Author Topic: korean switch stickers, where do you get them?  (Read 6143 times)
Offline ishtob
« on: Mon, 14 November 2011, 15:57:58 »
I'm not sure if this have ever been discussed before, but I can't seem to find anything about these outside the korean forum:
http://www.kbdmania.net/xe/index.php?mid=photo&page=8&document_srl=3117815
Offline NormaJean
« Reply #1 on: Mon, 14 November 2011, 16:07:07 »
I'm not sure I understand where exactly those would be applied...
Offline reaper
« Reply #2 on: Mon, 14 November 2011, 16:07:44 »
Quote from: ishtob;452040
Hmm... looks like another group-buy project. lol
Din Eli
Offline RiGS
« Reply #3 on: Mon, 14 November 2011, 16:16:25 »
It is a vinyl sticker that fits directly on the switch casing. It should dampen the sound (pinging) of the switch and also stop the dust from entering the switch case. It should work nicely with lubed switches.
Btw soulfree914 was kind enough and enlighted me about these:
Quote from: soulfree914
The sticker is used to eliminate the small movement (left-to-right) in the plastic part of the switch, so it is not something major as oiling & greasing, but the sensitive keyboard enthusiasts could not stand that tiny flaw and made stickers that fit perfectly in that small crack of the switch. lol
My experience was that, after applying the switch, it did fill up that small niche and eliminate the unneeded horizontal tilt from the plastic part of the switch.  And I believe your point on preventing dust contamination is another good observation. But sometimes it is too much of a job for such a small, mostly unnoticed effect.
« Last Edit: Mon, 14 November 2011, 16:23:31 by RiGS »
Offline whiskerBox
« Reply #4 on: Mon, 14 November 2011, 16:42:07 »
Interesting am I safe to assume that you can use these in conjunction with O-rings?
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
Offline RiGS
« Reply #5 on: Mon, 14 November 2011, 16:45:08 »
Absolutely, as the O-rings applied on the stem of the keycaps.
Here some pics to get a better idea:
« Last Edit: Mon, 14 November 2011, 16:50:09 by RiGS »
Offline whiskerBox
« Reply #6 on: Mon, 14 November 2011, 18:46:51 »
Ok I didn't understand where the sticker was actually going, that all makes sense now.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #7 on: Mon, 14 November 2011, 19:39:38 »
Quote from: whiskerBox;452167
At least if you're willing to forgive some serious OCD craziness.
Filco w/ Imsto thick PBT
Offline mmmty
  • bang! bang!
« Reply #8 on: Mon, 14 November 2011, 21:07:53 »
Damn, that is tight!!!  :eek:
Keyboardless
Offline ishtob
« Reply #9 on: Tue, 06 December 2011, 21:08:18 »
so... anyone want to get designing on this? or should I start another DIY project :P
