Author Topic: [GB] Double shot replacements ROUND FOUR! - SHIPPING!  (Read 1442764 times)
Offline TheProfosist
  • Custom Layouts Only!
[taking orders!] Double shot replacements ROUND FOUR!
« Reply #1650 on: Fri, 18 November 2011, 04:13:29 »
Quote from: 7bit;454628
Function row: All keys are in the TKL kits, except Tab and = .
yes and all the letter should be in any standard kit. the number pad should be in a full size minus the "0" and "+"
Also nonstandard would be "Del" and "End". Possibly "|\" and left "Shift" but those could be standards from a ISO layout board.
From Left to right other keys that wouldnt be standard would be "Control", "Fn", "Caps", "Alt", "Win", "Menu", and "Fn 2" and "Fn 3" coud just be "Fn" if that would help.
Offline 7bit
  • MX1A-G1DW
« Reply #1651 on: Fri, 18 November 2011, 04:57:55 »
Quote from: TheProfosist;454631
are you refering to the text size that I used? If so thats just a placeholder o what functions I would like the keys to have not the actual way I would like the legends to be. When I said I wanted legends to ba s close as possible what I meant was that the same function was written on the key cap. Im not too particular how it looks, though I would prefer a uniform look across all key caps.
Sorry didnt see the edit. So I would need TKL, NUMERIC, ans some random keys? How would I get the random ones?
I will add some keyboard specific MODIFIER kits which will contain the necessary Return key etc.
Buy key caps here: Round 5
Buy switches here: CherryMX
« Reply #1652 on: Fri, 18 November 2011, 05:00:33 »
Quote from: 7bit;454653
alright just let me know what I need to order
Offline Zehkul
« Reply #1653 on: Fri, 18 November 2011, 05:02:52 »
I'd prefer an arrow instead of the handbag, too (or the shout key ;P)
Anyways, great kit, thanks!
Are there still numbers on the arrows from CARROW?
Quote from: Razer1987;454568
page up and page down
Ah, thanks.
« Last Edit: Fri, 18 November 2011, 05:06:11 by Zehkul »
Offline 7bit
  • MX1A-G1DW
« Reply #1654 on: Fri, 18 November 2011, 06:35:36 »
Quote from: Zehkul;454656
These are arrow-keys for the cursor T.
Offline Zehkul
« Reply #1655 on: Fri, 18 November 2011, 07:58:06 »
Aren't those already included in the standard set?
/e Are you going to order together with the novelty group buy or is that canceled?
« Last Edit: Fri, 18 November 2011, 08:04:37 by Zehkul »
Offline wuzle
« Reply #1656 on: Fri, 18 November 2011, 09:24:22 »
I am still confused about how to get replacement keys for round 3 that had varying fonts, font sizes, and font spacing. To me the following all look different:
- Tab
- Control(Row 3 Caps lock replacement)
- Row 4 Controls
- Alt
- Meta
- Back Space
- Return
- Shift
From what I can tell I need to order a entire new Tenkeyless kit to get these. The modifier kit doesn't cover all these.
Offline 7bit
  • MX1A-G1DW
« Reply #1657 on: Fri, 18 November 2011, 10:21:24 »
Quote from: Zehkul;454700
The arrows in the standard kits are from SP, the arrows in the SYMBOLS kit are my own creation and should look as close to Cherry-arrows as possible.
Offline 7bit
  • MX1A-G1DW
« Reply #1658 on: Fri, 18 November 2011, 10:23:45 »
Quote from: wuzle;454733
- Tab
- Row 4 Controls
- Alt
- Meta
- Back Space
- Return
- Shift
I hope this time we can get one font-style. I will tell Melissa, which keys turned out perfect and which they should re-design.
« Reply #1659 on: Fri, 18 November 2011, 10:39:31 »
I'll buy it, too.
7 bit phantom will be excellent.
« Reply #1660 on: Fri, 18 November 2011, 10:48:29 »
Quote from: dorkvader;454803
I'll buy it, too.
I think I will be in for at least 3 of what ever I end up needing for this buy as that is the number of 7bit Phantoms that I will be making for my self and others.
Offline wuzle
« Reply #1661 on: Fri, 18 November 2011, 11:42:40 »
Quote from: 7bit;454787
So, do I need to buy the entire tenkeyless kit to get these replacements?
Offline 7bit
  • MX1A-G1DW
« Reply #1662 on: Fri, 18 November 2011, 12:45:14 »
Quote from: wuzle;454861
Yes.
