Author Topic: New Keyboard (totally new to this)  (Read 14035 times)
Offline USAgent
« on: Mon, 17 October 2011, 10:51:21 »
Hey all,
Completely new to the forums, read around and watched YouTube a bit and I still am not sure what to do. I currently have a standard MS Media 3000 keyboard and was looking to get a 'gaming keyboard'. My issues with this one is that the F keys don't seem to work in games (F1-12 that is). I like the aesthetic of it, clean and simple. I don't like those crazy gaming keyboards with buttons all over the place, but looked at the Logitech G110 and it's a pretty simple design. I wanted something a little on the quiet side, not sure if it was Cherry Blue or Brown for mechanical as I'm new to it all. Just looking for some suggestions and appreciate the patience from you guys as I try to figure this out.
Filco MJ2 Ninja 104Ducky Disco TKL
Offline noodles256
  • le legendary
« Reply #1 on: Mon, 17 October 2011, 10:58:50 »
wlcm
AF | Ducky YOTD |
Offline spolia optima
« Reply #2 on: Mon, 17 October 2011, 11:01:03 »
MX Brown switches are silent (tactile)
MX Blue switches are loud (clicky + tactile)
MX Black/Red switches are also silent (linear)
You want to check out Leopold, DAS, Filco, and WASD to begin with.
Looks like you're in the right place, too. Mechanical keyboards are known for their sleek, modern appearance. Most of us can't stand flashy, plasticky keyboards that basically look like toys.
keyboards!
« Reply #3 on: Mon, 17 October 2011, 11:01:36 »
Also welcome to GH!!! Enjoy your stay and GIRD YOUR WALLET
keyboards!
Offline USAgent
« Reply #4 on: Mon, 17 October 2011, 11:04:29 »
I will check those out, just to make it easier:
Preferences:
Smooth typing as I don't use a headset and in games I typically type
Quiet is better than loud, I can't see it being too important, but I feel like the smoothness is nice
At work I have a Bloomberg keyboard (mini one) I'm guessing it's mechanical but I can find out, it is a little stiff
Also, has anyone tried the new BlackWidow Stealth and Stealth Ultimate?
Offline peda
« Reply #5 on: Mon, 17 October 2011, 11:04:32 »
Welcome.
Have a look at http://www.keyboardlover.com for a general overview of mechanical keyboards.
Or click ripster's signature for a more in depth knowledge base.
Offline USAgent
« Reply #6 on: Mon, 17 October 2011, 11:09:27 »
That is a nice sig. I'll do some reading
Offline RColinTaylor
« Reply #7 on: Mon, 17 October 2011, 11:10:48 »
It would be a stretch to consider MX Browns as 'Silent' but I like them for gaming; they fit in as that sort of middle man for typing and gaming comfort.
I like my Browns more than my Blues.
« Reply #8 on: Mon, 17 October 2011, 11:12:23 »
Oh, and as a side note: What kind of gaming are you looking at doing?
« Reply #9 on: Mon, 17 October 2011, 11:23:04 »
The blackwidow is good (and cheap) but generally not the same kind of high-quality that you'll find in a leopold, filco, or das.
That's not to say I wouldn't recommend them. I HIGHLY recommend the blackwidow to anyone new to mechanical keyboards who might be on a budget.
Mind taking of a picture of that "bloomberg" keyboard? Just take off a keycap and snap one of what's underneath.
keyboards!
Offline USAgent
« Reply #10 on: Mon, 17 October 2011, 11:36:37 »
I'm mostly FPS, probably play Diablo 3 when it comes out, maybe try the new Star Wars: Old Republic. I'd imagine(and for wallet's sake) my MMO days are behind me.
Offline peda
« Reply #11 on: Mon, 17 October 2011, 11:45:30 »
Quote from: USAgent;432796
This is also true for me but I don't think that I will be able to resist guild wars 2...
B-)
Offline USAgent
« Reply #12 on: Mon, 17 October 2011, 13:07:57 »
I'm curious about the BlackWidow Stealth edition, has anyone used it? I saw the reviews for the non-stealth one and wasn't sure if this new one uses a different Cherry? I'm liking the DAS but I don't really like the glossy look. I feel like the Razer might be a good choice since I also have some Best Buy giftcards it will cost me little to nothing out of pocket.
Offline RC-1140
« Reply #13 on: Mon, 17 October 2011, 13:12:27 »
Well, in that case the Black Widow Stealth seems to be the right option. It uses PCB Mounted Brown switches (ergonomic, tactile, non-clicky). It might not be of the same quality as a Filco or a Leopold, but if you could get it cheap, why not.
In the case you like it, you could still look for a keyboard with a higher build quality and plate mounted switches. But I for myself am quite happy with my cheap Cherry boards, so it really depends on yourself.
