Author Topic: Fujitsu Peerless thing  (Read 1953 times)
Offline EverythingIBM
« on: Fri, 09 September 2011, 23:57:58 »
So I've acquired a keyboard from my friend.
I'm under the assumption it's a "fujitsu peerless". It has a spring with a rubberdome thing underneath.
What is the whole deal with these things? For typing, the keys do have sort of a "click", but it's incredibly stiff. Even more stiff than a model M. The spacebar is very hard for me to actuate while typing. Even if I press it, it doesn't signal due to the need to hit it incredibly far & hard since the dome acts as the buckling mechanism?
It's totally bizarre. The indicator lights are integrated in the respective keys; I don't like that.
« Reply #1 on: Sat, 10 September 2011, 00:50:51 »
Quote from: ripster;413783
Got any nickels for a RipOmeter test?
I have a friendly debate going on at Deskthority.net on the Fujitsu Peerless.
I have canadian nickels, but probably like only one USA one.
Here's the backside:
MODEL FKB4700 SERIES
FCC ID: C9S4D8KB4700
FUJITSU LIMITED
MADE IN JAPAN
« Reply #2 on: Sat, 10 September 2011, 16:50:15 »
Quote from: ripster;413923
See RipOmeter for Canadian nickel values.  Depends on the year.
You'll need 70-90g of them.  That sucker is stiff.
Me posting this got me banned at Deskthority.net for "threadcrapping".
Okay I'll drop a few on it later. It'll take a lot, though.
You can actually fatigue your hands incredibly well with a peerless. I wager the reason for the stiffness lies in the fact that the spring doesn't "buckle", so it's similar to the C64's awful keyboard.