Offline ishtob
« Reply #1663 on: Fri, 18 November 2011, 13:05:47 »
are we going to have a backspace key available for those who wnats it to be the 1.5 key that is current;y the backslash? (like the HHKB)
« Reply #1664 on: Fri, 18 November 2011, 13:08:10 »
Quote from: ishtob;454916
I believe thats what 7bit meant by "I will add some keyboard specific MODIFIER kits which will contain the necessary Return key etc." http://tinyurl.com/7yozapb
Offline Skoobs
« Reply #1665 on: Fri, 18 November 2011, 18:43:51 »
=O
that dark/black set is awesome... and double-shot... what material? not PBT im guessing... that would be too awesome.
also, will these fit the das keyboards?
and can we order anything off of the deskauthority wiki? like the dark/black lotus, dark/black jolly roger, etc?
« Last Edit: Fri, 18 November 2011, 18:54:27 by Skoobs »
Offline sinis
« Reply #1666 on: Fri, 18 November 2011, 19:07:29 »
Quote from: Skoobs;455176
what material?
ABS like all Doubleshots
yes, fits perfectly
you can order anything that is in the wiki
Offline Autolyze
« Reply #1667 on: Fri, 18 November 2011, 19:13:42 »
The keycaps in this group buy are all ABS. They will fit on a Das, but they will be a little shorter than the stock keycaps, so you should be aware of that if you're thinking of mixing the SP keycaps and the Das ones.
You can try to order anything off of the Round 4 wiki page, but if there are too few requests for a particular kit (style and key set combo), it probably won't get made. 7bit periodically posts the current number of orders for each kit.
Edit: Damn, too slow.
Offline Skoobs
« Reply #1668 on: Fri, 18 November 2011, 21:41:55 »
thanks guys!
Quote from: Autolyze;455182
damn, i may not do this then. i was thinking of just doing the numbers and modifiers, but i dont want them to look weird.
im really unsure as to how to order lol ive looked it over but its really daunting.
although im guessing even the modifiers will be different than the stock das caps.
i have some jolly rogers on order from the other thread (white on black) so i may see how those fit before i pick these up. i really would rather have the black on dark ones.
edit: i might just give it a try and order the ones i want. is there any way to get a full set of "DARK" keycaps that are blank? or only with the black symbols? like will there ever be a group buy for them in another thread or something?
to order, say, black on dark arrow keys, i would put
DARK/ARROWUP100
DARK/ARROWDOWN100
and to order a pirate set i would put
DARK/PIRATEFLAG
but how would i order multiples?
im not seeing left and right arrows, and i am not seeing them for wasd keys... is this right?
and i noticed there are full sets available... but once again, so i just put DARK/BLANKSTD ?
lol this is so confusing.
« Last Edit: Fri, 18 November 2011, 22:07:50 by Skoobs »
Offline sinis
« Reply #1669 on: Fri, 18 November 2011, 22:14:47 »
Quote from: Skoobs;455243
DARK/PIRATEFUN 2
for example.
what is the point of DOUBLEshots that are blank? blank doubleshots are no doubleshots! anyway you can order a complete set of blanks. I forgot the name of the set. it is in the wiki!
You can order a DARK/STANDARD for a complete set of doubleshots in the DARK style fitting your DAS. You need a DARK/SPACE bar too.
For only Arrow keys look at the GAMER sets. The GAMER sets include arrow keys and WASD in some different colors and fonts. Depending in which style you order it. For example the DARK/GAMER set come in orange if I read the wiki correctly.
The deadline on this is 30.November. You may wait for your delivery of your other groupbuy, but this groupbuy may be over then. There is however time to order a few days after 30.November afaik.
« Last Edit: Fri, 18 November 2011, 22:26:40 by sinis »
Offline RColinTaylor
« Reply #1670 on: Fri, 18 November 2011, 22:32:55 »
You can actually buy blanks from SP; they have them in stock and the prices are fairly reasonable.
I like my Browns more than my Blues.
Offline sinis
« Reply #1671 on: Fri, 18 November 2011, 22:34:17 »
Quote from: RColinTaylor;455273
they are still ABS.
If blanks there is only one choice: PBT
« Reply #1672 on: Fri, 18 November 2011, 22:36:58 »
Quote from: sinis;455275
they are still ABS.
Well yes; if you really want to do blanks right then get PBT.
