Author Topic: Clear Transparent Numpad / Tenkey Keycaps  (Read 3426 times)
Offline litster
  • Trade Count: (0)
  • rare caps?! THAT'S A SMILIN
« on: Tue, 06 September 2011, 11:01:54 »
If you purchased a full 104 set of clear, transparent keycaps from Round 3 group buy, but don't need the tenkey numpad part, I would love to buy it from you.  Let me know.  I would like to use a clear keycaps for my Goldtouch numeric keypad Cherry Switch Tester.  Thanks.
Offline redpill
  • Trade Count: (0)
« Reply #1 on: Tue, 06 September 2011, 13:05:13 »
I may be able to work something out with you.  I'll probably be ordering a 104-key clear set off ebay assuming I get the other keyboards I need for a project I'm working on, and I won't be needing the numberpad keys.
^ Current Favorite ^  Topre Realforce 87UB 55g  |  Topre Realforce 103UB 55g | KBC Poker/Browns/Sanded Keycaps |  Ducky 1087 | Filco MajesFoam-2 | IBM Model M 1390131 Feb '87 | Still Love: Microsoft Trackball Explorer x3 | Now Unused:  Microsoft Natural Ergo 4k x2
Offline mmmty
  • Trade Count: (0)
  • bang! bang!
« Reply #2 on: Tue, 06 September 2011, 13:18:49 »
I have a set. Got them from here (#5) http://geekhack.org/showthread.php?21674-Lots-of-key-caps-for-sale.-104-clear-37-PBT-Customized-keys-and-Aluminum-keys.
The white stabilizer inserts from my Filco won't complete go in on the 3 big keys (too long). So you'll have to cut/file them. I'm looking for $25 shipped. Let me know. Keycaps are unused. I just put them on my Filco for testing.
« Last Edit: Tue, 06 September 2011, 13:22:36 by mmmty »
Keyboardless
Offline mmmty
  • Trade Count: (0)
  • bang! bang!
« Reply #3 on: Tue, 06 September 2011, 13:40:29 »
No, those smokey ones are from #1. Mine are from #5 on the list.
They're supposed to look like these. It depends on the angle when you look at the keycaps.
The stabilizer inserts fit in the holes but won't go all the way in.
[ Attachment Invalid Or Does Not Exist ] 26019[/ATTACH]
« Last Edit: Tue, 06 September 2011, 13:44:02 by mmmty »
Keyboardless
Offline litster
  • Trade Count: (0)
« Reply #4 on: Tue, 06 September 2011, 14:35:12 »
Thanks for your response, redpill and mmmty.  I ended with your mmmty's set since he is ready to ship.  Thank you all.
