Author Topic: Cherry G80-11908HWMGB (Seller Refurbished)  (Read 3800 times)
Offline squarebox
  • In Omnia Paratus
Filco Yellow Edition  | Filco Brown | Filco 2 Brown TKL | G80-1950 | G80-3494 | G80-11900 | Leopold FC500R | Noppoo Choc Mini
Offline BiNiaRiS
« Reply #1 on: Sun, 31 July 2011, 15:32:15 »
British layout makes even less keys usable though
Sent from my EVO
KMAC 2 w/ErgoClears
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Sun, 31 July 2011, 16:11:26 »
this one is a better deal for a doubleshot harvest, it's nib. or this one, if they take a lower offer.
« Last Edit: Sun, 31 July 2011, 16:23:57 by lysol »
Offline N8N
« Reply #3 on: Sun, 31 July 2011, 16:17:16 »
eh, not really - I have one like it, you're missing not only the whole bottom row, but also the right shift, numpad zero, and numpad plus (assuming that you are using a 104) even if you have a TKL you still need the right shift.
Honestly, I'm starting to see the wisdom of just buying the $80 sets that the guy on HK is selling.
« Reply #4 on: Sun, 31 July 2011, 16:31:00 »
Sometimes a good price on even a usable 37 set can be an attractive buy. Using blanks for the rest can look pretty good too. I had one of my boards set up like that for awhile. It all depends on what you want. If you are going for a full set there are better options than the 1800 style for sure.
Offline xbb
« Reply #5 on: Sun, 31 July 2011, 17:41:01 »
remember this is UK layout... not so common.
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #6 on: Tue, 02 August 2011, 00:41:31 »
How can you tell what on ebay is double shot and what isn't?
Offline sordna
« Reply #7 on: Tue, 02 August 2011, 00:49:28 »
My undersdanding is that an "H" in Cherry keyboard model numbers means High quality keycaps: doubleshots.
Offline BiNiaRiS
« Reply #8 on: Tue, 02 August 2011, 01:47:17 »
Quote from: sordna;391432
That is the most important factor. And if a board has custom keys those will usually be lasered. Once you've dealt with them enough you can usually spot them easily with a decent photo.
KMAC 2 w/ErgoClears
Offline Atenacius
« Reply #9 on: Tue, 02 August 2011, 09:58:09 »
The g81-8000 is a pretty good donor for full-sized keyboards since everything works except for the front row and caps lock
Keychron Q6 GATERON G PRO YELLOW
Vortex Pok3r CHERRY MX RED
Das Keyboard Model S CHERRY MX BLUE
IBM Model M
1391401 09 MAR 93
