Author Topic: Filco Majestouch 2 Keycaps  (Read 3480 times)
Offline darkblader
« on: Sat, 10 September 2011, 12:54:18 »
Hi all :flypig:
I got a little problem, my keys are getting shinny from my Majestouch 2 105 (German Layout).
The problem is i only can find keycaps for the 104 filco.
Do Cherry G80 / G81 keycaps fit into the Filco? Or do they have a different shape?
CPU : Intel Core i7 920 @ SNK-P0035AP4 | RAM : takeMS 12 Gb DDR3-1333 | GPU : AMD FirePro V4800 1Gb | MOBO : DFI LANparty JR X58-T3H6 | SSD1 : Crucial C300 64 Gb | SSD2 : Intel 320 120 Gb | HDD1 : Hitachi Deskstar 7K1000.C 1Tb | PSU : Scythe Stronger 500W[/COLOR]
Filco Majestouch 2 | Topre Realforce 103 U-UW | Deck 82 Ice | KBC Poker | Cherry G81-7000 | Sun Type 7 | Apple Keyboard (MB110D/B)
[/SIZE]
Offline darkblader
« Reply #1 on: Sat, 10 September 2011, 15:00:00 »
Is there no chance to get new pbt keycaps for 105 german/uk layout?
[/SIZE]
Offline Lolcakes
« Reply #2 on: Sat, 10 September 2011, 15:01:37 »
Offline darkblader
« Reply #3 on: Sat, 10 September 2011, 15:04:05 »
Quote from: Lolcakes;414077
http://www.keyboardco.com/keyboard_details.asp?PRODUCT=778  - the uk layout
is that the orginal filco set with abs or custom with pbt?
[/SIZE]
Offline redpill
« Reply #4 on: Sun, 11 September 2011, 13:32:58 »
Sorry to hear about your issue darkblader.  You'd think as expensive as Filcos are they would have more durable keycaps.
I'd recommend ignoring any shills/trolls that tell you "deal with it," they tend to have their own agendas and there's no reason you should have to put up with this.
If you can't find replacement key caps you could try sandblasting them, or even sanding them by hand if you have the time, superfine grit sandpaper, and something curved to lay the sandpaper over.  See my KBC Poker link in my sig for my results from such an endeavor.  Sandblasting would be easier and give you better texture but you need the equipment.  In either case you'd also wind up with blank key caps obviously, so that needs to be acceptable also.
Good luck!
^ Current Favorite ^  Topre Realforce 87UB 55g  |  Topre Realforce 103UB 55g | KBC Poker/Browns/Sanded KeycapsDucky 1087 | Filco MajesFoam-2 | IBM Model M 1390131 Feb '87 | Still Love: Microsoft Trackball Explorer x3 | Now Unused:  Microsoft Natural Ergo 4k x2
Offline Zamorph
« Reply #5 on: Sun, 11 September 2011, 18:40:42 »
@ red-- How long did the sandblasting take ya? Looks amazing !! :)
Offline redpill
« Reply #6 on: Sun, 11 September 2011, 19:02:21 »
Quote from: Zamorph;414622
Thanks, but I didn't sandblast, I did it by hand.  But it's a very time consuming endeavor.  If you have the sandblasting equipment it would be much faster.
Offline monked
« Reply #7 on: Sun, 11 September 2011, 19:04:09 »
UK = quertY :/
@darkblader
i am thinking about buying a filco tenkeyless and get blank keycaps... so i could sell you the printed ones... should not be a problem if you didn't use your numpad a lot^^
OM me if interested (could take ~2 weeks  because i didn't buy it yet)
« Last Edit: Sun, 11 September 2011, 19:06:10 by monked »
Offline Chobopants
« Reply #8 on: Sun, 11 September 2011, 19:21:43 »
LOL agenda.
I think stock Filco keycaps actually feel cooler when they get a little used and the look just means it's a tool that you've put some work into and shows it's something that gets a lot done. Even though I've switched all my Filcos to PBT keys I keep the stock ones around in case I miss them enough to put them back on (I get pretty close sometimes).
Realforce 87UW 45g - Filco Blue 87 - Filco Linear R - Filco Brown 104
