Author Topic: Ducky DK-1008 vs Leopold Fc500r  (Read 7806 times)
Offline Deadly55
« on: Wed, 21 September 2011, 14:12:22 »
I got a, widow atm and the double tap issues get me so it's upgrade time. The two boards will be browns as I like the tactile feel. I'll be doing typing and gaming on them. The ducky will have pad printing and will be 80$ where as the leopold would be 109$
Sent from my GT-I9000M using Tapatalk
Offline silverphoenix
« Reply #1 on: Wed, 21 September 2011, 15:01:15 »
Leopold without a doubt. My friend owns a ducky brown, and I recently got my brother an FC500r red's and the leo's feel much more solid and better built imo, esp the keycaps.
Offline Deadly55
« Reply #2 on: Wed, 21 September 2011, 15:09:47 »
Otaku or normal? I like the no printing but when I typo I look down to find the proper key.. I've read about linear switches and asked others about how they feel and haven't gotten an idea of how a black switch feels like at all. I'm only looking at browns because i love my blues. Keycaps, for filco boards will work on the leopold s right?
Offline Urglifast
« Reply #3 on: Wed, 21 September 2011, 15:18:18 »
Quote from: Deadly55;419659
[insert ripster pointing someone to the wiki's here]
you won't be able to swap the spacebar.  however most, if not all, of the keys should be swappable.
« Last Edit: Wed, 21 September 2011, 16:12:18 by Urglifast »
Offline Deadly55
« Reply #4 on: Wed, 21 September 2011, 16:05:44 »
Internet browsing sucks on phone.
Offline Urglifast
« Reply #5 on: Wed, 21 September 2011, 16:11:58 »
Quote from: Deadly55;419672
i edited my post to answer the question anyhow.  copied to below,
you won't be able to swap the spacebar. however most if not all of the other keys should be swappable.
Offline Deadly55
« Reply #6 on: Wed, 21 September 2011, 17:00:19 »
Now it's down to the c leopold or wasd with black caps and yellow wasd. Same price as the, leopold
Offline Urglifast
« Reply #7 on: Wed, 21 September 2011, 17:24:47 »
Quote from: Deadly55;419687
decide which stabilizers you prefer.  one has costar, the other has cherry.  the keycaps are a little different as well, but i believe they're both etched *wanders to check the wiki*
*ok, back* according to the wiki, they're both ABS keys with lasered w/ infill or blank.
« Last Edit: Wed, 21 September 2011, 17:28:17 by Urglifast »
Offline Deadly55
« Reply #8 on: Wed, 21 September 2011, 17:31:06 »
I only know how the widows stabilizers feel
. The otaku variant, has no lasering right? Just blank keys?
Offline Urglifast
« Reply #9 on: Wed, 21 September 2011, 17:37:11 »
Quote from: Deadly55;419696
someone correct me if i'm wrong but i believe the B.widow and the WASD have the same stabilizers.  and yes, the otaku variant is the blank key version.
Offline Deadly55
« Reply #10 on: Wed, 21 September 2011, 17:39:50 »
I see I'm so torn between the, two styles it's funny. I look and don't look at my keys while typing
Offline Urglifast
« Reply #11 on: Wed, 21 September 2011, 17:47:37 »
could always do something like this:
[ Attachment Invalid Or Does Not Exist ] 27017[/ATTACH]
behold my Leo, i put those on there for the occasional keytarded brother that might use my keyboard.  also, the blank keytops feel soooo silky
Offline Deadly55
« Reply #12 on: Wed, 21 September 2011, 17:49:41 »
Now thats awesome, I think,i might go otaku and, consider a second set, of, keys.
Where do you get those caps?
Offline keyboardlover
« Reply #13 on: Wed, 21 September 2011, 17:59:28 »
Ducky sucky. Go for Leopold.
Offline Urglifast
« Reply #14 on: Wed, 21 September 2011, 18:04:00 »
Quote from: Deadly55;419705
I found them from an ebay seller. i'll link to his store when i get home and can browse ebay.
« Reply #15 on: Wed, 21 September 2011, 18:10:53 »
Quote from: Urglifast;419699
WASD has the "wire" stabilizers, and the keycaps are lasered with no infill. I have one, and I highly recommend it.
Offline Deadly55
« Reply #16 on: Wed, 21 September 2011, 19:20:58 »
I'm stuck between  linear and tactile again. Could I get some personal descriptions of a, linear, switch?
Offline Deadly55
« Reply #17 on: Wed, 21 September 2011, 19:24:48 »
Linear is, more rubber dome ish?