« Last Edit: Mon, 17 October 2011, 13:21:31 by RC-1140 »
[SIGPIC][/SIGPIC] Unicomp 122-Key Terminal Emulator - IBM Model M 1394309 - IBM Model M 1394312 (Terminal) - Cherry G84-4100 - Cherry G80-1800 MX Black - Cherry G80-2551HAD (with a spare NIB)
Offline Mazora
« Reply #14 on: Mon, 17 October 2011, 13:38:32 »
Diablo 3: I would go with a ten key less keyboard. There's not so much keyboard spamming in this game (its mostly on the mouse) so I guess a clicky switch keyboard would be good.
HHKB Pro 2: black case white keys
Filco Masjestouch v2 / MX-Reds / hard lending pads /Dye-sub keycaps
RF-87UW
Offline USAgent
« Reply #15 on: Mon, 17 October 2011, 13:45:25 »
I checked under the key on my bloomberg keyboard it's a weird combo but I think I'm gonna try for the BlackWidow Stealth, just need to find a place to buy it from.
Offline RC-1140
« Reply #16 on: Mon, 17 October 2011, 13:55:49 »
Indeed, these switches seem strange to me too, but I'm far from being an expert. But from the first glance these seem to be some strange Rubber Domes.
Offline Mazora
« Reply #17 on: Mon, 17 October 2011, 14:00:47 »
I'm using the exact same bloomberg keyboard at work. It's a terrible keyboard, very very sucky, one of the worst I ever typed on.
« Last Edit: Mon, 17 October 2011, 14:13:31 by Mazora »
RF-87UW
Offline USAgent
« Reply #18 on: Mon, 17 October 2011, 14:08:21 »
It's like they combined the worst things of a laptop keyboard with an attempt at mechanical keyboard. The wobbliness of the keys drives me nuts.
Offline kingqway
« Reply #19 on: Mon, 17 October 2011, 18:14:20 »
Not sure if you would like the blackwidow if you don't like the Das for its gloss. Blackwidow is pretty much a glossier das keyboard.
Das Professional Silent || White Filco TKL MX Blue || Leopold FC500R MX Brown
Offline StaCT13
« Reply #20 on: Mon, 17 October 2011, 19:12:51 »
I don't really know if I can agree with that 'sleek, modern appearance' part. But most modern mechs tend to steer away from unneeded features.
But on a more helpful note, if you want a really high quality, no bells-and-whistles board for a reasonable price, look into Leopolds. They're on the cheaper side, but match the amazing reputation of Filcos.
Good 'ol Filcos...
ErgoDox Classic Aluminium (MX Reds) | Leopold TKL Otaku (MX Browns) | Rosewill RK-9000 (MX Blues) | Dell AT101W (Alps Black)
Happily typing in Dvorak
Offline SmallFry
« Reply #21 on: Mon, 17 October 2011, 20:39:16 »
A cheap starting board would be a Model M, but they are quite loud. So, I'd find what switch sounds most pleasing, then browse the Classifieds. There are usually a few nice cheaper either Pokers or Leopolds on there. Again, like everyone else, WELCOME TO GEEKHACK!
Offline flyball
« Reply #22 on: Mon, 17 October 2011, 20:45:18 »
buy something new enough to have a windows key
[SIGPIC][/SIGPIC]
Offline Lmnr
  • The Jack Of All Trades
    • W.W.C.
« Reply #23 on: Mon, 17 October 2011, 21:14:15 »
TOPRE REALFORCE haha if you want to try them out they start at 200 and up also very high quality keyboards that have their own type of switches called topre switches and its constantly debated over if its worth the money and if its not and my answer to that is if you have the money itll be worth it, I also had the same issue moved from trying to get a filco,ducky,leopold,wasd all of them seemed ok but the topre constantly gets good rep for the people that have them and used them for a while... then again 200+
Peripherals:
Realforce 87uw with grey caps,Ducky YOTR Blues,Realforce 104ug Hipro,Zowie Am FG,WMO 1.1a,Sidewinder X3
Offline Pretendo
« Reply #24 on: Mon, 17 October 2011, 21:45:52 »
Welcome to GH!
I'll continue my praise for the Rosewill RK-9000.  Cheap, attractive and high quality.  That logo may knock off a couple sleek points though...
If you want to go completely anti-sleek but type on pure heaven, you could adopt a Model M.  Grey and beige keyboards will come back in style some day, just you wait!
That process could be sped up significantly if somebody knocks Snooki out with one on live TV. Any GH members live in Jersey?
IBM Model F-122 6110347 -- September 13th, 1984
IBM Model M 1391404 -- April 14th, 1988
Rosewill RK-9000
Offline TheProfosist
  • Custom Layouts Only!
