Author Topic: Computer power up and IBM M 1391401  (Read 1556 times)
Offline genegold
« on: Wed, 03 August 2011, 18:13:03 »
It's been a couple of years since I posted here, during which time the Model M has served me very well.  Since I've got a new CPU on the way, last night I updated the BIOS on my GA-MA790X-UD4P motherboard from version F4 to F9 (update list: http://www.gigabyte.com/products/product-page.aspx?pid=3038#bios).  The problem since then is that my computer will no longer turn on from the console's Computer/Master switch, but requires use of the case button.  What I'm seeing when I turn on the console master/computer switch (or button) is the monitor and keyboard lights come on, but the latter then go out quickly; there is nothing turning in the computer and the mouse doesn't illuminate.  What I'm wondering, and the reason I'm posting here, is whether or not those keyboard lights going out might be a sign that the the updated BIOS is not compatible with the Model M; i.e., the keyboard is killing the computer start.  Any thoughts?  Thanks,
Offline REVENGE
« Reply #1 on: Wed, 03 August 2011, 18:26:15 »
By the console, you mean a power console / power strip? It may have to do with your BIOS's power state after power loss option. Make sure it is set to power the computer on after a power loss event. I'm guessing this has nothing to do with your Model M.
Offline genegold
« Reply #2 on: Wed, 03 August 2011, 18:39:05 »
Yes, you're correct on both counts.  After power loss was the setting I was looking for.  Thanks!
Offline False_Dmitry_II
« Reply #3 on: Wed, 03 August 2011, 18:42:59 »
To me, that seems like an odd way to turn on a computer.
But then, mine is on a UPS so doing something like that wouldn't actually work at all for me.
Offline REVENGE
« Reply #4 on: Wed, 03 August 2011, 19:13:04 »
Quote from: False_Dmitry_II;392504
I think it's rather old fashioned, but a college buddy did the same thing. *shrug*
Offline genegold
« Reply #5 on: Wed, 03 August 2011, 22:47:46 »
Just saves a step.  I'm not aware of any harm in starting that way.
