Author Topic: [Interest Check] Faux Cherry Red ESC + RGBY modifiers  (Read 86374 times)
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« on: Sat, 22 October 2011, 04:34:02 »
This thread is defunct!  See the order thread for the latest on this buy.
The second round moogle kit buy is winding down, and the work cycloverid did to create custom legends that duplicate the Cherry font ended up looking pretty freakin' awesome.
So, naturally the next step is a red Escape key.  I'm interested in duplicating the look of the classic Cherry red Escape (this one is owned by reaper):
[ Attachment Invalid Or Does Not Exist ] 30333[/ATTACH]
cycloverid has graciously offered to do the SVG file.  Here is his work from the second-round moogle buy.  The Ctrl and Alt on the left in the first image are real Cherry 2-shots, and the two columns on the right are the moogle kit.  The second image shows the white kit in context in all its glory.
[ Attachment Invalid Or Does Not Exist ] 30335[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 30334[/ATTACH]
So, to sum up: I would like to gauge interest in doing a group buy for a red Escape key with a custom, faux-Cherry legend.  If there's sufficient interest, it would also be cool to do RGBY versions of the Ctrl, Shift, Alt, and Win keys from the moogle kits.
CONTENTS
The base RGBY kit will include:
2 x 1.25x red Control
2 x 1.25x blue Alt
2 x 1.25x yellow Win (legend as yet undetermined)
1 x 2.75x green right Shift
There will be two left Shift options to complete the base kit:
2.25x ANSI green left Shift
1.25x ISO green left Shift
The left Shifts will be ordered as separate individual keys, and are not tied to the RGBY base kit per se.  So feel free to order extras if you so desire.
EXPRESSING INTEREST
Post in the thread if this sounds appealing.  Please clearly indicate a guesstimate of how many of each of the following you'd be interested in, assuming a decent price:
REDESC
RGBY-BASE
SHIFT-ISO
SHIFT-ANSI
Also be sure to include the country your order would ship to.
BREAKING: Calavera has lamented the lack of Choc-Mini-compatible keys in this buy.  Choc lovers, rise up and make your voices heard, and I'll see what I can do!  #occupygeekhack
PRELIMINARY PRICE QUOTES
Bear in mind that these quotes are for the raw manufacturing cost.  There are a lot of other costs that will be factored into the final charge (e.g., legend fees, shipping from SP to me, Paypal seller fee).
REDESC ($35 setup fee)
25 keys @ $4.38 each
50 keys @ $2.43 each
75 keys @ $1.76 each
100 keys @ $1.44 each
RGBY
RGBY-BASE (no setup fee)
5 sets @ $46.89 each
10 sets @ $26.51 each
15 sets @ $19.71 each
25 sets @ $14.28 each
50 sets @ $10.20 each
75 sets @ $8.84  each
100 sets @ $8.16 each
SHIFT-ISO ($45 setup fee)
5 keys @ $4.18 each
10 keys @ $2.48 each
15 keys @ $1.91 each
25 keys @ $1.46 each
50 keys @ $1.12 each
75 keys @ $1.01 each
100 keys @ $0.95 each
SHIFT-ANSI ($45 setup fee)
5 keys @$20.41 each
10 keys @ $11.22 each
15 keys @ $7.82 each
25 keys @ $5.11 each
50 keys @ $3.07 each
75 keys @ $2.39 each
100 keys @ $2.05 each
OPEN QUESTIONS
Colors.  I'm leaning strongly toward the same red and green from aggiejy's RGB buy:
[ Attachment Invalid Or Does Not Exist ] 30340[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 30341[/ATTACH]
Yellow and blue are still very much up in the air though.  Personally, I like BFK or BOH (blue), and YPB or YCH (yellow).
[ Attachment Invalid Or Does Not Exist ] 30342[/ATTACH]
Legend for the yellow Windows keys.  I quite like the diamond legend shown here:
[ Attachment Invalid Or Does Not Exist ] 30807[/ATTACH]
The other main option so far is the standard Windows logo.  Voice your opinions in the thread.
STATUS REPORT
ELAPSED RUNNING TIME: 20 days
INTEREST CHECKED: 113-121 REDESC, 51-53 RGBY
« Last Edit: Mon, 21 November 2011, 15:04:05 by hashbaz »
Offline RColinTaylor
« Reply #1 on: Sat, 22 October 2011, 04:36:40 »
Interested!
In probably 1-2 Esc's
In Western Amurica.
I like my Browns more than my Blues.