« Reply #1673 on: Fri, 18 November 2011, 22:48:55 »
Quote from: RColinTaylor;455277
This is true.
Don't SP have a list of what PBT blanks they have in inventory? I thought I saw that in a .PDF on their 'site somewhere.
'cause SP PBT keys are excellent.
Offline Skoobs
« Reply #1674 on: Sat, 19 November 2011, 00:04:53 »
i just want the blanks to match the custom keys i get for double shots. i was thinking about getting a pirate set and maybe a couple others, but like someone said, the size is different than my das keys. and i am willing to bet the color is slightly different. so i wanted to get a set of blanks for all of the keys that i dont replace with the double shot ones.
ehh, i probably shouldnt be doing this now anyways, i will wait til my keys arent still brand new lol then maybe ill just get the dark set, and whatever custom ones i want so that other people can use my keyboard. people dontuse my blank one hahaha
« Last Edit: Sat, 19 November 2011, 00:08:53 by Skoobs »
Offline Skoobs
« Reply #1675 on: Sat, 19 November 2011, 00:10:13 »
Quote from: dorkvader;455291
This is true.
http://www.keycapsdirect.com/key-capsinventory.php
Offline 7bit
  • MX1A-G1DW
« Reply #1676 on: Sat, 19 November 2011, 04:05:49 »
Now available:
Code: [Select]
Order-ID     |qty|USD|description
APPLE        | 13| 18|Apple kit (2xcmd-sym, 2xOPT, 1, 1.25, 1.5 u)
APPLE100     |  4|  4|Apple kit (2xcmd-symbol, 2xOPT, 1 unit)
APPLE125     |  5|  6|Apple kit (2xcmd-symbol, 2xOPTION, 1.25 units)
APPLE150     |  4| 11|Apple kit (2xcmd-symbol, 2xOPTION, 1.5 units)
APPLETXT     | 13| 10|Apple kit (2xCMD, 2xOPT, 1, 1.25, 1.5 u)
APPLETXT100  |  4|  2|Apple kit (2xCMD, 2xOPT, 1 unit)
APPLETXT125  |  5|  4|Apple kit (2xCOMMAND, 2xOPTION, 1.25 units)
APPLETXT150  |  4|  4|Apple kit (2xCOMMAND, 2xOPTION, 1.5 units)
WINDOWS      |  9|  7|Windows kit (2xflag, 1xmenu, 1, 1.25, 1.5 u)
WINDOWS100   |  3|  2|Windows kit (2xflag, 1xmenu, 1 unit)
WINDOWS125   |  3|  3|Windows kit (2xflag, 1xmenu, 1.25 units)
WINDOWS150   |  3|  3|Windows kit (2xflag, 1xmenu, 1.5 units)
WINDOWSTXT   |  9|  7|Windows kit (2xWIN, 1xMENU, 1, 1.25, 1.5 u)
WINDOWSTXT100|  3|  2|Windows kit (2xWIN, 1xMENU, 1 unit)
WINDOWSTXT125|  3|  3|Windows kit (2xWINDOWS, 1xMENU, 1.25 units)
WINDOWSTXT150|  3|  3|Windows kit (2xWINDOWS, 1xMENU, 1.5 units)
Offline csm725
  • I BLEED RED AND GOLD
    • http://csm725.com
« Reply #1677 on: Sat, 19 November 2011, 04:14:39 »
Hey 7bit.
What would I order if I wanted an 87-key set for my Filco similar to Group Buy 3's?
How much would it cost?
Thanks a lot and I appreciate all your hard work!
« Reply #1678 on: Sat, 19 November 2011, 04:21:30 »
Its DCS for standard and DSS for spherical right?
Offline sinis
« Reply #1679 on: Sat, 19 November 2011, 04:24:50 »
Quote from: csm725;455364
Hey 7bit.
ROUND3/TENKLESS 57$
or
ROUND3/TKL 49$
these will fit a USA ANSI tenkeyless. If you have an ISO just take ROUND3/JRET for proper Enter and left Shift.
and
ROUND3/SPACE 2$
add your emailadress like:
EMAIL youremail@yourhome.xyz
EDIT: maybe you want a language kit, too.  And some fancy modifier keys, like ROUND3/RGB125 10$
« Last Edit: Sat, 19 November 2011, 04:29:54 by sinis »
Offline csm725
    • http://csm725.com
« Reply #1680 on: Sat, 19 November 2011, 04:27:12 »
(Picture by jpm)
The above except for Esc and KL is what I want.
