Author Topic: Problem with Noppoo Mini Choc  (Read 2243 times)
Offline xEndeavor
« on: Mon, 01 August 2011, 15:34:58 »
I just purchased a Noppoo Mini Choc MX Brown and it arrived today. I'm using Win7 64 bit and for some reason when I plug the keyboard in, all the LED lights consistently flash and no keypresses register. Likewise when I plug the keyboard up and reboot my computer, I'm stuck at the bios screen.
Anyone have a clue as to what's wrong?
Offline xEndeavor
« Reply #1 on: Mon, 01 August 2011, 16:31:19 »
bump.
Desperate for some assistance here!
Offline dfour
« Reply #2 on: Mon, 01 August 2011, 16:43:11 »
Have you tried a different USB port. What about a completely different computer?
Offline AUAnonymous
« Reply #3 on: Mon, 01 August 2011, 17:25:23 »
I'm using that keyboard on Win 7 x64 and I've never experienced any problems like the ones you've described, so it's definitely not an OS issue.
Noppoo Choc Mini (MX Blacks) - First mechanical keyboard :D
Why don\'t you give Colemak a try? You\'ll like it, I promise.*
*Not a real promise
Offline xEndeavor
« Reply #4 on: Mon, 01 August 2011, 21:41:34 »
I tried every USB port on my computer and it still does not work. This time the switch key light only blinks and when I press a key, all other LED lights flash.
Offline sordna
« Reply #5 on: Mon, 01 August 2011, 22:41:04 »
Try it on some other computer, if you see the same issues, the keyboard is probably defective.
Offline xEndeavor
« Reply #6 on: Mon, 01 August 2011, 23:50:14 »
I tested it on both my destop and laptop and I have the same issue. Don't suppose there's some sort of driver update for the board perhaps? I dunno.. guess it's time to send it back