Offline 7bit
  • MX1A-G1DW
« Reply #2 on: Sat, 22 October 2011, 05:05:03 »
Quote from: hashbaz;436584
I recommend that you 2 put your order together and try to get a better price from SP than if ordering separate.
Nevertheless, I'd be interested in the SVG files for this.
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline N8N
« Reply #3 on: Sat, 22 October 2011, 05:23:17 »
I'd be in for a couple Esc, maybe one RGB, I'm in US
Offline Grond
« Reply #4 on: Sat, 22 October 2011, 05:37:31 »
I was also going to start such a group buy! :)
I'm definitely into a RGB kit as long as it includes a ISO option (short left shift). I'm sure a lot of people may want this, because there hasn't been a ISO RGB kit recently.
Also, I would suggest to actually do a RGBY kit like the one Sixty did some time ago:
[ Attachment Invalid Or Does Not Exist ] 29465[/ATTACH]
But with all 1,25 modifiers in order to fit Filcos, Leopold, etc. I think it would look gorgeous!
So i'm interested in RGB + ESC, I live in Italy.
« Last Edit: Sat, 22 October 2011, 05:40:43 by Grond »
Offline N8N
« Reply #5 on: Sat, 22 October 2011, 05:52:15 »
ISO left shift is different size from compact right shift, yes?  that's too bad because then there's four different shift keys people are likely to ask for...
Offline Grond
« Reply #6 on: Sat, 22 October 2011, 05:58:23 »
Yes, ISO left shift is 1.25 as well, so it's actually shorter than "compact".
« Reply #7 on: Sat, 22 October 2011, 06:10:33 »
I'd be in for a Esc and rgb set.
Maybe 3-4 esc and 2 rgb sets.
Offline Ascaii
« Reply #8 on: Sat, 22 October 2011, 06:11:08 »
I would be in for an iso rgb set for sure.
Offline 7bit
  • MX1A-G1DW
« Reply #9 on: Sat, 22 October 2011, 06:16:21 »
Quote from: Grond;436603
(Attachment Link) 29465[/ATTACH]
Help yourself:
http://deskthority.net/wiki/Doubleshot_Replacements_Round_4
There are still some kits not covered by those recent mini-group buys.
I should have known better beforehand: 4 means death in the East-Asian cultures and group buys with an even ordinal number always faild in history.
Quote from: N8N;436605
We need:
1x Shift: 1, 1.25, 1.5, 1.75, 2, 2.25, 2.75
2x Control: 1, 1.25, 1.5, 1.75, 1.75 step
2x Alt: 1, 1.25, 1.5
1x Alt Gr: 1, 1.25, 1.5
« Last Edit: Sat, 22 October 2011, 06:21:11 by 7bit »
Offline csm725
  • I BLEED RED AND GOLD
    • http://csm725.com
« Reply #10 on: Sat, 22 October 2011, 07:01:38 »
1 Esc
Offline sinis
« Reply #11 on: Sat, 22 October 2011, 07:40:15 »
what is this? is every single key now in a separate groupbuy? you want Groupbuy R4 never to happen? Or you just want to feed USPS?
Offline Grond
« Reply #12 on: Sat, 22 October 2011, 08:01:42 »
Personally I think that 7bit is doing a great job with GB4 and I don't want to boycott it in anyway. However, smaller single-purpose GB like Moogle kit 2 have proven to be much faster for obvious reasons. If this GB is going to offer what I'm looking for and I can have it sooner, why should I wait any longer? I'm even ok with spending a little more money for that. I don't really believe this is going to kill GB4 anyway.
Offline Mysteric
  • Formerly 'Mackem'
« Reply #13 on: Sat, 22 October 2011, 08:20:24 »
I'd be interested in an Esc key and an ISO UK RGB set
Offline ishtob
« Reply #14 on: Sat, 22 October 2011, 08:44:26 »
i'd be interested in 3-5 esc keys
Offline Laggy-gaga
« Reply #15 on: Sat, 22 October 2011, 09:06:15 »
i'd be interested in 5 esc keys
Working: Ducky Dragon Blue
Looking for: 356L
For sale:Benchmark DAC1+Stello U3+Amber,RS1i,GS1000i,HE400,HD650,w4r,se535LE
AU only
Offline Mafioso
« Reply #16 on: Sat, 22 October 2011, 09:20:02 »
I'd probably take an escape key and the RGB modifier. I'm in UK.
