Author Topic: What kind of switches are in this? CHERRY G81-1800LPMUS-2  (Read 6523 times)
Offline silverphoenix
« on: Fri, 02 September 2011, 13:54:46 »
http://www.newegg.com/Product/Product.aspx?Item=N82E16823333054
[ Attachment Invalid Or Does Not Exist ] 25562[/ATTACH]
I'm trying to find any information on the type of switches, they are just listed as mechanical.
Offline Symmetry
« Reply #1 on: Fri, 02 September 2011, 14:03:44 »
Wow, a Cherry spacesaver with tenkey for $60! That's a deal and a half, assuming it has MX switches (which I can't imagine being otherwise).
Offline itlnstln
« Reply #2 on: Fri, 02 September 2011, 14:07:50 »
Let's just say, "you'll be very disappoint."
Offline N8N
« Reply #3 on: Fri, 02 September 2011, 14:15:00 »
I'll send you one w/o keycaps for shipping + beer money, but I wouldn't recommend that you buy it.  I'm not a big fan of the MY switches, but I guess maybe if you like heavy linear switches they might be OK.  But even so I'd recommend you just get a board w/ blacks in that case.  (mine did have a nice set of black doubleshots on it, which is the main reason that it hasn't hit the trash yet.)
Offline Ekaros
« Reply #4 on: Fri, 02 September 2011, 14:42:39 »
G81 -> DON'T BUY FOR USIGN!
G80 is MX-series, G84 for ML, some strange people might like...
So I should add something useless here yes? Ok, ok...
Filco 105-key NKRO MX Browns Sw/Fi-layout|IBM Model M 1394545 Lexmark 102-key Finnish-layout 1994-03-22|Cherry G80-3000LQCDE-2 with MX CLEAR
[SIGPIC][/SIGPIC]
Dell AT102W(105-key SF) (Black ALPS)|Steelseries Steelkeys 6G(MX Black) ISO-FI-layout|Cherry G84-4400 G84-4700 Cherry MLs
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5 on: Fri, 02 September 2011, 16:55:13 »
MY switch, maybe just a hair better than rubberdomes depending. I would suggest to look on ebay instead, as a lot of the time you can find the g80 mx switch with the same layout for close to the same price or cheaper, sometimes new in box. Probably the best bargain for a similar MX keyboard is this one, though it has an integrated trackpad and an Italian layout.
Offline Cherry Keyboards
« Reply #6 on: Tue, 06 September 2011, 10:22:54 »
The G81-1800 series uses the FTSC key technology. It is a mechanical switch that presses on a Mylar membrane. You should look at the G80-1865LXNEU-2 if you want the 1800 style footprint/layout with brown MX keysswitches. If you want the blue MX switches you can go with the full sized G80-3000LSCEU-2.
Offline BiNiaRiS
« Reply #7 on: Tue, 06 September 2011, 11:26:10 »
Quote from: lysol;409619
G80-1800s are extremely rare in ANSI layout. I've seen 2 on ebay in the last 4 months
Sent from my EVO
KMAC 2 w/ErgoClears
Offline itlnstln
« Reply #8 on: Tue, 06 September 2011, 12:01:27 »
Quote from: BiNiaRiS;411401
Sent from my EVO
PCHome has them (see WW Buying Links).  Pricey but not all that rare anymore.  That's one reason why I ended up selling mine.  Also, the page nav cluster is in a crappy spot.
Offline AlleyViper
« Reply #9 on: Tue, 06 September 2011, 16:02:10 »
For gaming, it's like a heavier black MX with smother action and less key wobble. The extra force will only really bother at the second half of  travel (at least with heavier double-shots).
It's not recommended for typing, but imho it's easier to avoid bottoming out than with MX blacks, simply because you can't do it with the same light touch (crazy ~110g at the end of travel, two springs) and doing so will get you tired quickly, so you adapt in no time (for the wrong reason).
To rephrase it, avoid G81 when in doubt. It has that feeling of something made to outlast you, but not to be comfortable.
(I like them a lot)
