Author Topic: [GB] Double shot replacements ROUND FOUR! - SHIPPING!  (Read 1442785 times)
Offline 7bit
  • MX1A-G1DW
[taking orders!] Double shot replacements ROUND FOUR!
« Reply #1700 on: Sat, 19 November 2011, 14:56:31 »
Quote from: dorkvader;455661
Is there a difference? I checked the wiki, and you still need a "K" on the bottom row
I will!
Yes, there is a difference. Maybe you should clear the cache to see it.
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline zoidbergslo
« Reply #1701 on: Sat, 19 November 2011, 15:09:22 »
Is RETRO/FUNCTION32 all light blue on dark grey? FUNCTION32S and FUNCTION32T are for alternating. is that correct. Anyway looking for F1-F4 and F9-F12 in blue/darkgrey
Filco Tenkeyless
Offline Soarer
« Reply #1702 on: Sat, 19 November 2011, 15:19:19 »
Quote from: 7bit;455526
BTW: we are at more than 40,000 key caps!
Have you found anyone willing to distribute them yet?
Offline 7bit
  • MX1A-G1DW
« Reply #1703 on: Sat, 19 November 2011, 15:29:31 »
Quote from: zoidbergslo;455684
Normally function keys are alternating in color.
FUNCTION32
FUNCTION32S
FUNCTION32T
are non-alternating add-ons in the modifier/function key color (in this case lightblue on dark grey).
Maybe I add a FUNCTION12 kit ...
Offline 7bit
  • MX1A-G1DW
« Reply #1704 on: Sat, 19 November 2011, 15:31:31 »
Quote from: Soarer;455688
[size=12]YES!
Me![/size]
Offline zoidbergslo
« Reply #1705 on: Sat, 19 November 2011, 16:10:12 »
Quote from: 7bit;455694
That would be even better. :) Lets just hope 25 people want non-alternating function row.
Filco Tenkeyless
Offline s0b
« Reply #1706 on: Sat, 19 November 2011, 18:51:58 »
Quote from: 7bit;455657
Just send it off to 7bit_R4 and you will see ...
I'm asking if I am forgeting something to get the full set
« Reply #1707 on: Sat, 19 November 2011, 18:52:33 »
Quote from: 7bit;455672
Oops, my bad. I completely forgot about that.
Looks good now.
Offline Autolyze
« Reply #1708 on: Sat, 19 November 2011, 18:59:52 »
Quote from: s0b;455790
You're not forgetting something. You should just need STANDARD and SPACE to have all the keys for a full-sized (ANSI) Filco. I'm not sure about the Spanish keys, but I'm assuming you're good with the ES kit.
Offline dux
« Reply #1709 on: Sat, 19 November 2011, 19:27:46 »
Is anybody taking the slovenian kit? If yes, in what style? I would maybe join.
Offline godofdeath
« Reply #1710 on: Sat, 19 November 2011, 21:27:23 »
question on the number pad keys
they dont have the stuff like up/down/left/right arrows and stuff like pg up and down?
Offline maladroid
« Reply #1711 on: Sun, 20 November 2011, 00:22:00 »
Yes, please.  I've never understood the point of having alternating colors of function key groups.
Offline Kurk
« Reply #1712 on: Sun, 20 November 2011, 06:27:57 »
Thanks for fixing the Dvorak set! Ordering today...
Offline 7bit
  • MX1A-G1DW
« Reply #1713 on: Sun, 20 November 2011, 07:21:51 »
Quote from: godofdeath;455857
You are the first to ask.
Maybe, for the off-center styles, I could add these ...
Offline Soarer
« Reply #1714 on: Sun, 20 November 2011, 07:47:34 »
Making sure the SPACENEW is correctly specified, since the graphic from Round 3 resulted in the middle stem being offset to the wrong side.
Quote from: Round 4 Wiki
SPACENEW 6 units, 114mm wide, 3 keymounts, 38mm and 57mm apart
Going from left to right, the spaces between stems should be 57mm and 38mm; the switch is offset to the right hand side.
Here is a corrected graphic, I've just moved the stem. I also noted the view - it would be wise to add such a note to all drawings.