Offline BiNiaRiS
« Reply #17 on: Sat, 22 October 2011, 10:33:58 »
What set of caps is that and how does that work? I bought one set of Rebel 1.2 and Rebel 1.5 and none of the caps have an offset and I have never seen a cherry board that has stems that fit like that (like realforces)
KMAC 2 w/ErgoClears
Offline tsangan
  • 1000/600
« Reply #18 on: Sat, 22 October 2011, 10:37:51 »
Possible to get a set of blank RGB too or has to be double shot? I'm pretty sure it has to be double shot but thought i'll ask ;p
Keyboardless
Offline Grond
« Reply #19 on: Sat, 22 October 2011, 10:44:32 »
Quote from: BiNiaRiS;436717
It's a Rebel 1.2 set, I took the picture from here: http://deskthority.net/viewtopic.php?f=8&t=689&hilit=rebel
I think it only fits winkeyless keyboards. However, I only meant to suggest to replicate the RGBY color scheme and the "cherry star" legend, not the key size.
Offline tsangan
  • 1000/600
« Reply #20 on: Sat, 22 October 2011, 10:45:19 »
<3 rebel kit
Keyboardless
Offline 7bit
  • MX1A-G1DW
« Reply #21 on: Sat, 22 October 2011, 11:18:32 »
Quote from: sinis;436628
They also kill off any volume discount.
But I don't mind!
Maybe I should write some script which is able to turn posts like
I'm in for a standard kit and WASD keys if they are not big-ass, centered.
Will these keys fit a Filco tenkeyless?
into proper order-ID strings of the form:
RETRO/TENKLESS
RETRO/GAMER
Offline mashingkeys
« Reply #22 on: Sat, 22 October 2011, 11:26:05 »
1-2 esc keys
Offline dux
« Reply #23 on: Sat, 22 October 2011, 12:50:02 »
Quote from: 7bit;436750
But I don't mind!
RETRO/TENKLESS
RETRO/GAMER
I think you should find somebody who would help you translating. It could speed up things. The whole think is too geeky in the moment for the majority. If you are into volume, you need to offer Iphone and Siri, that is a fact of life.
Offline 7bit
  • MX1A-G1DW
« Reply #24 on: Sat, 22 October 2011, 13:08:59 »
Quote from: dux;436776
Can you please measure the space bar of the Iphone and the Siri? Are these tenkeyless keyboards?
Offline hashbaz
  • Grand Ancient One
« Reply #25 on: Sat, 22 October 2011, 13:09:15 »
I'm down for RGBY, but I'm not super keen on the Cherry star legend.  Also not sure how economical splitting the order across the various shift lengths will be.  I'll be in contact with Melissa at SP about this next week.
Offline hashbaz
  • Grand Ancient One
« Reply #26 on: Sat, 22 October 2011, 13:10:50 »
Quote from: tsangan;436721
Have you seen the blank RGB sets sold by Elite Keyboards and WASD?
Offline 7bit
  • MX1A-G1DW
« Reply #27 on: Sat, 22 October 2011, 13:14:21 »
Quote from: hashbaz;436782
This is what we demand:
« Reply #28 on: Sat, 22 October 2011, 13:19:09 »
What on earth are you talking about?
Offline hashbaz
  • Grand Ancient One
« Reply #29 on: Sat, 22 October 2011, 13:48:33 »
Quote from: demik;436790
Translating people's plaintext Round 4 orders into acceptable order strings.
« Reply #30 on: Sat, 22 October 2011, 13:49:54 »
I got that, he lost me on the iPhone and Siri part.
Offline Intense
« Reply #31 on: Sat, 22 October 2011, 13:50:00 »
i would be interested in 1 esc and a RGB set
Ergodox EZ w/Zilent V2s | WIP Dactyl Manuform 5x7 w/Holy Pandas
Offline tsangan
  • 1000/600
« Reply #32 on: Sat, 22 October 2011, 14:17:01 »
Quote from: hashbaz;436784
Sadly their colours are really ugly, either its the blue is too light or the green is too light ;(
RGBY Rebel Kit!!!!!!! lol
Keyboardless
Offline Atenacius
« Reply #33 on: Sat, 22 October 2011, 14:19:33 »
I'm in for 2 Esc keys only.
Keychron Q6 GATERON G PRO YELLOW
Vortex Pok3r CHERRY MX RED
Das Keyboard Model S CHERRY MX BLUE
IBM Model M
1391401 09 MAR 93
Offline Grond
« Reply #34 on: Sat, 22 October 2011, 14:20:08 »
I don't know where the Cherry star come from. I suspect it's not a star but a cursor that Sixty designed it for this board! http://keyboardporn.com/mx-switch/g80-3500-hau---cherry-mouseboard/
I think the yellow key should be an alternative - and neutral - system key. Maybe it could be a simple "diamond" key, as seen on previews GBs. Otherwise it could feature the good old cherry logo, if it's not too detailed to double shot.