« Reply #25 on: Mon, 17 October 2011, 21:54:04 »
pick up this up its a great deal for a new board http://tinyurl.com/345slza
Offline USAgent
« Reply #26 on: Tue, 18 October 2011, 05:52:30 »
I cashed out some credit card reward points and loaded up on Amazon giftcards, but now I see that the BWU Stealth is not currently for sale. I'll have to go to the store and see if I can play with the non-stealth one and see if how I like the sound and feel.
Offline juanito89
« Reply #27 on: Tue, 18 October 2011, 07:20:00 »
Hey Agent.
I've also been looking into Blackwidows as an option for my first mechanical keyboard.
As far as I understand, the main (only?) 2 differences between the Original and the Stealth are:
A) Original uses Cherry Blue switches - Stealth uses Cherry Browns. These two switches have different sound and feel, so that Original in the store will be very different from the Stealth.
B) Stealth has a black matte finish, Original has a black glossy finish, which most people hate because they're very hard to keep clean and free of fingerprints.
Offline USAgent
« Reply #28 on: Tue, 18 October 2011, 07:35:59 »
Yeah that's why I'm leaning towards the Stealth, I don't know why they are completely unavaible :(
Offline Harlequin
« Reply #29 on: Tue, 18 October 2011, 09:08:05 »
DO NOT GET Razer Black Widow(Cherry blue switch) keyboard. especially Ultimate one. It has so many problems, the most common problem is that if u press some key, it hits other keys.
my problem was XCV keys. I pressed V and C came up together and so on. so annoying. u can fix it but it's not worth doing this.
Get FILCO or Leopold.
If you play FPS, i heard that black switch is good. SteelSeries 6GV2 has black switches. It's just solid simple nice keyboard.
A lot of pro FPS gamers use this keyboards.
MMORPG, i suggest either brown or blue.
DK Saver Winkeyless | Leopold FC700R | Ducky DK9087 Shine 2
« Reply #30 on: Tue, 18 October 2011, 10:33:48 »
Quote from: Harlequin;433521
I take it you're talking about ghosting?
Also, where did you get this scandalous information about Razer's quality control?
keyboards!
Offline USAgent
« Reply #31 on: Tue, 18 October 2011, 13:06:53 »
Something about the font on the keyboard caught my eye, also the matte finish on the stealth really looks a lot better. Seriously though, no one is willing to take my money for this thing, cannot find it for sale.
Offline Mazora
« Reply #32 on: Tue, 18 October 2011, 13:12:27 »
financial professionals should go for Topre Realforce 87-UW...see that gosu integrated numpad ?
RF-87UW
Offline juanito89
« Reply #33 on: Tue, 18 October 2011, 13:13:09 »
Quote from: USAgent;433675
Have you tried emailing the Razer store to ask when it will be available again? I was considering that...but now my interest is swaying into the Leopold brown tenkeyless or even the Noppoo, so I probably won't.
Offline kingqway
« Reply #34 on: Tue, 18 October 2011, 13:37:21 »
eh, I don't hear good reviews about razer products on a general level (like my cousins, online forums, etc). But having seen the normal blackwidow (mx blues) it seemed perfectly fine. Personally, I don't like razer's flashy approach to gaming accessories, so I avoid their products at all possibilities, and that's about the only reason. As for the blackwidow, one of my friend's got it and he enjoys the keyboard a lot (ultimate).
I would just like to warn people who get blackwidows to watch out for their slight change in key setup. The macro keys to the left of the keyboard, and the Fkeys along the top are different. Personally, I found this extremely aggravating to adjust to when I was playing on his computer (starcraft 2), as I take quite a bit to adjust to new keyboard setups once I've settled down with the standard. Just keep it in mind when you buy one that you will need to adjust slightly to their change in format.
EDIT: Corrected some huge mistakes :P
« Last Edit: Tue, 18 October 2011, 13:42:43 by kingqway »
Offline USAgent
« Reply #35 on: Tue, 18 October 2011, 13:48:58 »
I did email the Razer store, will let you know what I hear back. In the meantime I started looking at the Deck Legend with MX Clears, heard the Blacks are really stiff.
edit: forgot to mention, steel series looked ok, but the left windows button not being a windows button I heard this may be an issue?
Offline USAgent
« Reply #36 on: Wed, 19 October 2011, 11:41:08 »
I started playing around on WASD customized keyboard layouts, anyone have a WASD with Cherry Browns it looks like what I want!
Offline enoy21
« Reply #37 on: Wed, 19 October 2011, 12:15:59 »
I have it in blues and I use it here at work. I love my Filco brown that I use at home too. They are both of excellent quality.
WASD 104 work
WASD 104 home
WASD 104 [not my style]
Filco MJ2 Ninja 87 [sold]
« Reply #38 on: Wed, 19 October 2011, 15:09:22 »
I have a Custom Blue WASD very good build quality and great support.
Offline Meekis
« Reply #39 on: Wed, 19 October 2011, 18:26:36 »
I have a WASD Custom in brown, I love it!
