Author Topic: Easy Switch opener - from a guitar pick!  (Read 9135 times)
Offline ishtob
« on: Mon, 05 December 2011, 13:18:15 »
Step 1: use a pencil to mark down width of the latch
Step 2: Cut
Step 3: Test and enjoy :D
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #1 on: Mon, 05 December 2011, 13:42:19 »
Now I have a reason to have 1000000000 picks lying about. Good tip!
Fight For Freedom. Stand with Hong Kongers
Offline ishtob
« Reply #2 on: Mon, 05 December 2011, 15:54:08 »
making putting together ergo clears for my DOX so much easier
Offline braaaiiins
« Reply #3 on: Mon, 05 December 2011, 20:55:00 »
So resourceful haha. Would this work on switches that are already soldered on? Right now I'm using two small screw drivers and let me tell you its a PITA.
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #4 on: Mon, 05 December 2011, 22:49:20 »
Yeah opening a standalone switch is not a problem.  It's the ones attached to the PCB that are a pain.
Offline ishtob
« Reply #5 on: Tue, 06 December 2011, 00:57:38 »
bend the end back maybe?
Offline ishtob
« Reply #6 on: Tue, 06 December 2011, 00:58:55 »
braiiins, i have a method to use only 1 screw driver to remove the top from PCB mounted switches... i actually find it easier to do than these detached ones
Offline oneproduct
  • @Ubisoft
« Reply #7 on: Wed, 07 December 2011, 22:26:22 »
Quote from: ishtob;465041
Do tell! I opened up a bunch of PCB mounted ones using a flathead screwdriver placed between the two parts that snap around and popping it off, but it wasn't all that easy.
Layout: Colemak
Offline ishtob
« Reply #8 on: Thu, 08 December 2011, 00:13:05 »
the trick i found is to depress the stem first then insert screw driver to either one of the upper tabs. pull up on that side and hold it, and now do the other upper tab.
Offline ishtob
« Reply #9 on: Thu, 08 December 2011, 00:14:42 »
i swap a keyboard like this in ~30 min
Offline oneproduct
  • @Ubisoft
« Reply #10 on: Sat, 17 December 2011, 10:00:51 »
Quote from: ishtob;466323
By upper tab do you mean the plastic around the center you can hook under now that the stem is pushed down and out of the way? I'd be worried about damaging it I think, though I guess you had no problems with that.
Layout: Colemak
