Author Topic: Cherry G80-1502 to USB  (Read 5190 times)
Offline ischeriad
« on: Sat, 17 September 2011, 20:34:47 »
The Cherry G80-1502 is a nice keyboard, but is has this ridiculous coiled PS/2 and serial plug cable which weighs almost as much as the board itself.
Since I use it with an USB adapter anyway and do not need the card reader, I replaced the stock cable with a USB cable complete with the little board I got from a PS/2-USB adapter. I tried to make this mod reversible, so I soldered the four leads to the bottom of the controller PCB. The original cable is fully intact and I can replace it should I ever need, desoldering or just snipping the leads to the USB adapter.
It would have been even nicer if I had a grey USB cable to spare, but the black will do just fine. I also considered a removable USB cable by building a (mini) USB jack in the casing, but I had none lying around.
The stock cable has the following configuration:
Code: [Select]
Keyboard  PS/2       Serial
BROWN     -          7: RTS
ORANGE    -          8: CTS
RED       -          3: TxD
BLUE      -          2: RxD
BLACK     3: GND     5: GND
YELLOW    5: +CLK    -
GREEN     4: Vcc     -
WHITE     1: +DATA   -