Offline N8N
« Reply #40 on: Wed, 19 October 2011, 18:33:46 »
If you think that you may want a WASD go for it.  I also have one in blues and love it.  Currently typing this on a Noppoo Choc Pro/browns that I actually bought WASD keycaps for.  The new laser printed caps are fantastic.  The only reason I'm not using the one w/ blues is that I really don't like the click of the blues.  I bought the board with the intent of modifying it to clears, but ended up liking it as is and couldn't bear to cut it up.  So I have an extra keyboard :)  (it occasionally sees some use at home, as the browns really do feel pretty good, I'm just not a big fan of the click.)
WASD is pure concentrated evil for people like me who are snobbish about their equipment and also somewhat frustrated graphic designers... for a mere $60 you can completely change the character of your keyboard :)  Right now of my three favorite keyboards only one of them (the WASD) has the keycaps that it came with out of the box.  (the other two would be this Noppoo w/ WASDs and my hacked-up Filco with MX clears and Cherry doubleshots.)
Offline USAgent
« Reply #41 on: Wed, 19 October 2011, 18:55:31 »
I'm really itching now, think I might get an all black with lime green WASD blank.
Sidenote: If anyone wants a logitech store code, I got 20% off because I just recently got the Wireless Gaming G700, god it's so smoooooth.
Offline Bry
« Reply #42 on: Wed, 19 October 2011, 20:12:58 »
Welcome.
You might be a good candidate for a Leopold with browns (tactile light spring), reds (linear light spring), blacks (linear heavy spring), or possibly clears (tactile heavy switch).
Leopolds seem to be a good value, and if you want to pay a bit more I'd check out Filco and WASD (fully customizable keycaps).
Good luck!
last.fm | deviantART | SC2
Filco MJ2 Ninja - MX Red | Filco MJ2 Ninja - MX Brown | U9BLS - MX Brown
« Reply #43 on: Thu, 20 October 2011, 00:15:26 »
Quote from: USAgent;434864
If your just going to modify the WASD get a semi custom. I personally recommend o-rings to dampen bottoming out. I wount use a cherry mx keyboard long without them.
Offline duncan
« Reply #44 on: Thu, 20 October 2011, 02:31:40 »
Quote from: TheProfosist;435036
+1
Realforce 86UB || HHKB P2 || FILCO MT 87 Blues || FILCO MT 87 Browns || FILCO MT 87 Ninja  Blacks || Poker X Reds
Offline asassdsd
  • Call me "Jelly"
« Reply #45 on: Thu, 20 October 2011, 03:07:16 »
It is said and mostly believed that Cherry MX Black switch are the type of switches to play on an FPS game.
Cherry Blacks are a bit stiff but DEFINITELY quite as OP likes.
Im currently typing on a Ducky 1008 bought from PChome. If your on a budget it is good to start with a Ducky , it cost about $78 shipping included to US.
But if you have some loose money in your hands. You can definitely buy a steelseries 6GV2, It is about $100 everywhere and uses Cherry Black switches. Steelseries seems make lots of think for FPS players so im sure that will interest u a bit. If that doesnt satisfy you, You can also try the Das, and the slightly better Filco/Leopold, they all have Cherry black versions.
Also, don't but Blackwidow non-stealthed if you like quite keyboards, Cherry blues are LOUD.
This isn't an alternative or troll account, I've been using this username for at least 10 years. Try typing it, is so fast and easy!
Recently acquired: Leopold fc660c with PBT   Currently: Bro-less    Clack-less    Mummy-less
I am currently at : Santa Cruz, CA
Offline duncan
« Reply #46 on: Thu, 20 October 2011, 03:33:09 »
Quote from: asassdsd;435068
I assume this was meant to be "quiet"?
This is only true if you don't bottom out. If you bottom out a non-dampened MX Black then they are plenty noisy.
A bottomed out Black can be (seem?) louder than a non-bottomed out Blue and the provision of a tactile bump in the Blue can help prevent bottoming out. So much depends on how things are used.
« Reply #47 on: Thu, 20 October 2011, 04:27:40 »
Quote from: duncan;435082
O and I must say I much prefer the sound of PBT bottoming out that ABS. Bottoming out ABS is like nails on a chalkboard to me.
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #48 on: Thu, 20 October 2011, 04:58:42 »
Silent and smooth typing?
Id go for a board with Cherry reds, if possible PCB mounted!
« Last Edit: Thu, 20 October 2011, 15:58:55 by TheSoulhunter »
A Ghost From The Past
Offline duncan
« Reply #49 on: Thu, 20 October 2011, 05:12:24 »
Quote from: TheSoulhunter;435104
Id go for board with Cherry reds, if possible PCB mounted!
+1
And add o-rings to the keys (see the WASD Keyboards site) to make it even nicer.
