Author Topic: [FINISHED] Faux Cherry Red ESC + RGBY modifier kit  (Read 238875 times)
Offline litster
  • rare caps?! THAT'S A SMILIN
« Reply #950 on: Fri, 16 March 2012, 01:34:16 »
If you don't, you should be.  I gave you **** for your non-stepped, off-center stem capslock.  And tsangan and hashbaz are my buddies.  Your enemy's buddy is your enemy.
Offline The_Ed
  • Asperger's... SQUIRREL! I'm Anal Retentive *****!
« Reply #951 on: Fri, 16 March 2012, 01:45:21 »
You gave me flak for 1 thing. Big deal. Both you and Hashbaz are alright in my book, same goes for ripster.
Reaper "frelled" me... Twice... Did he "frell" you too?... *brohug*
I'm camping for a week, and moving twice in a month. I'll get back to you when I can (If I don't then just send me another PM).
R.I.P.ster
Offline litster
« Reply #952 on: Fri, 16 March 2012, 01:51:05 »
:grouphug:
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #953 on: Fri, 16 March 2012, 01:52:11 »
Quote from: The_Ed;547532
:thumb:
Offline Reptile
« Reply #954 on: Fri, 16 March 2012, 02:35:44 »
Quote from: The_Ed;547484
I don't even know who/what Kony is. Tsangan is #1 on my list.
What did he do?
Home:Realforce 87UB 55g
Work:Leopold FC700R Ergo Clears
Offline Grond
« Reply #955 on: Fri, 16 March 2012, 04:40:22 »
I got them today – at last! :D RGB and ESC look amazing! Now I'm looking forward to the new yellow and Moogle kit 3!
Thanks again for the great job!
Offline hashbaz
  • Grand Ancient One
« Reply #956 on: Fri, 16 March 2012, 08:52:45 »
Quote from: Grond;547633
Wow that took forever.  Glad you like them!
Offline Mysteric
  • Formerly 'Mackem'
« Reply #957 on: Fri, 16 March 2012, 10:57:40 »
I was extremely surprised at how fast mine arrived, think it was 3 or 4 days from US to UK :D Still waiting on my keypuller from qtan; It's been 10 working days and no sign yet :(
Offline lightsout714
« Reply #958 on: Fri, 16 March 2012, 10:58:46 »
Quote from: Mackem;547840
Stuff can be pretty slow from qtan, it will get there though.
Offline Mysteric
  • Formerly 'Mackem'
« Reply #959 on: Fri, 16 March 2012, 11:00:08 »
Quote from: lightsout714;547842
Yeah, I know, I'm just anxious for it to come so I can finally remove all of the keycaps properly, give it a good clean and put my RGBY kit on, faux Esc key and my novelty keys :D
Offline The_Ed
R.I.P.ster
Offline hashbaz
  • Grand Ancient One
« Reply #961 on: Mon, 19 March 2012, 16:26:06 »
Just got word back from Melissa.  Turns out cycloverid and I are both right, ha!  The Esc key is not 0.018", but it's also probably slightly thicker than 0.015".
Turns out the 's' in the Esc key came out as a blob at 0.018" so they bumped it down, probably to 0.017" or 0.016".  I responded asking her if there's a way to be sure which cutter was actually used.  She also reiterated that at the small gradations of scale we're talking about, the cutting and molding process is not exact enough to map a 0.01X" cutter to a final key line width measuring 0.01X".
Offline hashbaz
  • Grand Ancient One
« Reply #962 on: Mon, 19 March 2012, 16:43:18 »
Quote from: ripster;550826
Whatever happened to these then.  Melissa's error or ours?
(Attachment Link) 44946[/ATTACH] (Attachment Link) 44947[/ATTACH]
I mean, if the font's line width changes randomly how can we get Signature Plastics Key Round 10 to be perfect?
The Control keys in your picture are from the second round moogle set, which was 0.020".  That is clearly too thick, even given the variability of the cut/mold processes.  So I call that our error, though error isn't really the right word.  We've learned a lot about this process between moogle2 and RGBY.  Hopefully moogle3 will be as good as we can get with SP's process.
Offline hashbaz
  • Grand Ancient One
« Reply #963 on: Mon, 19 March 2012, 22:49:54 »
FWIW here is a scan of the photocopy I made.  It's pretty clear from this image that the final key's legend is both thicker and larger.