Offline hashbaz
  • Grand Ancient One
« Reply #35 on: Sat, 22 October 2011, 14:26:53 »
Quote from: Grond;436838
I like the idea of an OS-agnostic yellow Meta key.  I'd like to avoid another custom legend if possible though.
Offline Grond
« Reply #36 on: Sat, 22 October 2011, 14:59:15 »
"Meta" it's ok for me, I think it woul look fine. That won't be cheaper than a costum legend though, since it's a costum font anyway.
I was looking for a close up on the windowed cherry logo key found on keyboards such as the 2100, but I could not find it. Anyway, I think it looks roughly like this:
[ Attachment Invalid Or Does Not Exist ] 29543[/ATTACH]
« Reply #37 on: Sat, 22 October 2011, 15:00:26 »
Quote from: Grond;436853
(Attachment Link) 29543[/ATTACH]
Odds are that will be too detailed for SP to make into a doubleshot. Also, the 'meta' has been used on a lot of keys already.
Offline tsangan
  • 1000/600
« Reply #38 on: Sat, 22 October 2011, 15:09:26 »
Quote from: RColinTaylor;436855
That doesn't look too bad, there should be enough space between the lines for it to work, that is if people wants it
Keyboardless
Offline jpm804
  • KeyCap Assasin
« Reply #39 on: Sat, 22 October 2011, 15:24:38 »
would be in for some esc keys and a RGB or CMYK kit.
REALFORCE|FILCO|HHKB|KBC POKER X|LEOPOLD|CM STORM|SIIG (GHSS)|IBM SSK
« Reply #40 on: Sat, 22 October 2011, 15:33:27 »
Quote from: tsangan;436859
My concern is in the spacing between the fruit and the spacing between the leaf; SP has very strict rules about their Doubleshots and, if the TeamLiquid key is any indicator, they will make you change your design or they will not even attempt it.
Offline eyeshield21san
« Reply #41 on: Sat, 22 October 2011, 15:41:01 »
I would be interested in a esc+rgb(y?) set that fits filco and/or noppoo mini choc.
Offline Grond
« Reply #42 on: Sat, 22 October 2011, 15:43:40 »
According to the wiki: "gaps between lines must be at least 0.5mm". I don't know how to measure that, but I believe the logo could be modified to respect that rule. Anyway, as I said, I'm also cool with "meta" if more people preferes that.
Offline dux
« Reply #43 on: Sat, 22 October 2011, 16:00:49 »
Quote from: 7bit;436781
Those were some group buys that I missed 'cause they went too fast for me. Can't tell you much about them. I could try digging in some Korean forums if you're really interested.
Offline dux
« Reply #44 on: Sat, 22 October 2011, 16:11:26 »
Quote from: 7bit;436786
I'm taking one of those, but without the win keys.
« Reply #45 on: Sat, 22 October 2011, 16:13:55 »
I think people are trying to turn this buy into something far more complex than Hashbaz had in mind when he decided last night to throw out the interest check.
Offline calavera
« Reply #46 on: Sat, 22 October 2011, 16:36:23 »
How about you split it into two general categories, make it simple.
choice #1 : ESC only
choice #2 : RGBY for Filco/Poker/Leopold...etc (all 1.25)
choice #3 : RGBY for others (1.5 modifiers + single ALT, short right shift for Noppoo choco mini, EU-size shift)
Something like that, see how many are interested in each.
« Reply #47 on: Sat, 22 October 2011, 16:37:23 »
Quote from: calavera;436915
Probably the best way to go about this, yes.
Offline jwaz
  • * based mod
  • #geekhack on freenode
« Reply #48 on: Sat, 22 October 2011, 16:56:28 »
Interested in 2 Esc keys and a set of RGB CTR Shift ALT (for leopold/ poker), Seattle WA.
Offline The_Ed
  • Asperger's... SQUIRREL! I'm Anal Retentive *****!
« Reply #49 on: Sat, 22 October 2011, 18:29:32 »
1x cycloverid font red esc for ed. MN, USA.
red escape good for ed.
Reaper "frelled" me... Twice... Did he "frell" you too?... *brohug*
I'm camping for a week, and moving twice in a month. I'll get back to you when I can (If I don't then just send me another PM).
R.I.P.ster