Would it be TENKLESS or TKL?
Offline sinis
« Reply #1681 on: Sat, 19 November 2011, 04:33:39 »
Quote from: csm725;455367
they both have those keys. For the difference of TKL and TENKLESS you need to watch the wiki. Its Quite at the end.
But the \KL you need to order separately: ROUND3/KEYBOARDLOVER
 And the red one is not in this groupbuy. But I am shure you know that :)
« Last Edit: Sat, 19 November 2011, 04:36:17 by sinis »
Offline csm725
    • http://csm725.com
« Reply #1682 on: Sat, 19 November 2011, 04:36:44 »
I know that... I said I wanted everything in the picture EXCEPT Esc and KL :P
Why does TENKLESS cost more than TKL?
How do I set the colors to be like in the above pic?
BTW thanks for the help sinis. Nice avatar too ;)
Offline jpm804
  • KeyCap Assasin
« Reply #1683 on: Sat, 19 November 2011, 04:39:48 »
Quote from: csm725;455373
There is more key's in the TENKLESS kit (109) vs TKL (93)..
All this info is in the Round 4 wiki.
REALFORCE|FILCO|HHKB|KBC POKER X|LEOPOLD|CM STORM|SIIG (GHSS)|IBM SSK
Offline sinis
« Reply #1684 on: Sat, 19 November 2011, 04:44:51 »
by ordering the style ROUND3: You order the style by setting it before the set/key code:
STYLE/KEY
its all in the wiki. First paragraphs.
You are welcome. Thanks for the flowers :)
[ Attachment Invalid Or Does Not Exist ] 32423[/ATTACH]
Offline csm725
    • http://csm725.com
« Reply #1685 on: Sat, 19 November 2011, 05:11:03 »
ROUND3/TENKLESS
ROUND3/SPACE/GX
ROUND3/AWESOME100/ORANGE
email@email.com
Is that right?
Can I also order:
ROUND3/GAMER/ORANGE
« Last Edit: Sat, 19 November 2011, 05:16:25 by csm725 »
Offline sinis
« Reply #1686 on: Sat, 19 November 2011, 05:23:12 »
Quote from: csm725;455384
ROUND3/TENKLESS
ROUND3/SPACE/GX
email@email.com
Is that right?
Can I also order:
ROUND3/GAMER/ORANGE
include EMAIL:
Code: [Select]
ROUND3/TENKLESS
ROUND3/SPACE
EMAIL email@email.com
I dont know what you want with the "/GX" at the space. This is not valid!
if you want an orange GAMER it is the RETRO/GAMER/ORANGE. but the font is smaller than the ROUND 3 one.
ROUND3/GAMER is only in blue, black and red.
read the wiki please!
Offline csm725
    • http://csm725.com
« Reply #1687 on: Sat, 19 November 2011, 05:32:16 »
Ah, I see now regarding the space bar.
It seems that there is an Orange Round3 Gamer kit...
Code: [Select]
ROUND3/TENKLESS
ROUND3/SPACE
ROUND3/GAMER
That would be Gamer in Orange by default, no?
Offline Kurk
« Reply #1688 on: Sat, 19 November 2011, 05:47:18 »
Hi 7bit (and others knowledgable in the art of ordering),
A few questions:
1)
The DVORAK kit contains 22 caps according to the wiki. However I expect 24 keys, see picture: http://i.imgur.com/2To15.jpg
2)
Say I want to order a complete set of spericals for my Filco in Dvorak layout. Would this order be correct?:
SPH/TENKLESS
SPH/SPACE
SPH/DVORAK
3)
What are the chances for dvorak kits? Are there any dvorak kit(s) likely to go into production?
4)
I'm still confused by the wiki... major question: Are all kits available in all styles? E.g. SPH/MODIFIER or SPH/RGB ?
5)
Will there be opportunity at the end of this group buy (after Nov 30th) to change my orders to those kits that actually go into production?
Cheers,
 -Kurrk
Offline sinis
« Reply #1689 on: Sat, 19 November 2011, 05:52:26 »
Quote from: csm725;455390
Code: [Select]
ROUND3/TENKLESS
ROUND3/SPACE
ROUND3/GAMER
you are completely right!
sorry, my bad!