Offline Urglifast
« Reply #18 on: Wed, 21 September 2011, 19:26:55 »
Quote from: ripster;419748
Got to your neighbors, press the doorbell, and run.
You've just tried a linear switch.
Flip a lightswitch.  You've just experienced tactile.
For a clicky tactile grab a bic pen.  CLICK! (a little ping too)
i love this explanation....sheer genius
Offline Deadly55
« Reply #19 on: Wed, 21 September 2011, 19:27:04 »
O.o the door bell I tried was rather mushy
Offline Deadly55
« Reply #20 on: Wed, 21 September 2011, 19:37:37 »
I read it, I guess I fail at thinking what a, linear feels like.
Offline Lolcakes
« Reply #21 on: Wed, 21 September 2011, 20:52:08 »
Now I understand why I like the blue switches! Back in college I used to love switching my pen on and off.... CLICK! CLICK!, it was pissing everybody off. Same logic with my blues board... it just has 88 times more buttons that click <3
Offline Urglifast
« Reply #22 on: Wed, 21 September 2011, 21:10:46 »
Offline Deadly55
« Reply #23 on: Thu, 22 September 2011, 00:01:39 »
The rubber domes I've  tried feel like a door bell. Link didn't work on my phone.
Edit: works in opera
« Reply #24 on: Thu, 22 September 2011, 00:07:45 »
I've found rubber domes can vary greatly in feel.
Red's feel like they have almost no resistance as it goes down and it is mechanically smooth like a rail and then it just bottoms out when plastic meets plastic. Blacks have a more pronounced increase in resistance as the key is pressed but other than that the its the same.
As for browns, for me personally I get a tiny bit of tactility but in terms of resistance it feels almost linear. Blue's have more tactility due to the little snap but I don't like how it is delivered(personally)
I personally use ergoclears, best way to put it is they have this high resistance for like the first 1.5-2mm of movement then they just turn into redlike smooth and ease. In a way it sort of reminds me of buckling springs.
Anyhoo on one note most doorbells tend to feel mushy these days.
Offline Deadly55
« Reply #25 on: Thu, 22 September 2011, 00:12:20 »
Silver reds or browns which should I get? Anything else to get a feel of linear? If I go red should I wait for corsairs board?
« Reply #26 on: Thu, 22 September 2011, 00:18:03 »
well the only thing i think you can try is pull apart a cheap clicky pen, and push on the ink tube into the bottom half of the pen, this will bottom it out without the clickyness. Although the pens' may feel more like the way i described blacks, kinda have to push down to keep the sucker down. Unlike red's where it's almost like the weight of my hand can keep em down but they float up when you release em. I personally see no difference in gaming between the two nor in typing, most feel the browns are better for typing but I tend to bottom out anyways so it doesn't matter to me. I'd say the red's are rarer and the Leo reds are a ridiculously good price at EK but browns are safer to go with. I can't tell you what you'll be happier with.
Offline Clickey
« Reply #27 on: Thu, 22 September 2011, 01:57:47 »
Linears feel terrible IMO, they feel much stiffer than they actually are. It is also much easier to avoid bottoming out on a non-linear switch. I would stick with blue if you don't find the sound annoying, because you will probably miss the click, or if you must switch switches, go to browns.
Also what is the point in Otaku? It is terrible if you don't know the keys 100% (as you stated), there really is no benefit to otaku/ninja, unless you think it looks amazing.
"we are on Geekhack not Lazy****" - The Solutor
Offline Deadly55
« Reply #28 on: Thu, 22 September 2011, 10:48:31 »
Blues and double tapping gets me,  thats why I'm wanting  to switch. I know where the keys are on my widow it's just, when i typo (usually one off) then,i end up looking.
Offline dux
« Reply #29 on: Thu, 22 September 2011, 10:51:47 »
Why is anybody considering a Ducky if can you can get a Plu? Why taking a scrap copy if you can take a good precise copy?
Offline Marclgw
« Reply #30 on: Fri, 23 September 2011, 04:35:39 »
Leopold Of Course.
Ducky is honestly a piece of ****.
Offline WTFGoD
« Reply #31 on: Fri, 23 September 2011, 06:35:09 »
Quote from: Marclgw;420330
Leopold Of Course.
what makes the duckys a pos?
Offline dux
« Reply #32 on: Fri, 23 September 2011, 09:34:17 »
Quote from: WTFGoD;420339
really really flimsy plastics / construction. a product from a garage.
Offline itlnstln
« Reply #33 on: Fri, 23 September 2011, 09:39:17 »
My Ducky 9008s are very well-built.  I really like my YOT edition 'board.  They rank right up there with the Filcos I had.  The Ducky 1087s are not that great, though.
