Author Topic: Filco Minus Key does not register - please help  (Read 1568 times)
Offline davin
« on: Tue, 30 August 2011, 08:38:18 »
Dear All,
I have a strange problem with my Filco keyboard.
Recently the minus key on the keypad stopped registering.
The key does a full traversal but does not register.
When i push on the side a little bit, and here have to use much more force, then it registers.
Can anybody give me some advice how i can resolve this issue ?
Regards,
davin
Offline redpill
« Reply #1 on: Tue, 30 August 2011, 08:42:39 »
What type of switches are they?  First thing to try is blowing compressed air into the switch, there could be a foreign particle in there that is preventing contact from being made.
^ Current Favorite ^  Topre Realforce 87UB 55g  |  Topre Realforce 103UB 55g | KBC Poker/Browns/Sanded Keycaps |  Ducky 1087 | Filco MajesFoam-2 | IBM Model M 1390131 Feb '87 | Still Love: Microsoft Trackball Explorer x3 | Now Unused:  Microsoft Natural Ergo 4k x2
Offline itlnstln
« Reply #2 on: Tue, 30 August 2011, 09:15:43 »
As long as it doesn't ping, it should be fine.
Offline Lanx
« Reply #3 on: Tue, 30 August 2011, 10:27:48 »
imo remove the keyboard and look underneath with it still plugged into the computer, take a wire or something metal and create a connection between the two points of contact with the minus key. If you see a minus on the screen then i guess
1. switch bad
2. resolder, pin is off.
Offline davin
« Reply #4 on: Tue, 30 August 2011, 13:52:06 »
Hi
Thanks for all the suggestions;
They are blue MX switches btw.
I will take the keyboard home and try some compressed air, or check underneath the key.
Regards
Offline davin
closed
« Reply #5 on: Wed, 31 August 2011, 07:14:41 »
closed
