Author Topic: Mode M Hardwired DVORAK ??? Possible??  (Read 6762 times)
Offline joneslee85
  • HHKB Scrub JP
  • Professional Rubyist programmer!
    • Ruby Journal
« on: Wed, 05 October 2011, 20:36:19 »
Hi guys, is there a hard wired Drovak version of Model M or has anyone moded model M for Drovak layout yet?
TOO MANY KEYBOARDS THAT I COULD NOT COUNT! BUT I AM STILL USING MY MODEL F77
Offline Pylon
« Reply #1 on: Wed, 05 October 2011, 20:53:57 »
You should check out the USB controller mod for the Model M. That's one possible way to do it.
You could also ask Unicomp. Maybe they can custom program one for you.
Offline SmallFry
« Reply #2 on: Wed, 05 October 2011, 22:02:19 »
I've wondered this too. You'd need non ridged f and j and whatever the Dvorak homerow keys are ridged as well as a ya know what... You can! An AIKON keyboard controller can be built and programmer fairly easily:) goodluck
Offline pkamb
    • http://www.staylimber.com/
« Reply #3 on: Mon, 21 November 2011, 14:28:07 »
Check out the "Qwerty In - Dvorak Out" USB adapter:
http://www.keyghost.com/qido/
fossala
  •  Guest
« Reply #4 on: Mon, 21 November 2011, 14:29:28 »
They look good but the $89 WTF.
Offline hasu
  • @tmk
« Reply #5 on: Mon, 21 November 2011, 22:26:00 »
My PS/2 to USB converter supports DVORAK layout just for *demonstration purpose*. But you will be able to make your DVORAK dedicated version converter with small code change. See my mod article.
And my firmware also can be used as keyboard controller so I think you can embed it inside the keyboard such like other model M mod.
