Author Topic: Heavy ass ghetto rigged KBC Poker  (Read 9431 times)
Offline Lethal Squirrel
  • I <3 60%
« on: Fri, 04 November 2011, 19:04:20 »
I thought my Poker was too light. So I filled it full of lead.
Not sure how much it weighs exactly, but it's heavier than my Rosewill now. xD
[ Guests cannot view attachments ] 30859[/ATTACH]
Offline AvenZerg
« Reply #1 on: Wed, 09 November 2011, 13:27:58 »
how did you attach all of that stuff without the keyboard making a hell of a noise when you move it around?
[SIGPIC][/SIGPIC]
  • I <3 60%
« Reply #2 on: Thu, 10 November 2011, 01:27:19 »
Lots and lots of hot glue
Offline spolia optima
« Reply #3 on: Thu, 10 November 2011, 10:58:24 »
​I do the same thing with my Cherry 'boards, 'cept I put some rubber deskmat stuff in between the lead and the PCB.
keyboards!
  • I <3 60%
« Reply #4 on: Sat, 12 November 2011, 00:39:29 »
Oh yeah of course. I did the same. I just didn't show a picture of it. I wouldn't watch that lead bridging anything
Offline peda
« Reply #5 on: Sat, 12 November 2011, 01:49:32 »
where are the guys who screamed lead-poisoning in the keycaps thread? :doh:
but good idea.
anyway: if you do it the next time (or for those who want to do that as well), you might consider to use these lead-tapes we use in golf: http://www.golfsmith.com/product/30040212/golfsmith-1
no need to handle glue etc.
Offline ishtob
« Reply #6 on: Sat, 19 November 2011, 06:41:58 »
fishing weights?
Offline Oqsy
« Reply #7 on: Sat, 19 November 2011, 08:43:46 »
Peda, inside the case means no contact in normal use. Big difference from a key cap. Lead poisoning is cumulative, like arsenic, etc.
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
Offline TheProfosist
  • Custom Layouts Only!
« Reply #8 on: Sat, 19 November 2011, 14:48:14 »
This is what I use its perfect http://tinyurl.com/7lg8nyk ;) I have it in 2 Rosewills now modding one for someone as well. Since my DOX uses a poker case I should be able to add it in there right?  Also I recommend putting at least 2 if not 3 layers of electrical tape on top just in case. I didnt do this originally and had some problems.
Offline Skoobs
« Reply #9 on: Sun, 20 November 2011, 16:18:45 »
think dynamat would do basically the same thing?
« Reply #10 on: Sun, 20 November 2011, 16:23:48 »
Quote from: Skoobs;456300
dynamat?
