Author Topic: Cherry MX Tenkeyless with num lock?  (Read 4669 times)
Offline Bongoojingie
« on: Mon, 03 October 2011, 12:59:37 »
I know, for example, the Topre Realforce 87U has a num lock key so that you can have a pseudo-num pad in the tenkeyless form factor.  Are there any Cherry MX-based keyboards that have a similar feature?
Realforce 87U Black Uniform 30g | Filco TKL Black Ergo Clear | Filco TKL White Ergo Clear | Filco TKL Linear R Limited | Custom Dell AT102W w/ White ALPS | HHKB Pro 2 Type-S | TypeNow Solid Blues | SteelSeries 7G
Offline HaiiYaa
« Reply #1 on: Mon, 03 October 2011, 13:25:17 »
noppoo choc mini
« Last Edit: Mon, 03 October 2011, 13:27:27 by HaiiYaa »
« Reply #2 on: Mon, 03 October 2011, 14:59:08 »
Quote from: HaiiYaa;425587
noppoo choc mini
Hmm.  Any others?  Doesn't sound like this would work with my Mac (which wouldn't be it's primary use and I might just deal with, but like having the option open.)
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Mon, 03 October 2011, 19:10:41 »
Ducky 1087 has an embedded numpad.
Offline BababooeyHTJ
« Reply #4 on: Mon, 03 October 2011, 20:15:40 »
Quote from: lysol;425759
Yup but the G2 may also give you issues with a Mac.
« Reply #5 on: Mon, 03 October 2011, 20:19:31 »
I found the Ducky 1087 after making this post but I'm a little hesitant based on some of the complaints I've seen regarding its build quality.  I'm thinking maybe I just dive into a tenkeyless head first and forget I ever had a numpad and go with a Filco...
« Reply #6 on: Mon, 03 October 2011, 20:24:22 »
Honestly, most of the claims about the build quality are vastly exaggerated. I haven't owned a 1087 but I have had a 1008 and I was impressed with it. For $95 shipped there really aren't any better options for a keyboard with no number pad. I love my filco but I don't think that you would be disappointed with the ducky. If you want or don't mind a numberpad I would say that you would be better off spending the extra $25 on a WASD keyboard.
« Reply #7 on: Mon, 03 October 2011, 20:54:17 »
Well I'm a bit crowded for space, so I'm trying to decide which is more annoying: the lack of desk space or the lack of numpad when I use it on occasion.
I have a full 104 key now, thinking I would try for something in-between to ween myself off numpad use ;)
« Reply #8 on: Mon, 03 October 2011, 22:09:14 »
Kinesis Advantage ... (not quite as narrow as a Filco Tenkeyless, but not as wide as a full-sized board either)
Offline BiNiaRiS
« Reply #9 on: Mon, 03 October 2011, 23:09:24 »
G80-1800
Sent from my EVO
KMAC 2 w/ErgoClears
