Author Topic: Converting XT to AT  (Read 1639 times)
Offline Clickey
Converting XT to AT
« on: Wed, 17 August 2011, 23:22:35 »
I want to try a model F, but the AT ones are so much more expensive. Will this convert XT to AT?
http://cgi.ebay.com/Symbol-STI80-0100-Keyboard-Synapse-Cable-Adapter-AT-XT-/150642380960?pt=PCA_Mice_Trackballs&hash=item2312fc50a0
It has no useful description, and im not sure if the seller either mislabeled it, or if its just to convert an rj type connector TO an AT/XT.
"we are on Geekhack not Lazy****" - The Solutor
Offline didjamatic
Converting XT to AT
« Reply #1 on: Wed, 17 August 2011, 23:28:37 »
I don't think so, that takes input from a barcode scanner and splits to either XT or AT but it's not a converter between the two.  However, there is a similar adapter I've seen on ebay that I thought might do it.
Offline SmallFry
Converting XT to AT
« Reply #2 on: Mon, 22 August 2011, 10:40:49 »
Use Soarer's Teensy adapter...If I recall it converts XT to AT. I've been meaning to do such, but I'm too broke to buy a Teensy.
Offline Soarer
Converting XT to AT
« Reply #3 on: Mon, 22 August 2011, 11:49:32 »
My code on a Teensy will convert either XT or AT, to USB :-)
