Author Topic: Cherry MY 1800 beige doubleshot donor  (Read 3193 times)
Offline mbodrov
« on: Wed, 16 November 2011, 20:31:50 »
http://www.ebay.com/itm/Cherry-MY1900-Point-Sale-POS-keyboard-card-reader-programable-/110776652812
Currently at $0.99 on ebay.com with 4 days to go.
Also a bunch of relegendable keycaps on this keyboard, which may be a turnoff or a bonus to you.
Offline RColinTaylor
« Reply #1 on: Thu, 17 November 2011, 00:28:00 »
Quote from: mbodrov;453680
I will give you $30000000 to remove all information from this thread and burn your records.
I like my Browns more than my Blues.
Offline eagleeye
« Reply #2 on: Thu, 17 November 2011, 01:40:57 »
Don't MY caps have different stems than MX caps?
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #3 on: Thu, 17 November 2011, 01:55:02 »
Different switch type, but the stems are compatible.
« Reply #4 on: Thu, 17 November 2011, 21:23:47 »
Quote from: RColinTaylor;453765
It's still only at $.99
« Reply #5 on: Thu, 17 November 2011, 22:59:36 »
Quote from: dorkvader;454398
That's my bid.
Offline hashbaz
  • Grand Ancient One
« Reply #6 on: Thu, 17 November 2011, 23:05:44 »
Are you sure those are 2-shots?  Image is small and no model number...
Offline sealcouch
« Reply #7 on: Thu, 17 November 2011, 23:21:49 »
I had one of these boards. The fit cherry stems just fine.
Offline mbodrov
« Reply #8 on: Fri, 18 November 2011, 02:15:15 »
Quote from: hashbaz;454489
I'm sure. It's clear from the image.
You need to look at the ~, F, J, numpad + keycaps. They're different between lasered and doubleshot versions.
« Last Edit: Fri, 18 November 2011, 02:18:06 by mbodrov »
« Reply #9 on: Fri, 18 November 2011, 03:32:19 »
In the end, for under $5, the relegendables are 100% worth it. If it does come out to be lasered then I will just throw it in our maintenance shop at work to replace the 3000000 year old dell rubberdome.
« Reply #10 on: Fri, 18 November 2011, 04:56:30 »
How about the keys, and left ? On my modern MY boards, these had different stabilizers that were not compatible with MX. I don't know about the older type of MY (with black shaft), though
Offline mbodrov
« Reply #11 on: Fri, 18 November 2011, 06:20:18 »
Unlikely, but if it turns out to be a problem, you can just transplant the stabilizers as well. Harder than a simple key swap but not a whole lot harder.
Offline hashbaz
  • Grand Ancient One
« Reply #12 on: Fri, 18 November 2011, 07:00:03 »
Quote from: RColinTaylor;454615
MY switches are pretty bad man.  You might be better off with the RD.
« Reply #13 on: Fri, 18 November 2011, 09:59:28 »
Quote from: hashbaz;454689
Well then I guess I will dumpster it and be happy with the relegendables if I can get them. Its sort of just a shot in the dark but for $.99 + $9.99 shipping I can't be too mad with a bad result.