[ Attachment Invalid Or Does Not Exist ] 32492[/ATTACH]
Offline Soarer
« Reply #1715 on: Sun, 20 November 2011, 07:57:15 »
Can SP do space bars that are 3 units wide? And/or 2 units wide, POS-style?
Offline kps
« Reply #1716 on: Sun, 20 November 2011, 09:15:21 »
Quote from: Soarer;456017
You can see what shapes they have available in the PDFs here. They don't have any space bars that small. My understanding is that they will make new molds if you give them a million billion zillion dollars.
Offline 7bit
  • MX1A-G1DW
« Reply #1717 on: Sun, 20 November 2011, 09:30:23 »
DCS:
3<---normal key profile
4.5
5
6
6.2
6.75
7
8
9
9.75
10
SA:
3<---------normal key profile
4
6.25<------available in Round 4 for the first time ever!
7<---------available in Round 4 for the first time ever!
8
9
I've corrected the wiki.
« Reply #1718 on: Sun, 20 November 2011, 11:33:47 »
Quote from: 7bit;456049
DCS:
4.5
5
6
6.2
6.75
7
8
9
9.75
10
SA:
4
8
9
Wow, they have 10-unit spacebars? depending on where the mounts are, I could maybe get a replacement for my WYSE keyboard.
Offline dux
« Reply #1719 on: Sun, 20 November 2011, 11:48:22 »
Some thoughts on RGB sets: they are OK supplementing the existing styles.
But, an universal symbol RGB is needed.
The faux Cherry (from moogle) is not as nice as I thought it would be. The font is to thick, doesn't go with Cherrry keycaps. The only solution is to ban text. RGB with diamond, triangle etc instead of Control, Alt, Super, and Shifts with symbol. Am I the only one with the idea?
Offline godofdeath
« Reply #1720 on: Sun, 20 November 2011, 12:46:32 »
Quote from: 7bit;456009
if you could add those that would be awesomeeeeeeeeeeeee
want it to look as stock as possible with the keys
lemme know if you do then i will probably buy like 2 kits
Offline HWI
« Reply #1721 on: Sun, 20 November 2011, 22:51:22 »
I want:
NOIR/TENKLESS
NOIR/SPACE
but how do I add KEYBOARDLOVER to that? just:
NOIR/KEYBOARDLOVER or what?
I read through the wiki, but I wasn't 100% sure.
Bottom Out Like A Boss
Razer BWU | Ducky DK-1087 | Noppoo Choc Mini | CM Storm QFR | KBT Race
Offline Culinia
« Reply #1722 on: Mon, 21 November 2011, 04:16:42 »
How do I find out who vote for what? Is this group buy going buy the minimum quantity at set price?
I was going to order a noir/colemak/uk key caps but not sure how many people vote what? It don't seem that many people buying colemak this round (skimming back a few posts back) so I don't want to pay for 10 of them, lol) plus there's the backspace/caps lock situation...
Offline 7bit
  • MX1A-G1DW
« Reply #1723 on: Mon, 21 November 2011, 12:41:34 »
Quote from: Culinia;456621
Code: [Select]
SPH/DE..............1
SPH/SE..............2<---- 3 are too few
SPH/FR..............1<---- too few
SPH/BEPO............9<---- OK, gets support anyway.
SPH/DVORAK..........1<---- too few
SPH/COLEMAK.........1<---- too few
ROUND3/DE...........1
ROUND3/SE...........2<---- 3 are too few!
ROUND3/ES...........1<--- there might be an ES kit left over from Round 3
ROUND3/FR...........2<--- I'm not sure about the FR kit.
RETRO/DE............4
RETRO/DK............1
RETRO/FI............1<----- 10 altogether.
RETRO/SE............3
RETRO/UK............1
RETRO/FR............1<----- toooo few!!
RETRO/ES............2<---- too few, or expensive NORDIC kit
RETRO/COLEMAK.......2<---- too few!
NOIR/DE.............3
NOIR/FI.............2
NOIR/SE.............4<----- 10 altogether.
NOIR/UK.............1
NOIR/ES.............1<---- This makes the NORDIC kit expensiv!