This is the exact code you can send and wait for answer. Answers should come a few times a day. Have fun ordering :)
Quote from: Kurrk;455392
A few questions:
sorry, but too special....dunno   ... :noidea:
« Last Edit: Sat, 19 November 2011, 05:58:44 by sinis »
Offline s0b
« Reply #1690 on: Sat, 19 November 2011, 08:05:48 »
Can someone post a image of a tenkeyless kb with spherical keycaps to see how it looks?
Soon i'll do my order :)
Very much thanks!
Offline zulios
« Reply #1691 on: Sat, 19 November 2011, 08:18:54 »
Quote from: s0b;455414
Very much thanks!
The closest you may find is the photos taken from that topic :
http://deskthority.net/viewtopic.php?p=23509
SPH style is pretty much the same as this board.
« Last Edit: Sat, 19 November 2011, 08:21:25 by zulios »
Tipro matrix - mx black
Offline 7bit
  • MX1A-G1DW
« Reply #1692 on: Sat, 19 November 2011, 10:51:00 »
A few questions:
1)
What is missing?
2)
SPH/TENKLESS
SPH/SPACE
SPH/DVORAK
3)
4)
This depends on how many people will order them.
5)
Cheers,
 -Kurrk
Yes, you can change your order for quite a long time after the Nov 30th, becuase I've got to wait for a price quote and then I've got to wait for everybody ordering more stuff and then I will lower the prices and then even more will be ordered ....
You will be notified when we start collecting money!
« Reply #1693 on: Sat, 19 November 2011, 11:33:29 »
Quote from: 7bit;455472
What is missing?
Looks like we need to add a "K" to row4.
nubsa re another difference: he's not swapped the H and J keys to the other keyboard. It's not an issue, because they are replaced in this set anyway, but do we need nubs on H and U? I notice U is replaced anyway, but H is just moved over one, and won't have a nub.
so there are three differences: U, H, K; one is irrelevant, because "U" is replaced anyway. H is on the same row, and could theoretically be moved over, but won't have a nub or whatever.
so, you'd have to add a nub U, a nub H, and a K to row4 to be fully compliant. For sets without nubs (or people that don't need them, like me) only a "K" is needed in row4.
Also, I really want to order a Dvorak kit (especially in spherical), but I don't think the quantity will be high enough. :(
« Last Edit: Sat, 19 November 2011, 11:36:36 by dorkvader »
Offline 7bit
  • MX1A-G1DW
« Reply #1694 on: Sat, 19 November 2011, 11:47:28 »
Quote from: dorkvader;455499
Better now?
About minimum quota:
Just order, don't worry ...
Offline 7bit
  • MX1A-G1DW
« Reply #1695 on: Sat, 19 November 2011, 11:49:05 »
I've updated quite a bit:
Also available:
FUNCTION32S (add-on for STANDARD kit / 28 function keys, F1-F4, F9-F12, F13-F32 in one color)
FUNCTION32T (add-on for TERMINAL kit / 16 function keys, F5-F8, F17-F20, F25-F32 in one color)
These are add-on kits for Apple and Windows lusers:
Code: [Select]
Offline 7bit
  • MX1A-G1DW
« Reply #1696 on: Sat, 19 November 2011, 12:04:32 »
BEPO
STANDARD125
STANDARD150
BTW: we are at more than 40,000 key caps!
« Last Edit: Sat, 19 November 2011, 12:18:24 by 7bit »
Offline s0b
« Reply #1697 on: Sat, 19 November 2011, 13:37:49 »
Is my fist group buy. Can someone check if this order is ok to dress two full filco layouts?
SPH/STANDARD
SPH/SPACE
SPH/AWESOMEFUN
SPH/ES
ROUND3/STANDARD
ROUND3/SPACE
ROUND3/AWESOMEFUN
ROUND3/BACKSPACEFUN
ROUND3/GAMER
ROUND3/ES
Very much thanks!
Offline 7bit
  • MX1A-G1DW
« Reply #1698 on: Sat, 19 November 2011, 14:38:47 »
Quote from: s0b;455602
SPH/STANDARD
SPH/SPACE
SPH/AWESOMEFUN
SPH/ES
ROUND3/STANDARD
ROUND3/SPACE
ROUND3/AWESOMEFUN
ROUND3/BACKSPACEFUN
ROUND3/GAMER
ROUND3/ES
Very much thanks!
Just send it off to 7bit_R4 and you will see ...
« Reply #1699 on: Sat, 19 November 2011, 14:41:34 »
Quote from: 7bit;455508
Better now?
Is there a difference? I checked the wiki, and you still need a "K" on the bottom row
I will!
