Author Topic: Corsair K60 Or Leopold Tenkeyless Otaku  (Read 4552 times)
Offline rhizo
« on: Wed, 21 December 2011, 17:45:24 »
Hi guys, which is better in your opinion? they are of equal price to me. thanks!
Offline DaemonRaccoon
« Reply #1 on: Wed, 21 December 2011, 17:48:38 »
Go for the Leopold, the Corsair is a werid hybrid of rubber domes and MX switches.
122-Key Model F 6110345 1985-03-01 | Model M SSK 1391472 1991-01-22 | Rosewill RK-9000 v1 | KBC Poker X | Filco FKBN87M/PWE2
Offline rhizo
« Reply #2 on: Wed, 21 December 2011, 17:51:36 »
so i have heard, hmm, and the blank keys look the dogs...
Offline DalaiLameR
« Reply #3 on: Wed, 21 December 2011, 18:32:55 »
Leopold!
[SIGPIC][/SIGPIC]
Model M SSK ReAlforce 88UB 45g Filco MX Blue Filco MX Red
Offline RickyJ
« Reply #4 on: Thu, 22 December 2011, 00:44:07 »
Quote from: DaemonRaccoon;475474
That's only the K90, as far as I know.
I've been curious about the Corsair boards since I can get them cheaper in Canada than bringing a Leopold across the border.  If they're both the same price for you, Leopold tenkeyless all the way!  I'd be hard pressed to go back to a fullsize keyboard.
« Last Edit: Thu, 22 December 2011, 00:48:44 by RickyJ »
Currently GMMK Pro: lubed 68g U4T, FR4 plate, extra gaskets, etc
Offline Greenbean
« Reply #5 on: Thu, 22 December 2011, 00:59:37 »
Quote from: RickyJ;475646
I believe the K60 also uses a mixture of MX Reds and rubber domes.
Quote from: Corsair
Tuned silicon dome keyswitches: F1 through F12, Esc, PrtScn, Scroll Lock,  Pause/Break, Insert, Home, Page Up Page Down, Delete, and End
Link to Corsair K60 Product Page
Click the "Tech Specs" on the side menu and look around.
« Reply #6 on: Thu, 22 December 2011, 01:01:30 »
3 ways to make the corsair boards great.
Tenkeyless
Full mech
Different switch options
Offline RickyJ
« Reply #7 on: Thu, 22 December 2011, 01:26:47 »
Quote from: Greenbean;475649
F'n hell, thanks Corsair for going out of your way to mess up an otherwise solid offering. :(
Offline Gin
« Reply #8 on: Thu, 22 December 2011, 01:38:06 »
They probably figure that they could save some money on the cherry MX switches where they think people won't use that much. Wasn't a very good decision.
Offline rhizo
« Reply #9 on: Thu, 22 December 2011, 03:01:47 »
thanks guys, pretty much unanimous leopold :) will get it after christmas! cant wait, but still a little sceptical... i mean its 100£ for a keyboard!
Offline gregh
« Reply #10 on: Thu, 22 December 2011, 07:14:47 »
I say go with the Corsair.
I have the K90 and the hybrid board doesn't bother. Unless you use the function keys a LOT, it probably won't bother you either. But some people have reported that it's jarring for them...
Honestly, order the Corsair K60 on Amazon and just return it if you don't like it. That's what i do these days, I just order everything on Amazon and try it out...make use of their amazing return policy. Even if they charge a restocking fee, go to the live chat and ask them to remove it...they ALWAYS will.
I'd wager that most people on the net (not this forum specifically) who are suggesting the Leopold haven't used both keyboards. I have and I prefer the K90 (about the same as the K60).
Offline jellowiggler
« Reply #11 on: Thu, 22 December 2011, 07:15:58 »
I thought the k90 I had was a pretty nice keyboard. But I couldn't get past the different types of keys being used. It feels pretty jarring to me.
The k60 has the same issue. Rubber dome keys are used for the f key row including esc.  Same with the ins/del block.
Mike -jellowiggler-
Filco MJ2 Tenkeyless / Rosewill RK-9000 / IBM Model M 1391401 / Logitech DiNovo Edge / MS Sidewinder X4
Offline Human
« Reply #12 on: Thu, 22 December 2011, 09:12:19 »
Quote from: jellowiggler;475775
The main reason I gone mechanical is because I want durability and consistently in all key feels even after a long time, which is sure hard to be achieved by RD.
Now, Corsair make the choice easier as we don't even need to wear it to make a different between key feels...
Congrats Corsair for which they saved less than 5$ for each board but also manage to kill off more than 20% potential buyers.
Though, I do hope to see any disassemble video of the keyboard to confirm whether there is any room or chance to mod those RD away and replace them with same switch.
« Last Edit: Thu, 22 December 2011, 09:17:31 by Human »
Offline rhizo
« Reply #13 on: Thu, 22 December 2011, 11:12:18 »
Ok, probably going to use that amazon refund policy, but last question, WASD keyboard or leopold? :D