NOIR/FR.............4<---- OK
NOIR/BEPO...........1<---- just one is too few.
DARK/FR.............1<---- I would not bother with that.
                                     You will not be able to read the
                                     black on very dark grey lables anyway!
DARK/DE/ORANGE......5
DARK/DK/ORANGE......1
DARK/SE/ORANGE......4<----- 10 altogether.
DARK/US/ORANGE......1<----- no problem.
                                      This is just JRET plut 1.25 units Shift
DARK/FR/ORANGE......1<----- too few.
BTW, we are at 42000 key caps.
« Last Edit: Mon, 21 November 2011, 12:44:02 by 7bit »
Offline 7bit
  • MX1A-G1DW
« Reply #1724 on: Mon, 21 November 2011, 13:59:46 »
Anybody in for this:
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #1725 on: Mon, 21 November 2011, 14:19:26 »
Quote from: 7bit;456841
Yeah, I would be.
Fight For Freedom. Stand with Hong Kongers
Offline Tarkoon
« Reply #1726 on: Mon, 21 November 2011, 14:25:38 »
Blood red on bright white would be much cooler!
That on a black case would look awesome!!!
I would take 2 or 3 sets of these...
« Last Edit: Mon, 21 November 2011, 14:42:27 by Tarkoon »
Offline zulios
« Reply #1727 on: Mon, 21 November 2011, 14:42:30 »
Quote from: 7bit;456795
If you need 4 ROUND3/FR kits to make sure they will get done, I can help in supporting that.
Tipro matrix - mx black
Offline zulios
« Reply #1728 on: Mon, 21 November 2011, 14:43:53 »
Quote from: Tarkoon;456856
That was part of the BIANCO style, which got removed due to lack of interest unfortunately.
Offline Tarkoon
« Reply #1729 on: Mon, 21 November 2011, 15:47:19 »
Bianco was black on white as far as I know, not blood red on white. Or am I wrong?
I can't imagine a better color combination than that.
Offline 7bit
  • MX1A-G1DW
ˇbump!
« Reply #1730 on: Mon, 21 November 2011, 16:10:51 »
Did you know?
SYMBOLS and SYMBOLSISO are available in any style!
SYMBOLS kit
    * MARROWUP100R1 1 unit, row 1
    * MARROWDN100R2 1 unit, row 2
    * BACKSPACE200 2 units, row 1
    * TABARROW150 1.5 units, row 2
    * HANDBAGCAP 1.75 units, row 3
    * ARROWUPMOD225 2.25 units, row 4
    * ARROWUPMOD275 2.75 units, row 4
    * ARROWRET 2.25 units, row 3
    * CARROWS 1 unit, row 4 (4 arrows for the cursor block)
SYMBOLSISO kit
    * ARROWUPMOD125 2.25 units, row 4
    * ARROWJRET J-shape return
To get these send the following to 7bit_R4 :
SPH/SYMBOLS
ROUND3/SYMBOLS
RETRO/SYMBOLS
NOIR/SYMBOLS
DARK/SYMBOLS
DARK/SYMBOLS/ORANGE
SPH/SYMBOLSISO
ROUND3/SYMBOLSISO
RETRO/SYMBOLSISO
NOIR/SYMBOLSISO
DARK/SYMBOLSISO
DARK/SYMBOLSISO/ORANGE
Offline Fred
« Reply #1731 on: Mon, 21 November 2011, 16:17:58 »
Ah, shame on the sph/se. : /
Red on black is teh sexee, but then there's the /se issue all over again.
Offline 7bit
  • MX1A-G1DW
« Reply #1732 on: Mon, 21 November 2011, 16:25:25 »
Quote from: Fred;456949
Congratulation for the 1776th post in this thread!
You won US-ANSI doubleshot key caps in blue, red and white with stars and stripes (stripes on the backsides of the keys) to be delivered in Round 5.
« Last Edit: Mon, 21 November 2011, 16:31:36 by 7bit »
Offline Lpb45
« Reply #1733 on: Mon, 21 November 2011, 16:26:29 »
Jeez 7bit this gb still hasnt gotten going yet?
