Author Topic: Only Topre Spacebar ABS?  (Read 2066 times)
Offline davin
« on: Wed, 14 September 2011, 11:48:48 »
Hi Friends ;),
Maybe this question has been uttered before..., but wanted to be sure. (Sorry for the inconvenience)
I saw a few posts made by Ripster, about the spacebar on Topre keyboards; concluding it was made with ABS.
On the Topre keyboards, only the spacebar is ABS right?, or are all the keys ABS?, this i did not get from Ripster's surgery of the keys ;)
Regards,
Davin
Offline redpill
« Reply #1 on: Wed, 14 September 2011, 12:00:33 »
According to the Topre wiki, the rest of the keys are PBT.
^ Current Favorite ^  Topre Realforce 87UB 55g  |  Topre Realforce 103UB 55g | KBC Poker/Browns/Sanded KeycapsDucky 1087 | Filco MajesFoam-2 | IBM Model M 1390131 Feb '87 | Still Love: Microsoft Trackball Explorer x3 | Now Unused:  Microsoft Natural Ergo 4k x2
Offline RiGS
« Reply #2 on: Wed, 14 September 2011, 12:02:19 »
I believe the right shift is also ABS, however it hasn't been confirmed yet.
Offline keyboardlover
« Reply #3 on: Wed, 14 September 2011, 12:54:47 »
Dye subbed ABS? Unlikely.
Offline RiGS
« Reply #4 on: Wed, 14 September 2011, 14:41:41 »
That makes sense. Thanks for pointing it out, though they could still use some kind of modified nylon material that withstands the heat.
The shift key has a different texture.
« Last Edit: Wed, 14 September 2011, 14:44:47 by RiGS »
Offline redpill
« Reply #5 on: Wed, 14 September 2011, 16:15:58 »
Quote from: RiGS;416134
Hmm, I can't see a difference on the 103UB I'm staring at on my desk.  Could it be you just don't use your right shift so it looks like it has a different texture but just isn't worn?
« Reply #6 on: Wed, 14 September 2011, 16:27:06 »
Not to sound all "mcgurky" but it could be normal pbt wear from using that key a lot.
Offline ironman31
« Reply #7 on: Wed, 14 September 2011, 21:11:15 »
The Japanese layout boards have a PBT space bar :)
::cough:: ... like the one in my sig.. ::cough::
Keyboards:
IBM Model M Space Saving Keyboard (Used), HHKB Pro 2 (White, Lettered), Realforce 87U all-45g in White, Filco Majestouch 2 TKL with Cherry MX Browns, Model F PC/ATNoppoo Choc Mini (MX Browns), Model F XT, IBM Model M 1397735 (bought NIB), (2) Siig Minitouch (GHSS) one with XM, one with complicated ALPs (modded),2 Dell AT101W, Cherry G80-11900HRMUS (modded with MX browns)
Pointing Devices:
« Reply #8 on: Wed, 14 September 2011, 21:24:27 »
Can it be captured well in a photo? (maybe if you remove it and another cap and put them together?
If so, please post...
Offline RiGS
« Reply #9 on: Thu, 15 September 2011, 05:50:39 »
The texture is smoother, very similar to the spacebar.
