Author Topic: wyse THICK double shot keycaps  (Read 4798 times)
Offline heliar
  • Trade Count: (0)
« on: Wed, 28 December 2011, 18:56:14 »
these are the earlier THICK keycaps from Wyse, please note the layout is ISO/GB one. Pict 1 shows what you will get. The third key from Pict 2 and the first key from Pict 3 are from cherry and the later thin wyse respectively, just show the comparison between the thickness among the three.
$35 shipped worldwide.
Please send money through as GIFT, otherwise please add 3% handling fee.
« Last Edit: Thu, 05 January 2012, 23:42:13 by heliar »
Offline Kisakuku
  • Trade Count: (0)
« Reply #1 on: Wed, 28 December 2011, 18:57:40 »
I'll take them.
Offline tsangan
  • Trade Count: (0)
  • 1000/600
« Reply #2 on: Wed, 28 December 2011, 19:00:38 »
oh heliar why you gotta bring such awesome stuff but have it in ISO format, get us some ANSI!!!
Man they look so good lol
EDIT: side note, heliar you seem to be a Wyse expert. Do you know which model of the Wyse keyboards have these thick keycaps? Just so I know what to look out for
« Last Edit: Wed, 28 December 2011, 19:05:03 by tsangan »
Keyboardless
  • Trade Count: (0)
« Reply #3 on: Wed, 28 December 2011, 19:05:51 »
would you say he's a....wyse guy?
thank you thank you, i'll be here all night.
Offline heliar
  • Trade Count: (0)
« Reply #4 on: Wed, 28 December 2011, 19:22:37 »
frankly, I don't. my personal guess is that wyse was in transition from the thick one to the thin one, so you can find in the same keyboard both the thin and thick, quite fun actually.
the wyse stuff is cool, i am done with cherry, well almost done.
Quote from: tsangan;479308
Offline tsangan
  • Trade Count: (0)
  • 1000/600
« Reply #5 on: Wed, 28 December 2011, 19:23:26 »
Hmmmm maybe get this and use it for ANSI for thick then get another wyse set for the missing keys for the ANSI lol mainly only the ,< | .> | \| keys
Keyboardless
Offline Kisakuku
  • Trade Count: (0)
« Reply #6 on: Wed, 28 December 2011, 19:31:16 »
Quote from: tsangan;479319
That's exactly what I was thinking. Can't wait for one perfect set forever.
Offline whiskerBox
  • Trade Count: (0)
« Reply #7 on: Wed, 28 December 2011, 20:40:49 »
This set has my favorite style function keys of any of the wyse sets
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
Offline heliar
  • Trade Count: (0)
« Reply #8 on: Fri, 30 December 2011, 14:05:44 »
I still have not figured out that, as even within this model, you will find a totally thin-capped board, a partially thin-capped one and a fully thick-capped one. This one is produced in around 1991, as stated in QC label found inside. The 1993 boards are all thin-capped. So I guess the safer bet will be those made in late 80s and before.
And as I use those thick one on a Wyse PCE board (900866-01), the modifier issue does not bother me. And also to a lesser extent, ISO/ANSI layout difference. I just use all the original modifiers. The color scheme also matches perfect.
Although I don't have the equipment on hand, I think those wyse thick caps should be just very slightly heavier than the thick DS cherry ones. The wyse is certainly better finished than the cherry ones.
« Last Edit: Fri, 30 December 2011, 14:22:27 by heliar »
Offline heliar
  • Trade Count: (0)
« Reply #9 on: Fri, 30 December 2011, 14:14:25 »
Quote from: whiskerBox;479345
what other style of layout have you seen? i think the earlier the board the more interesting their style.
Offline IvanIvanovich
  • Mr. Silk Underwear
  • Trade Count: (0)
« Reply #10 on: Fri, 30 December 2011, 15:23:21 »
They used some different fonts and had a smaller more centered position on some of the later ones. Some of them don't have the cool yellow arrows either. Later ones have a closed 4 instead of open, and extra legends on the numpad instead of just numbers. The grey color of the keycaps seem to be a lighter shade too on the later ones.
The older 30-60 models seem to be the most likely to have the thick caps.
Looks like they are in excellent shape and it's rare that none of the modifiers etc. are grey. I already have my own 37+numbers set that I salvaged and don't really need another one. If more keycaps were modern size for the correct locations I would pick them up.
GLWS.
Offline heliar
  • Trade Count: (0)
« Reply #11 on: Fri, 30 December 2011, 18:58:40 »
the tragic thing is that the board itself is even nicer than the caps, they make the cheap filco caps feel better than they are. such a pity can't make those terminal boards working again.
Offline litster
  • Trade Count: (0)
  • rare caps?! THAT'S A SMILIN
« Reply #12 on: Fri, 30 December 2011, 19:08:45 »
Information you need to know on how to make these Wyse keyboards to come back to life again.
http://deskthority.net/viewtopic.php?f=7&t=646
http://deskthority.net/viewtopic.php?f=7&t=7
http://deskthority.net/viewtopic.php?f=7&t=15
Offline heliar
  • Trade Count: (0)
« Reply #13 on: Fri, 30 December 2011, 19:20:56 »
Quote from: litster;480709
thanks, I will spend some time on them.
Offline RiGS
  • Trade Count: (0)
« Reply #14 on: Fri, 30 December 2011, 19:23:05 »
Quote from: heliar;480704
Do you mean the switches?
Offline heliar
  • Trade Count: (0)
« Reply #15 on: Fri, 30 December 2011, 19:46:48 »
'Do you mean the switches?'
the board, that is the black cherry together with the metal plate. they just feel nicer (more dampened sound, without being at the same time hard, like the filco ones for example, and more solid feel, less vibration from the caps/switches) than the later wyse keyboard. maybe that has to do with the thickness of the plate, PCB layers, plastic quality, lubrication used etc.
even the cherry stabilizer found in wyse is much nicer than the ones you find in cherry keyboard, and it is a lot easier to remove/change than the filco costar one.
« Last Edit: Fri, 30 December 2011, 19:51:38 by heliar »
Offline heliar
  • Trade Count: (0)
« Reply #16 on: Thu, 05 January 2012, 23:42:46 »
bump
Offline heliar
  • Trade Count: (0)
« Reply #17 on: Mon, 09 January 2012, 21:38:18 »
one last set, incomplete, as shown below, the grey/biege keys and the arrow keys are the ones for sell, $30, including shipping.
Offline TranscendingLogic
  • Trade Count: (0)
« Reply #18 on: Mon, 09 January 2012, 22:11:07 »
PM'd
