Author Topic: Missing my numpad enter  (Read 3844 times)
Offline iratepr
« on: Wed, 19 October 2011, 23:31:55 »
I just made the switch to mechanical, and since desk space is at a premium at the moment I got a tenkeyless (Filco brown).  I'm adjusting to the spacing, which is expected, but the hardest thing is the missing numpad enter button.  Without thinking about it, I used it all the time whenever my right hand is on the mouse and I need to hit enter.
I never even noticed it before, but now that its gone it is driving me nuts.
I've hit the right arrow instead 3 times during this post alone.
Does anyone else do this?
Offline BarryGordon
« Reply #1 on: Wed, 19 October 2011, 23:33:52 »
I just got the same keyboard an hour ago and I was thinking of the same thing, but it's not much of a big deal.
Offline Lanx
« Reply #2 on: Wed, 19 October 2011, 23:37:17 »
get a mouse that you can re-map one of the buttons to enter?
Offline sinis
« Reply #3 on: Wed, 19 October 2011, 23:42:42 »
remap enter also to pause and remap pause to scroll lock?
Offline BarryGordon
« Reply #4 on: Wed, 19 October 2011, 23:48:02 »
I notice I used the num pad enter key after copy + pasting something, i'm considering of remapping the right arrow key. What's the best way going about this?
« Last Edit: Wed, 19 October 2011, 23:50:33 by BarryGordon »
Offline iratepr
« Reply #5 on: Wed, 19 October 2011, 23:52:42 »
Yeah copy-paste is probably the most common use, but I'm finding others.
I also considered remapping the right arrow, but then I'll be mad when I want to use the right arrow for its intended purpose.
Mapping a mouse button seems like a good idea.  I'll try this tomorrow at work where I have a mouse with thumb buttons.
« Reply #6 on: Wed, 19 October 2011, 23:57:44 »
Nah, my keyboard is sitting on top of a computer case, and the mouse is on a stack of old textbooks, so they're pretty far apart.
Pretty cool though. I never thaught of using my right thumb that much. All the better to learn lefthanded Dvorak, tohaugh. You can remap the -+ and Enter keys to all sorts of useful things to press while mousing.
I do need to lose this stupid ball mouse though and find that optical one.
Offline iratepr
« Reply #7 on: Thu, 20 October 2011, 00:01:20 »
@Barry
If you're going to try remapping, I recommend AutoHotKey.  A bit of a learning curve, but its pretty much a complete solution for remapping anything, making macros, etc.
Offline BarryGordon
« Reply #8 on: Thu, 20 October 2011, 00:30:13 »
I downloaded something called "SharpKeys" and just remapped the right arrow key to enter in the registry, now I just have to wait until I find myself needing the right arrow key!
Offline daerid
    • Rossipedia
« Reply #9 on: Thu, 20 October 2011, 03:10:47 »
I use KeyTweak, personally. It's a bit more graphical, which I like.
Offline pitashen
« Reply #10 on: Thu, 20 October 2011, 03:33:44 »
Never underestimate the potential of human adaptation ability.
YOU WILL GET USED TO IT.
Offline file_id
« Reply #11 on: Thu, 20 October 2011, 05:29:50 »
When I switched to TKL I missed the numpad enter key being there. Maybe get an external keypad.
DS3 White YOTS (Blue)|Poker 2 (Blue,Clear)|QFR Rapid-i TKL (Brown,Blue)|QFR Rapid TKL (Blue,Red,Brown)|KBP V60 (Blue,Clear,Matias Click)|Code TKL Clear|Filco MJ2 TKL (Blue)|Filco MJ2 Ninja Beige TKL (Brown)|Novatouch
Offline Tony
« Reply #12 on: Thu, 20 October 2011, 06:06:59 »
You can always buy a separate keypad. Or another fullsize Filco brown.
Offline iratepr
« Reply #13 on: Thu, 20 October 2011, 12:13:29 »
I'm sure I will get used to it, just as I would get used to losing a finger, but I'd still rather have the finger.
I'm going to stick it out for a while.  If it is still bothering me after a month I'll switch to a full size.
Offline pyro
« Reply #14 on: Thu, 20 October 2011, 12:21:53 »
As people said, just remap LWin / LCtrl / Ctrl+e / Shift+Space / Alt+Space to Enter (and Capslock to LCtrl). Or get a Poker.
Offline iratepr
« Reply #15 on: Thu, 20 October 2011, 13:14:34 »
Oooh, Ctrl + Space seems like a good idea.  Then I can do Ctrl+V, Space to paste, enter.
The only app I ever use that uses that combination is Eclipse, and I don't use Eclipse enough to miss it.
