 on: Tue, 15 November 2011, 14:42:36 »
Quote from: Wraul;452761
Which row?
Quote from: godofdeath;452767
How can a full 101 to 105 key keyboard be for cheapscates?
How many sets of STD will you take and from which style?
(Hint: ROUND3/STD or SPH/STD)
« Last Edit: Tue, 15 November 2011, 14:45:30 by 7bit »
Offline Wraul
« Reply #1582 on: Tue, 15 November 2011, 14:46:58 »
Quote from: 7bit;452770
Which row?
I want the legend to be identical to the *' key already in the SE kit, but as a 1.75 (or is it 1.5?) unit to replace the |\ key above enter on ANSI boards.
Offline 7bit
  • MX1A-G1DW
« Reply #1583 on: Tue, 15 November 2011, 15:00:29 »
Quote from: Wraul;452774
OK, sorry!
It is 1.5 units.
I will post the SE layout as soon as possible.
Please remind me again in 14 days.
Offline Wraul
« Reply #1584 on: Tue, 15 November 2011, 15:13:26 »
Quote from: 7bit;452785
OK, sorry!
It is 1.5 units.
I'm the one that should say thank you, for doing this huge group buy.
I will definitively remind you again in 14 days.
Offline 7bit
  • MX1A-G1DW
« Reply #1585 on: Tue, 15 November 2011, 15:25:09 »
Quote from: Wraul;452793
Not necessary anymore:
Thanks for supporting the SE kits in all styles!
Offline eagleeye
« Reply #1586 on: Tue, 15 November 2011, 16:37:41 »
Quote from: eagleeye;452466
ROUND3/TENKLESS
ROUND3/SPACE
ROUND3/GEEKHACK 2
RETRO/TENKLESS
RETRO/SPACE
RETRO/GEEKHACK 2
Any help?  Thanks.
Offline Mysteric
  • Formerly 'Mackem'
« Reply #1587 on: Tue, 15 November 2011, 17:28:35 »
I really want some white keycaps
Offline Razer1987
« Reply #1588 on: Tue, 15 November 2011, 17:51:42 »
Quote from: 7bit;452681
What is this?
The NOIR are not mine, i only placed the SPH/BEPO but i am gonna delete my first order and make a new one only with SPH/BEPOSTD
« Last Edit: Tue, 15 November 2011, 21:29:49 by Razer1987 »
Offline godofdeath
« Reply #1589 on: Tue, 15 November 2011, 21:21:19 »
Which row?
I was going to get
NOIR/STANDARD
NOIR/SPACE
NOIR/WINDOWS
and
RETRO/STANDARD
RETRO/SPACE
RETRO/WINDOWS
my goal is just to make it look like the stock keycaps that come withe filcos, so things like stepped caps lock, meta, diamond, alt graph, up, down, left, right are not necessary,
I would just like it to look like stock with the arrows and such
Offline 7bit
  • MX1A-G1DW
« Reply #1590 on: Wed, 16 November 2011, 04:25:46 »
Quote from: eagleeye;452848
Any help?  Thanks.
The 5.5 units space bar will not be available.
Maybe next time!
Offline 7bit
  • MX1A-G1DW
« Reply #1591 on: Wed, 16 November 2011, 04:27:20 »
Quote from: Razer1987;452912
You promised to order 5 sets of the SPH/BEPO kit!
Offline zulios
« Reply #1592 on: Wed, 16 November 2011, 05:51:37 »
I forgot to ask for one more key in the FUNCTION kit : "DEBUG", on row 3 please :)
Hope this is not too much work for you.
Offline 7bit
  • MX1A-G1DW
« Reply #1593 on: Wed, 16 November 2011, 06:15:34 »
Quote from: zulios;453150
Maybe it will be a
RUB OUT
ZULIOS
key!
I will see what I can do ....
Offline Razer1987
« Reply #1594 on: Wed, 16 November 2011, 11:48:16 »
Quote from: 7bit;453134
I delete the first one and instead i ordered that like i told you:
SPH/BEPOSTD 5
SPH/SPACE  5
SPH/WINDOWS 5
I even received the confirmation email.
There is no point for me to buy only SPH/BEPO as an add-on to a QWERTY STD or TKL set, if i want to sell them after i need a complete bépo standard set which fit AINSI and ISO layout. I hope it doesn't change anything…
Thank you
Offline 7bit
  • MX1A-G1DW
« Reply #1595 on: Wed, 16 November 2011, 15:36:51 »
Quote from: Razer1987;453328
SPH/BEPOSTD 5
SPH/SPACE  5
SPH/WINDOWS 5
Thank you
SPH/STANDARD.................10
SPH/TENKLESS.................18
SPH/TERMINAL..................6
SPH/TKL.......................7
ROUND3/STANDARD..............12
ROUND3/TENKLESS..............11
ROUND3/TERMINAL...............3
ROUND3/TKL....................3
RETRO/STANDARD...............30
RETRO/TENKLESS...............16
RETRO/TKL....................12
NOIR/BLANKTKL.................1
NOIR/STANDARD................18
NOIR/TENKLESS................10
NOIR/TKL......................2
DARK/STANDARD.................5
DARK/STANDARD/ORANGE.........20
DARK/TENKLESS.................3
DARK/TENKLESS/ORANGE..........7
DARK/TKL/ORANGE...............4
#keycaps: 38504
38504-50000==-11496
SPH/BEPOSTD...................5
Current deadline: 2011-11-30
14 days or 11496 keys to go!
[/color][/size]
« Last Edit: Wed, 16 November 2011, 15:39:22 by 7bit »
Offline Tanooki
« Reply #1596 on: Wed, 16 November 2011, 16:39:56 »
What are the BSD and GLIDER key kits, there is no pics on the wiki.  Could you also possibly add the LOD pics/combos to the Picture and Graphics section.
Also we need more sph keys ;o
« Last Edit: Wed, 16 November 2011, 17:58:45 by Tanooki »
Offline tsangan
  • 1000/600
« Reply #1597 on: Wed, 16 November 2011, 16:59:50 »
Sphericals!!!!!! :peace:
Keyboardless
« Reply #1598 on: Wed, 16 November 2011, 17:03:12 »
Quote from: tsangan;453508
I am so excited that I am buying a White Leopold w/ Blues when I order the SPH's so that I can recreate the ultimate typing experience: The Space Cadet 2.0
Offline godofdeath
« Reply #1599 on: Wed, 16 November 2011, 17:12:20 »
Quote from: godofdeath;452992
I was going to get
NOIR/STANDARD
NOIR/SPACE
NOIR/WINDOWS
and
RETRO/STANDARD
RETRO/SPACE
RETRO/WINDOWS
so any standard cheapskate?