Topre - 86U   |   Filco - Tenkeyless Linear Red
Filco - Tenkeyless Blue       |   Filco - Fullsize Non NKRO Blue (Work)
Offline Fred
« Reply #1734 on: Mon, 21 November 2011, 16:29:37 »
Quote from: 7bit;456954
Cobngratulation
Offline 7bit
  • MX1A-G1DW
« Reply #1735 on: Mon, 21 November 2011, 16:31:00 »
Quote from: Lpb45;456957
:~> grep Lpb45 userlist*
What is this?
Go! read this: http://deskthority.net/wiki/Round4
And order key caps!
Offline godofdeath
« Reply #1736 on: Mon, 21 November 2011, 16:41:39 »
any word on this?
Offline zulios
« Reply #1737 on: Mon, 21 November 2011, 16:47:05 »
Quote from: Tarkoon;456923
Different colors were available and I clearly remember having been terribly tempted by red on white.
Offline jinzo.pk3
« Reply #1738 on: Mon, 21 November 2011, 20:01:11 »
Interested. Would this be NOIR with red text?
Offline Zehkul
« Reply #1739 on: Mon, 21 November 2011, 20:12:38 »
Ahh no not red on black, my wallet can't stand this!!
Thankfully I just want German layouts, so chances are high I might get spared xD
« Reply #1740 on: Mon, 21 November 2011, 20:16:21 »
7bit, red on black is going to be part of GB4?
« Reply #1741 on: Mon, 21 November 2011, 22:52:25 »
That's me. What about Kurrk's SPH/dvorak?
Order it!
Offline Skoobs
« Reply #1742 on: Tue, 22 November 2011, 01:14:39 »
if the arrow symbols were available for wasd keys i would grab a set.
Offline 7bit
  • MX1A-G1DW
« Reply #1743 on: Tue, 22 November 2011, 03:11:44 »
Quote from: Skoobs;457227
Could be arranged.
Just the arrows for row 2 and 3, or (at least for RETRO, BOIR and DARK) letter, plus arrow?
Offline 7bit
  • MX1A-G1DW
« Reply #1744 on: Tue, 22 November 2011, 03:14:32 »
Quote from: jinzo.pk3;457083
It would be easier to handle if it is its own style:
BLOOD
or
ROUGE
I don't want to mess up color-names and style-names.
Quote from: demik;457094
If I get 25 orders until the end of this month, it will!
Just need a quick decision what it should be called.
« Last Edit: Tue, 22 November 2011, 03:18:37 by 7bit »
Offline dux
« Reply #1745 on: Tue, 22 November 2011, 03:51:51 »
A spherical ISO-Return is not possible in the moment, am I right?
Offline kaiserreich
  • HHKB Elite
« Reply #1746 on: Tue, 22 November 2011, 03:52:08 »
Isn't the CARROWS set redundant for the SYMBOLS kit?
Anyone who orders a set of keys, already have them included in any of the TERMINAL/STANDARD*/TENKLESS/TKL kits.
Offline jinzo.pk3
« Reply #1747 on: Tue, 22 November 2011, 04:07:53 »
Quote from: 7bit;457259
I was more wondering if they would look reasonably similar, so that I could mix and match etc.
Offline cancelx
« Reply #1748 on: Tue, 22 November 2011, 04:38:05 »
The single GEEK HACK key in ROUND3 style can be ordered by ROUND3/GEEKHACK, right?
Model M SSK - WASD V1 - CM Storm QFR - Ducky Year of the Rabbit - Realforce 87U - WASD V2 - K-Type
Offline 7bit
  • MX1A-G1DW
« Reply #1749 on: Tue, 22 November 2011, 05:13:54 »
Quote from: dux;457267
There are keys for the position which will fit. But there is no real JRET available ...
Quote from: cancelx;457277
Right!
Quote from: kaiserreich;457268
CARROWS
NO!!!!! These are different arrows!
CARROWS and SYMBOLS and all those other kits contain Cherry-style symbols, while the arrow-keys in TERMINAL/STANDARD/... are SP-style arrows.
« Last Edit: Tue, 22 November 2011, 05:18:58 by 7bit »