[ Attachment Invalid Or Does Not Exist ] 44970[/ATTACH]
edit: that's what she said
Offline The_Ed
« Reply #964 on: Mon, 19 March 2012, 23:01:27 »
Is it just me or does the "s" look completely different?
R.I.P.ster
Offline hashbaz
  • Grand Ancient One
« Reply #965 on: Mon, 19 March 2012, 23:18:42 »
Yeah it does.  I bet cycloverid tweaked it when he scaled the SVG larger after the prototype was done.
Offline Grond
« Reply #966 on: Tue, 20 March 2012, 16:47:23 »
Talking about the matte finishing – I bet someone wrote about this before – I noticed it changes a lot from key to key. On my set, Esc and right shift seem to be the roughest, while control, alt and super seem to be much smoother. I'm not complaining about this, as it's hardly noticeable until you touch the keys, I just wonder why?
« Reply #967 on: Tue, 20 March 2012, 18:45:13 »
Hmm, I just realized ESC is rough, too. For me, both (ansi) shifts are rougher than the modifiers. are you ISO?
I really like the rougher keys.
Offline cycloverid
« Reply #968 on: Tue, 20 March 2012, 23:15:21 »
I definitely tweaked the final ESC SVG a bit, including possibly scaling the legends up in size (it's all a little hazy to me now).
To me, the thicknesses look basically the same when inverting the black legends:
[ Attachment Invalid Or Does Not Exist ] 45148[/ATTACH]
Offline hashbaz
  • Grand Ancient One
« Reply #969 on: Tue, 20 March 2012, 23:34:13 »
Um, yeah.  Turns out you were right all along.  Melissa told me today that they ended up going with the 0.015" cutter rather than 0.016" like she thought before.  Annoying that she didn't tell me this earlier.  I think I will ask for the Enter prototype for moogle3 in 0.016".
Offline The_Ed
« Reply #970 on: Wed, 21 March 2012, 00:05:26 »
I'm betting that the closest to cherry will be .016" or .017".
R.I.P.ster
Offline hashbaz
  • Grand Ancient One
« Reply #971 on: Wed, 21 March 2012, 00:07:41 »
The bummer, though, is that if we go for fatter legends on the new moogle keys, the RGBY Ctrl/Alt/Shift legends will look different. :-|
Offline The_Ed
« Reply #972 on: Wed, 21 March 2012, 00:09:29 »
Yes but if the new keys finally nail cherry thickness they won't have to be redone for moogle 4. The RGBY keys would be the only ones that would have to be redone for moogle 4.
R.I.P.ster
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #973 on: Wed, 21 March 2012, 00:10:00 »
this is a problem that seems like it should be addressed when/if it actually bugs someone
Offline The_Ed
« Reply #974 on: Wed, 21 March 2012, 00:11:32 »
The legend thicknesses have already been bugging people. There are probably a few hundred posts about it...
R.I.P.ster
Offline hashbaz
  • Grand Ancient One
« Reply #975 on: Wed, 21 March 2012, 00:21:33 »
Quote from: The_Ed;552117
But in the meantime moogle3 is sullied with inconsistent legends. :(
Offline mkawa
« Reply #976 on: Wed, 21 March 2012, 00:28:56 »
Quote from: The_Ed;552119
(and not just people with asperger's...)
Offline The_Ed
« Reply #977 on: Wed, 21 March 2012, 00:36:52 »
Quote from: mkawa;552139
Unless hashbaz and cycloverid also have aspergers...
R.I.P.ster
Offline Grond
« Reply #978 on: Wed, 21 March 2012, 05:28:09 »
Yes, ISO left shift is not as rough as the right one. And I also prefere the rougher keys, I think they will take longer to wear out.
Offline hashbaz
  • Grand Ancient One
« Reply #979 on: Wed, 21 March 2012, 06:28:13 »
My guess is that ISO left shift is the same mold as the 1.25x modifier keys.  The roughness might be varied by row?
Offline Grond
« Reply #980 on: Wed, 21 March 2012, 06:39:53 »
Maybe so, but still doesn't make much sense to me. Aren't there several matte options available from SP?
