Author Topic: Realforce Uniform 30g ANSI  (Read 9278 times)
Offline Bongoojingie
« on: Wed, 30 November 2011, 19:53:39 »
Don't have anything in terms of actual content, but I have 2 Realforce Uniform 30g coming in from Japan ($117 shipping from Rakuten :(  Ouch!) and a Realforce 87U variable and by the end of this project will have a Realforce 87U in uniform 30g.
Update 1:
 So the 30g Topre boards have arrived from Japan.  Quicker than I expected them too.  But I guess for the shipping cost, it had better be quick!  Now to wait for my 87U to arrive, and then time to cut rubber!  The Topre 30g boards I got a 108 key.  They were the cheapest 30g boards I could find, and the extra keys are only useful in this case.  I had almost forgotten how large full sized boards are compared to the tenkeyless I've been using so much recently.  It's probably 3 times the surface area of my HHKB.
[ Guests cannot view attachments ] 33760[/ATTACH]
Update 2:
My first 87U Variable arrived today so I jumped right into the work.  I started with opening up the 108 board first.  Figured this was my first time cracking open a Realforce, I should do it on the donor board first.
[ Guests cannot view attachments ] 34075[/ATTACH]
[ Guests cannot view attachments ] 34076[/ATTACH]
Was happy to find the cable detaches very easily.  Just a plug and a single screw and the PCB+Plate combo are loose.
Then come all the screws.  There are soooo many screws.  This is the pile from just the 108.
[ Guests cannot view attachments ] 34077[/ATTACH]
Luckily the wholes are marked for which whole is a dark screw or a silver screw.  The dark screws have an area of no thread towards the head of the screw while the silver ones are threaded the entire way.
I used a couple of cubes as a makeshift stand to keep the plate floating in the air upside down so all the switch casings were out.
[ Guests cannot view attachments ] 34082[/ATTACH]
[ Guests cannot view attachments ] 34079[/ATTACH]
I used a cutting board and an X-acto knife to cut my cup rubber.  The 108 didn't have LEDs in the switches for caps lock, etc., so I had to cut new wholes for those.
[ Guests cannot view attachments ] 34083[/ATTACH]
And then I laid the springs in the rubber domes.
[ Guests cannot view attachments ] 34084[/ATTACH]
Ooh shiny.  And that's all for tonight!  Tomorrow I put the PCB on face down, put all the screws back in and hope for the best.  This one was pretty easy, as I just stole the sheet from the 108 board.  However, I verified the 30/35g keys on a Topre Variable match my Uniform 30g (via Ripometer) which is what I was hoping for.  Since there are 17 30g keys on a variable, I need to replace 70 switches.  The two 108 boards total 216, which means I can do 3 boards, for only 2 donors.  The last one is going to be the worst, since I won't have a sheet to use, and will be using individual rubber domes for pretty much the entire board.  I should have 2 87U anniversary edition coming shortly, to complete the mod.  Now the only question is, which one do I keep, the black or an anniversary?!
Update 3:
So from the picture above, I layed the PCB down on top.  I double checked all the springs to make sure I didn't have 2 in any rubber dome because the springs stick together quite easily.  I put in all the silver screws first, since there were less of them, and flipped the board over.  Everything looked straight and smug so I put it all back together and I'm typing on it now!  It feels greats and I'm finally not spamming typos because of the weird Japanese layout!  I realize I didn't take any pictures in my excitement to put it all back together, but good news for anybody reading this is that I have 2 more of these to do and so I can get pictures then!
Realforce 87U Black Uniform 30g | Filco TKL Black Ergo Clear | Filco TKL White Ergo Clear | Filco TKL Linear R Limited | Custom Dell AT102W w/ White ALPS | HHKB Pro 2 Type-S | TypeNow Solid Blues | SteelSeries 7G
Offline tsangan
  • 1000/600
« Reply #1 on: Wed, 30 November 2011, 23:57:10 »
This going to be crazy light, forget about resting your hand on the home row :p
Keyboardless
Offline keyboardlover
« Reply #2 on: Thu, 01 December 2011, 21:21:52 »
Unique mod idea...looking forward to seeing how it turns out...
Offline hasu
  • @tmk
« Reply #3 on: Fri, 02 December 2011, 00:21:18 »
Sounds promising.
I'm in the same boat, but my plan is HHKB 30g. I got a Realforce 106s the other day and waiting for modding now.
I'm happy on my HHKB with variable weighted now, but 30g still is a fun thing :)
« Reply #4 on: Fri, 02 December 2011, 21:28:35 »
I quite like the feel of the uniform 30g on the 108 board.  It's less tactile than the 45g, but feels so smooth for my sissy hands.
